Question about Toshiba gigabeat S MP3 Player
Gigabeat screan read contact manufacturer fo repair
I unscrewed my toshiba gigabeat s and took the battery out. When i put the battery back in put the cover back on and turned it on a screen with the message contact manufacturer for repair appeared.
  • enetterwald Jul 11, 2008
    the screen went white and stopped working could the battery be bad it also said contact repair dept
  • Anonymous Oct 01, 2008
    my gigabeat just decided to stop working and when i turn it on the same message comes up. this happened about a month ago but somehow i managed to get it working again. i've tried the same methods as before but the gigabeat just will not work.
    Problem Solver:
  • 12 Answers
You've either got the wrong battery or did something wrong when you installed it. You must make sure that the main power switch at the bottom is turned off.
Posted on Dec 10, 2007
Toshiba Gigabeat Touch Controls broken - need to transfer music to iPod
remove front cover on Gigabeat F40, remove battery. on back of battery a spacers remove those and replace with thinner spacers. I used hi quality insulation tape three layers of and stick back onto battery. Install battery again and it will have fixed the problem. Did it with mine
Jun 15, 2012 | Toshiba Gigabeat F40 40 GB MP3 Player
When I turn on my gigabeat it shows a picture of a box and a store and says underneath contact manufacturer for repair HELP!!!
I had that same problem before. My gbeat is working fine now after I followed instructions here:
http://www.rockbox.org/wiki/GigabeatSInfo
Read through the link under in Gigabeat S Code Injection Tool. You should be able to dl there the recovery firmware.
Sep 20, 2010 | Toshiba gigabeat MES60VK Digital Media...
My gigabeat f40 will not turn on, also it will not charge
I don't know if you still have this problem, but it could be possible that your battery is worn out. I remember reading this in the manual a long time ago. You'll have to contact toshiba itself and get yourself a new battery.
Jun 12, 2010 | Toshiba Gigabeat MEGF40S MP3 Player
MES60V suddenly stopped charging.
Download, and install the firmware. It should work after that. It might of formatted the storage partition of the device, but you can resync it after you update the firmware on the device. You can get the firmware here: Gigabeat S Firmware.
Jun 17, 2008 | Toshiba gigabeat MES60VK Digital Media...
Will not turn own it reads contact manufacturer for repair.
The hard drive became disconnected. I took out all of the screws to the outer case (5), gently slid cover down until the small ribbon connector for the power buttons is exposed, unclip and remove. Set aside back of unit (at this point the hard drive might come with it if the ribbon has come out of the back) at the top there is a two screw metal bracket that covers the ribbon connection for the hard drive. Remove the ribbon from the main unit and gently force it back into the hard drive ribbon connector. once fully seated you can reinsert the other end, replace the two screw bracket in a way that holds the ribbon down. Slide the backing back far enough to reinsert the power buttons ribbon connector and then test it before you throw in those last 5 screws.
Jun 06, 2008 | Toshiba gigabeat S MP3 Player
Frozen
i'm thinking the hard drive is messing up... you know when i dropped my gigabeat S30 it wasn't working n it was freezing and the video files weren't playing at all. it would freeze when i turn on or play video. then i turned it off and then back on using the battery switch. it said "contact the manufacturer for repair" with a yield sign. i really thought i killed it...but i still had my hopes high to fix it myself somehow n i really thought it was from the hard drive. so i took it in my hand and gave it a shake on my palm. like i actually hit it on my palm for once n then i turned it on and it worked =D fineee.... i was so happy n now it still works fine ;)
i hope that helps
May 26, 2008 | Toshiba gigabeat S MP3 Player
Toshiba gigabeat MES30VW
i hope that helps
May 26, 2008 | Toshiba Gigabeat S30 MP3 Player
Gigabeat blank
that's an indication that the media center program has loaded but frozen at a certain point [blue screen] before fully loading.
indicates a hard drive problem... prolly the head can't read the hard drive...did you drop it?
cuz when i dropped it...that happened to me...it froze on the menu...then i used the battery button to turn on n off..till i got the "contact the manufacturer for repair" with a yield sign message. i really thought i killed it...but i still had my hopes high to fix it myself somehow n i really thought it was from the hard drive. so i took it in my hand and gave it a shake on my palm. like i actually hit it on my palm for once n then i turned it on and it worked =D fineee.... i was so happy n now it still works fine ;)
i hope that helps
May 03, 2008 | Toshiba Gigabeat S30 MP3 Player
Gigabeat froze -_-
sound like the hard drive connection came apart.(wire came off of the board or the drive) you will have to open it up to fix it.
Feb 11, 2007 | Toshiba gigabeat S MP3 Player
Toshiba gigabeat S MP3 Player Logo
414 people viewed this question
Top Toshiba Audio Players & Recorders Experts
James DuPont Jr
James DuPont Jr
 Grubhead
Grubhead
Are you a Toshiba Audio Player and Recorder Expert? Answer questions, earn points and help others
