Question about ASUS K8V-MX Motherboard
Chack sum bois bad - ASUS K8V-MX Motherboard
  • 255 Answers
1. change the Bios battery
2. restart your computer
3. press Del key or F2 key to enter in Bios setup, and save the bios setup at Best performance or
Default setup...
try this..
Posted on Jun 20, 2009
ACER ASPIRE 4710
This will occure for a couple of reasons.
1. Your hard drive has gone bad or the connectors have.
2. Your bois is set to boot from the network card, and not the hard drive.
1. boot to the bois, and look to see if it "sees" your hard drive. If not replace the hard drive. This will require you to install the OS and software.
2. Boot to the bois, check the boot order and remove or disable boot from LAN or PXE. If this is the problem you should now boot from the hard drive, if not you will probably still get the no OS found error indicating a bad hard drive (see 1 above).
Hope this helps
Jun 27, 2012 | Acer Aspire One PC Notebook
Operating system not found
In all likelyhood, the computers harddrive has went bad. To check this you need to get the to bois. Power up the computer and during the ACER spash screen hold down the Ctrl, Alt, and Esc keys. This should take you into the bois of the ACER. Look for a section on drives and see if the harddrive is listed. If not you will need to replace the harddrive.
Feb 17, 2012 | Acer Aspire L310 Desktop
My pc is no audio
frist chack what windows your using and chack do u have audio is bilten on mother boeard some time if your not installing audio drivers u wont get sound
chack frist audio slote on u r PC then chack drivers if drvers are not install then you have to run that Drivers CD
May 12, 2010 | Computers & Internet
I dnt have sound card driverin my pc. i dnt kno evn mother board type. what should i do?
frist you have to find your motherboard model no then only you can find the drivers or u can chack your motherboard type from bois
Apr 19, 2010 | Intel Computers & Internet
Need to change mother board
WRONG ON THAT I HAVE ALL THE BOIS INFO YOU NEED.
WWW.lemig.umontreal.ca/bois/bois_sg.htm
www.ping.be/bois/numbers.shtml
www.allelec.com
email: mike@ttitech.com
www.unicore.com
go on line type in
update bois or upgrade bois
enter
typing in the bois name and date will tell you about any update or chacges and how to get the updates for free'
bois download drives my work also
rod
ps if you want mother information buy the new cpu magizine [ computer powers issue march 2009}
give you mother boards cpu cooling options cpu venders and option and more info check it out
rod
Feb 04, 2009 | AMD Asus A7V-ML Socket A MicroATX...
COMPUTER CHECK SUM ERROR'S ?
if you can enter bios (usually by pressing f2 or del), then load the default settings, otherwise, you will have to position the jumper properly, instructions for that are as follows.
1. Touch an exposed metal part of the case to ground yourself.
2. Unplug the power supply from the wall.
3. Move CMOS reset pins to short pins 2 and 3, then wait 10 minutes.
4. Replace CMOS reset pins back to 1 and 2.
5. Replug the power supply and boot.
Jan 20, 2009 | Acer Aspire™ T180 PC Desktop
Press F4
svjyrat
"always message to press F4 at the time of star up". this problem happen when CMOS detect any error. is also happen if CMOS battery fail (Chack sum error).
to solve this problem at first check CMOS battery (it voltage less then 3V or not) if it bad then replace it. u can buy this battery form any computer accessories shope.
or if u not connect floppy drive, and controller enable. if u desable floppy drive contoller from CMOS setup (in intel mother board is show BIOS setup) then this problem solved.
Jul 03, 2008 | Intel Motherboard
350w switching power suply
Michael
at first chack at which time it shutting down. if it happen when u click on any drive or when u using cd/dvd drive then power supply cant regulate power. then chack switching transistor and filter section capacitor.
(Be careful about filter capacitor in primary section because some time it stored high voltage dc after plug of power supply at first discharge this two capacitor.)
** also chack supply voltage r stady or not.
Jun 26, 2008 | Codegen POWER SUPPLY CG|PS-350XA-12 RT...
ASUS K8V-MX Motherboard Logo
81 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
