Question about Garden
Toro Zero Turn Lawn Mower Model 74325
I need a manual or some written procedures on how to replace the engine in my Zero Turn Riding Lawnmower?
  • 246 Answers
SOURCE: bought a 2002 toro timecutter 18-52 zero turn lawn
Hello:
>>You can View a Breakdown/IPL of the Mower at this Site Addy, https://lookup3.toro.com/partdex/default.cfm and Select Start Parts Viewer. Now Enter the Model Numbers () and Click Search. Now Select View Assembly Drawings for your Year Model.
At the Bottom of the Page (#6), Use this Link to Locate your Local Toro Dealer who can Order the Manual for you or you can Contact Toro Using the Options at this Site Addy; http://www.toro.com/contact/Homeowner.html .
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 11, 2009
  • 57 Answers
SOURCE: Need linkage hookup diagram for Toro Super
Go to TORO.com and view parts for your model.
Posted on May 19, 2009
SOURCE: riding lawnmower starts but will not continue stay running?
its probably in your ingnition switch, grab the switch and turn it right the turn key I had the same problem and that fixed it. It also wasnt starting and it was the same problem the switch is lose.
Posted on May 31, 2009
  • 32 Answers
SOURCE: Toro Lawn Mower model 20016
it isn't the spark plug if it wont turn over. maybe your battery is dead.
Posted on Jun 12, 2009
SOURCE: Toro 22in Lawn mower. Loud gear noise when try to engage drive.
Problem is in the rear pinion gears on rear axle and the design of the axle itself. I have a 2005 model 20041 had the same problem. I found a Toro dealer that had the fix.The problem is creadted by the fact that there is too much "play" in the rear axle. You have to limit that play by installing shims, or washers First, but the 2 new rear pinion gears for the rear axle. While you're at it, you may as well buy 2 new rear wheels because the "grinding" has worn the sprockets on the reas r wheels.Next, get 2 "fender washers", 1/2" ID and about 1" OD. I found it easier to turn the mower over and set it on saw horses to work on it.( drain the gas and oil first). Remove both rear wheels, pinion gears and all the washers etc. (caution - keep all parts from one side together - do not pile all parts together - keep them seperated by wheel - the reason is I believe there is one more washer/shim on the right side than on the left). Now to put everything back together, find a spot on the axle where the washer will fit in between the standard stuff.Install new pinion gears and replace the rest of the washers/shims just as they came off. INstall new wheels and you'll be good as new!
Posted on Aug 02, 2009
Need information on fixing steering on we261 riding lawn mower.
you will have to pull the front wheel steering spindells if they dont have grease fittings and grease them
Jul 17, 2014 | Toro Lawnmower 20099 Mower Mowers Lawn
Lawn mower repair
You might want to post this in the lawnmower section so the proper experts will see it.
Sep 03, 2012 | Toro Mowers - Time Cutter SS4235 42""...
Cant turn toro time cutter to the right
You might want to post this question in the lawnmower section so that the proper expert sees it.
Sep 02, 2012 | Toro Mowers - Time Cutter SS4235 42""...
74325 can the motion control levers be out of adjustment
yest there is a adjustment either a stop for one handle or a linkage adjustment on the rods
Jul 12, 2012 | Toro TimeCutter Zero Turn Lawn Mower...
Where do I find a repair manual
you can find one at your nearest riding lawnmower repair or look in the phone book
Aug 15, 2011 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
Need manual to see what size bolt is that holds on
Hi and welcome to FixYa. I am Kelly,
It appears your model number is 74370 There are 3 bolts one for each blade and the part number is 26-0671 or 260671 for the blade mount.
Part look up:
http://www.jackssmallengines.com
then enter part number 260671 $6.31 ea.
You can not use just any bolt for this. They are hardened bolts with an NF thread. If you use a non hardened bolt the blade will fly off when the bolt shears.
This bolt is available at most all Lawn Mower Parts Supply sources. Toro uses the same bolt on most all of their mowers.
If you do not have a Lawnmower Parts Supply near by, you might be able to go to an Autoparts supply source with yet one of the other blade bolts in hand and have them match the markings on the bolt head with yours so that you have the exact replacement bolt.
Any other parts for your mower can be found here:
http://www.jackssmallengines.com/help.cfm
Use the Search model window. each line below is a drop down window
Toro
Riding
74370 <- there are numerous models up to 74704
enter your model number if different.
Thanks for using FixYa.
Kelly
Apr 27, 2010 | Toro 42'' Zero Turn Lawn Mower 22hp Kawa...
I have Toro Wheel Horse riding lawnmower model # 70040 - 790000
need the ser number of the unit. the pulley don't split its one part, i need the ser number . this is no easy job. good luck
Oct 13, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
