Question about Euro-Pro 9125 Computerized Sewing Machine
Needle won't rotate stalls - Euro-Pro 9125 Computerized Sewing Machine
How do I time a bobbin hook on a 153W Singer
all sewing machines are basically the same, the hook that rotates to pick the cotton up off the needle must just enter behind the needle when it's on it's way back up which then grabs the cotton to form the stitch, so you must remove the sole plate to expose the shuttle case remove the shuttle and put to one side, now rotate the hand wheel on the sewing machine in the correct rotation and watch the hook rotate round until it goes behind the needle, just as the needle is starting back up from it's lowest position the hook should just be going behind the needle to pick up the cotton, if this is not the case then loosen the screws that clamp the hook assembly to the shaft and rotate the hook assembly gently until the hook is just going behind the needle and make sure the hook is close to the needle before retightening the clamping crews , and final give it a few turns by hand to make sure the hook locates the same all the time and the hook is not catching the needle, when your happy, then reassemble.
Happy sewing
Feb 16, 2015 | Singer Sewing Machines
The bobbin thread will not raise with the needle
1. REPLACE NEEDLE W/FLAT PART AWAY FROM YOU.
2. MAKE SURE THE TOP THREAD IS PROPERLY THREADED.
3. INSURE BOTTOM BOBBIN IS ROTATING RIGHT DIRECTION. (USUALLY COUNTERCLOCKWISE) ALLOW THREE INCHES OF THREAD PULLED AWAY.
4. HOLD TOP THREAD W/LEFT HAND AND ROTATE HAND WHEEL TOWARDS YOURSELF. DOES IT BRING THE BOBBIN THREAD UP?
5. IF THE BOBBIN CARRIER IS INSTALLED PROPERLY THE HOOK (POINTED OBJECT) UNDER THE BOBBIN SHOULD "HOOK" THE TOP THREAD AND BRING THE THREAD AROUND THE BOBBIN THREAD. THE NEEDLE AND TOP THREAD SHOULD BE PULLING THE BOBBIN THREAD UPWARDS. IF THE HOOK DIDN'T "HOOK" THE NEEDLE THREAD THE PROBLEM IS THE DISTANCE OF THE NEEDLE AND HOOK APART OR THE TIMING. YOU MAY TRY TO MOVE THE NEEDLE TO THE LEFT SIDE AND AGAIN TRY ROTATING THE HAND WHEEL. IF IT DOESN'T WORK THEN TRY TO MOVE THE NEEDLE ALL THE WAY TO THE RIGHT AND ROTATE THE HAND WHEEL. IF IT BRINGS THE BOBBIN THREAD UPWARDS IN EITHER CASE IT WILL SHOW A PROBLEM WITH TIMING. THIS WILL NEED TO BE ADJUSTED BY A PROFESSIONAL.
6. REMEMBER TO PUT ONE DROP OF OIL ON THE RACE TRACK BEFORE YOU PUT THE BOBBIN CARRIER IN.
Jan 13, 2015 | Singer HD-110 Mechanical Sewing Machine
Needle is stalled
try rethreading the machine top and bobbin
also try a new needle
make sure that the top thread has not come off the top thread takeup
lever
clean under the needle plate and in the bobbin area for lint
Nov 30, 2012 | Brother PE770 Computerized Sewing Machine
My Singer 5050 sewing machine won't let me
sounds like a part is damaged or jamed, the machine needs to be checked
to see what's wrong with it
Apr 14, 2012 | Singer Sewing Machines
My mother has a bernina 1008 and now that we have taken the bobbin casing out to clean it won't catch when threaded. Any ideas?
Are you threading the bobbin case correctly - the bobbin should rotate clockwise when pulling the thread out under the tension spring. Are you ensuring that the bobbin case is firmly clicked back into position when replacing it. Check your needle is OK. Did you remove the hook from the hook race when cleaning out - have you oiled the hook race ?
Jan 22, 2012 | Bernina Sewing Machines
Skipped stitches. Also, won't transition
have you checked the needle to make sure it's in correctly--flat side of needle goes to the back of the machine
correct needle insertion is mandatory for the proper use in your sewing machine. Raise the needle bar to the highest point, then loosen the needle clamp screw to remove the old needle.
place the new needle in the needle clamp with the flat side of the needle facing the back (or if using a round needle the groove in the needle should be facing away from the shaft.
push the needle all the way up to the stop, or as far as it will go, then tighten the needle clamp screw.
how to decide which needle is correct to sew with, it depends on the fabric & thread being used for the project.
like for example, I've been sewing for over 30 years, I'm sewing a stretchy fabric & regular needles won't work because they skip stitches & will pull the fabric thus damaging the fabric, the needle I have to use is a singer universal ball point needles, & I have no problem with the stitches they come out fine.
Sep 10, 2011 | Brother XL-2600
Not quite sure, but, cannot get bobbin thread to catch with upper thread. the bobbin casing doesn't rotate to catch upper thread from needle
First please double check that the flywheel clutch in engaged and not in bobbin winding mode, ie the inner knob is locked by holding outer flywheel and turning inner wheel away from you.
If you remove the needle plate and bobbin cover and turn the flywheel manually can you see the hook rotating at all?
If the needle is going up and down and the rotary hook is not rotating, then my guess will be that the pinon gear down in the free arm area has failed and will need to be replaced. You don't say what model but if it is a star series you should be able to remove the top plate on the free arm by undoing one screw and exposing this area to confirm this. If its a Stella or Lotus it won't be so easy to view. Either way, if its a Swiss made Elna parts are still available and there are serviceman around who can do this repair. If you are in the USA I would suggest you browse www.whitesewingcenter for parts/repair info on Swiss Elnas.
Or try www.sewingpartsonline.com and search by your model number to see the parts available.
May 16, 2011 | Elna Sewing Machines
A friend gave me a Singer Tiny tailor 700 Mending machine recently. The lower thread is not coming up when the needle goes up and down. I referred to the manual. But it is not of much help. Please help me...
make sure your bobbin is threaded correctly from the spool and through the eyelet. with 4 or 5 inches of thread coming out of the bobbin and install the bobbin. Then, hold onto the end of the thread that is threaded through the needle while you manually rotate the spinner allowing the needle to drop all the way down and backup again . If everything is right, your needle thread will come up with the bobbin thread as you slowly pull on the needle thread and rotating the spinner . Make sure you rotate the spinner wheel the same direction it normally rotates while running .
Oct 23, 2010 | Singer Tiny Tailor TT700
I am not sure if I have a 226R-1 or R-2, my machine just says 226. I broke a needle and since then my machine skips stitches. Please advise how to fix. It only skips on vinyl, not cloth.
Could be the incorrect needle for the machine. Also, vinyl is difficult to sew because its "stickiness" characteristic tends to grab and hold the thread during the stitching process and is more likely to cause skipped stitches. Look for a needle with a large groove to shield the thread from the fabric--perhaps a topstitch needle or even a leather needle.
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&ved=0ahUKEwjHsbHCp9LMAhVDw4MKHUhpCiEQFggjMAE&url=http%3A%2F%2Fwww.schmetzneedles.com%2Flearning%2Fpdf%2Fschmetz-needle-chart.pdf&usg=AFQjCNHTR52AmqwzvyCjbXmD5Ch52Va5_Q&cad=rja
All About Needles
Tips and Techniques for Sewing with Oil Cloth Vinyl Laminated Cotton
Oct 10, 2010 | Consew 226R-1
Kenmore sewing machine older model 1345381
hi! there wind thread on bobbins winder 4 times by your hand rotate clockwise,insert in shaft bobiins winder on top of your machine near hand wheel push latch to engage loop thread on disc winder tension start your machine on pedal foot automatically winder disengage if already filled up of thead pull this winder and insert to bobbins casing insert thread to slot and pull out winder 6411c87.jpgshould rotate clockwise as shown.insert on shuttle hook casing and close cover needle plate.next thread your upper
97b52e8.jpgthreading tension as shown on red threading from spool pull threading and loop to dial tension threading and insert thread to lever needle and to needle hole tip. pull tread under the needle foot and feeder tooth.rotate hand wheel counter clockwise to hook up thread bobbibs and appear at top of needle plate,teo thread shoul appear,set dial tension to # 3 and stich to # 8 range to # 12 depend on fabric and layer of fabrics and set on straight stich sewing,let needle on upper position insert fabric for trial sewiing.put down foot needle lever. manually by hand rotate for assurance needle is free to sew if obtruction on loop bobbins thread occurs adjust all tension gradually then try again until free from sewing w/o problem star sewing.
Aug 08, 2008 | Kenmore Drop-In Bobbin 505S-21BH...
Euro-Pro 9125 Computerized Sewing Machine Logo
19 people viewed this question
Top Euro-Pro Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
