Question about H.D. Hudson Hudson ECO Ecology BakPak Sprayer 3 Gallon
Assembly for hudson eco bak pak sprayer 13601
How do I assemble a Hudson eliminator 30151?
Go online with make and model and search or go to manufacturer web site or find a local service centre and ask there.
Sep 21, 2014 | Chapin Home and Garden Premium Nozzle Kit...
Manual for 60000gt sprayer
Go online to company, customer service.
Jun 05, 2014 | Green Thumb HD Hudson 60000GT Gt...
Looking for hudson sprayer repair kits
you will need to contact them from here
http://www.hdhudson.com/contact-us
they will direct you to the closest reseller of their kits or they can ship one to you.
Dec 29, 2012 | H.D. Hudson 2g Yard N Garden Sprayer
Why does Pump not build pressure
probably bad seals or ring or the relief valve is stuck open
Aug 29, 2012 | H.D. Hudson Hudson Pumpless Sprayer 2...
I'm not sure how to fill the thing. It's a 2 gallon sprayer, yet when I open the top (i.e. remove the pump mechanism), there is a chamber, but it only holds about 1/4 gallon. How do I get the...
it sounds like you unscrewed the pump assembly. that chamber is actually part of the pump and sometimes they do separate. try to remove what you called the chamber. if that is part of the pump then it has to come out before you can put the pump assembly back together.
May 25, 2011 | H.D. Hudson 2g Yard N Garden Sprayer
How do i fill my hudson sprayer
On the link below page 2 will tell you how to fill your sprayer.
http://www.hdhudson.com/PDF_files/poly-sprayer-instruction-sheet.pdf
Good Luck and please rate 4 thumbs up for the free answer.
Jun 27, 2010 | Eliminator Hudson Sprayer - 1 Gallon,...
I have the hudson eliminator sprayer and squeeze the trigger I just get one burst of spray and then a couple of drips. I do have it pumped up all the way. What is the problem?
IF your sprayer is full you should be good to go after 20 or so full stroke pumps
If it is not spraying unscrew the adjustable tip and clean out the little holes around the end
If you leave spray in the unit after using it it will get crudded up and plug up
Mar 08, 2010 | H.D. Hudson Hudson, H D Mfg Co 1 - 1/2gal...
From jdwillia on hudson sprayer
I poured hot water in the top and let it soak for ten minutes. Removed pressure valve and it broke free.
Jun 16, 2009 | H.D. Hudson 2g Yard N Garden Sprayer
I have a hudson classic sprayer and have no instructions.
The pumping mechanism should unscrew from the plastic bottle. Push the handle all the way down and try to unscrew the pump while holding the bottle steady.
Need help with Hudson Trombone Tree and Shrub Sprayer Model 61224
There's a parts illustration on the Hudson web site that may be helpful to put the sprayer back together correctly. Here's the link: http://www.hdhudson.com/PDF_files/10.pdf
Jun 16, 2009 | H.D. Hudson Hudson Trombone Sprayer - 140...
H.D. Hudson Hudson ECO Ecology BakPak Sprayer 3 Gallon Logo
63 people viewed this question
Top H.D. Hudson Garden Experts
Dennis Key
Dennis Key
john h
Are you a H.D. Hudson Garden Expert? Answer questions, earn points and help others
