Question about Springfield 91455 Wireless Digital Outdoor Thermometer and Clock
What does LL. LL mean on outside temp slot
After changing batteries and resetting, the outside temp display says LL.LL as the temp...no numbers
Can reset everything on my SkyScan Atomic Clock except for the outside temp. Have new batteries in both units. Main clock and outside remote thermostate..Any suggestions??
I expect that since the unit reads the outside temperature from the remote thermostat, there is no need to "reset" the displayed number since this data is obtained live from the thermostat.
Nov 04, 2015 | Home
How do you get the outside temp to display?
sorry no idea what you have , so can not look for any help
Aug 29, 2015 | Audio Players & Recorders
Model 00754W4 does not sense outside temperature..new batteries have been placed correctly in both inside and outside units..noW what do I do?
We would recommend a reset of your unit. Please verify that you are using good-quality, standard alkaline batteries such as Energizer or Rayovac, then follow the steps below.
1. Bring both the sensor and display unit indoors and remove at least one battery from each.
2. Make sure the A-B-C switch on both units match. Sometimes changing to a different channel can help.
3. Reinstall the battery in the outdoor sensor.
4. Reinstall the battery in the display unit.
5. Let the units sit within a couple feet of each other for about 20 minutes to gain a strong connection.
If you need any further assistance, please contact AcuRite Customer Support at 1-877-221-1252 or info@chaney-inst.com.
Dec 03, 2014 | Acu-Rite Acurite Wireless Indooroutdoor...
The outside temp sender won't work. We put new batteries in it, but it does not send a signal. It will not put an outside temp on the clock.
Simple, the instructions state that when changing the batteries on the outside temp. sensor, you must also change the batteries on the main clock unit. I had same problem when I changed the sensor batteries until I pulled the batteries from the clock and it reset fine. ( Sensor batteries first, then clock batteries. ) The clock will reset to atomic time overnight so don't worry if it doesn't read correctly at first.
Aug 18, 2009 | SkyScan 86709 Atomic Wall Clock
Reset Heating/ AIr cond temp display as well as EXT temp ????
the temp display can be switched between celsius and farenheit readings, since the car is from europe the default is celsius, The manual has instructions on changing back, You have to hold 2 buttons on the display per the manual.
May 07, 2009 | 2003 Land Rover Discovery
Remote Sensor
make sure your time is set and the atomic clock time is recieved, then leaving the rear cover off of the transmitter, push the "tx" button not the "c/f" that is just for centegrade or ferenhight. you will see the red light on the front of reciever flash in a few seconds. The temp should display on your clock screen. If not, did the red l.e.d. light on transmitter flash. If not, its not sending data to clock. I have to reset and hit transmit every time I replace batteries on transmitter. Had no problems for over 2 years of using outside. If your not getting a reading with transmitter sitting next to clock after hitting "tx" button you may have defective transmitter.
Jan 13, 2008 | Homedics Sound Spa Premier SS-5000 Clock...
Springfield 91455 Wireless Digital Outdoor Thermometer and Clock Logo
51 people viewed this question
Top Springfield Measuring Tools & Sensors Experts
ray gallant
Tom Chichester
Are you a Springfield Measuring Tool and Sensor Expert? Answer questions, earn points and help others
