Question about Little Giant 2-MDQX-SC Inline Pump
I am getting a lot of vibration from my pump
The vibration noises are not consistant but occur frequent enough that I find very annoying. The pump would vibrate for 1 minute, stop for like 10 seconds and the continue to vibrate again. The vibration is loud enough that I can hear it from the second floor of my house. The aquarium is on thje first floor.
I've oiled the pump but the loud vibration still cycles through. The motor also feels hot to the touch which I am not sure if it is normal or not.
Please advise.
  • 634 Answers
There is a bad bearing inside that has worn out and causes vibration and excess heat, when it frees up it will spin quiet for a little then bind and vibrate again. need to replace bearing.
Posted on Jul 17, 2009
Fuel pump
The fuel pump module contains the fuel pump and the fuel tank level sender for the guage and all the connections for it and the cap. The noises that you hear are the pump working and it is most likely because it is vibrating. This a common occurance and is annoying. There is very little chance that it is an idication of a failure that is coming. During manufacturing there is supposed to be a vibration damper that is installed to keep the pump vibration from transmitting to the hard fuel lines. Your pump might not have had that.
Mar 07, 2014 | 2006 Chevrolet Cobalt
ARS2665AC - Every 3 minutes noise
Unless this is somthing to with the ice maker, it is likely to be the refrigeration pump cycling on and off. It is possible that the pump is being stalled upon start up. Another possibility is that the pump vibrates more as the pressure is being built up and perhaps one of the rubber mountings has worn or perished. As long as the fridge is still working properly as you say then this should not be a cause for concern unless it becomes annoying. Regards
Oct 02, 2007 | Amana ARS2661B Side by Side Refrigerator
Disc brake noise during cold weather
unfortunately if the truck is equipped with ceramic pads.... well there is the draw back, its a trade off.. like a semi truck, most of them are noisey coming to a stop. lots of weight with a lot of friction causes a vibration thats annoying.SO 1) You could opt for softer material in the brake pads, which would directly relate to a more frequent pad change, but the noise will be gone, and 2) you could try to drive a little ways at about 35 mph and just REST your foot on the brake pad for approximately 1/4 mile then come GENTLY to a stop. procedeure called burnishing.2 times should be plenty, and give the brakes a chance to cool beore the second burnish,( about 3 to 4 mins of cool time) let me know what happens, and good luck!
Dec 13, 2011 | 1995 Toyota T100 Xtracab
Vibrating noise by fuel tank in 1999 silverado
check for an exhaust leak or something loose onthe exhaust heat changes these things alot check it cold
Dec 07, 2011 | 1999 Chevrolet Silverado 1500
We just had a new top-load Maytag Washer delivered. When the man finished installing it, he started a wash cycle and left. When it got to the spin cycle there was a lot of vibration. It doesn't...
NO. Have you checked if he installed an anti vibration pads. This is because the high frequency vibrations caused by the spin cycle can cause annoying noise and very serious long term structural damage to you home.
Jan 12, 2011 | Maytag Bravos MTW6600T Top Load Washer
When installing a pump, does it need to be bolted to the pad? Aren't most pads today styrofoam?
No they do not. It may vibrate and run with some noise if it is not tight to the ground but other than perhaps being annoying, the noise wont hurt anything.
Aug 09, 2009 | Hayward 1.5hp Max Flo Inground Pool Pump #...
My black and decker water cooler makes noise like its boiling water which I know it does but it's much more pronouced and more frequent than before.
Slight boiling noise aside, a loud and unbearable rattling noise plagued my B&D Hot and Cold Water Cooler (top load). DIY Solution: The issue was some sort of copper coil vibrating against the front panel cover (just behind where you would place a glass. This copper colored coil is attached a canister looking thingy ma-bob, with a long black arm that is runs to the bottom right of the back cover. By removing all four screws on the back cover, you may angle (bottom out) the cover enough to gain access to this arm. GENTLY... lift the arm/rod so that the copper coil is no longer touching the front panel (and thus it is free to vibrate without that annoying noise). CAUTION: unplug the unit and ground yourself to avoid shock. Once you can see the coil is no longer touching, plug-er back in and see if the noise has stopped. Perform above at own risk.!!!!!
Aug 01, 2009 | Whynter FX-6SW Free Standing Hot & Cold...
1999 escort 5 sp manual trans. had vibration
IF GEAR SHIFT SHAKES THEN THE TRANSMISSION MOUNTS COULD BE BAD. HOPE THIS HELPS. GOOD LUCK
May 01, 2009 | 1993 Dodge Shadow
80 Series top loader excessive vibration and noise on spin
check the screw feet, on the front corners, one may be not screwed down far enough to be 'tight' to the floor allowing a small movement that makes a lot of noise, halting under pressure suggests this is the case
May 26, 2008 | Kenmore 24032\24036 Top Load Washer
Little Giant 2-MDQX-SC Inline Pump Logo
269 people viewed this question
Top Little Giant Garden Experts
Jim Goldsmith
Jim Goldsmith
Mike Squire
john h
Are you a Little Giant Garden Expert? Answer questions, earn points and help others
