Question about Simplicity Garden
Engine fires but runs out of gas - Simplicity Garden
THE ENGINE WAS OVERHAUL AFTER THAT IT FAILING TO START JUST CRANKING BUT PROMISING ,THE SPARK IS THERE WHY PUTTING MORE FUEL ON THE PLUGS
Did you check for spark at more than one or two spark plugs? The spark is there, and the spark plugs are wet with gas? Is it flooded? Or is it getting too much gas? For a flooded engine, you know to open the intake valve wide open by holding the gas pedal to the floor, and cranking for up to 15 seconds? This will let a lot of air in and clear out most of the excess gas. Or have you tried this already?
Spark, gas, and compression: that is all that the cylinders need to run. In a well-timed engine, that is. A little gas/air mixture, then compression, then a spark is delivered and it runs. One of those three things is not right or missing for your engine not to start. Or you will have to recheck timing.
Jan 13, 2015 | Cars & Trucks
Engine miss fires at higher RPM
check for water in gas run additve seafoam in gas this stuff works will clean carb and dry water in gas and decarbonize engine it does it all i use all the time in shop
Sep 04, 2014 | Garden
Ignition stop firing/engine floods w/ gas
Check for loose connections on your ignition system, mainly around the coil.
Jan 07, 2013 | 1993 Pontiac Sunbird
2003 Santa Fe V 6 miss firing with New plugs and wires
Got a check engine light? Get the codes read to find out if the misfires are on all cylinders or just 1. Could be ign coil, bad crank or cam sensor, or a valve issue
Jan 27, 2018 | 2003 Hyundai Santa Fe GLS
The engine won't run. fire and gas is good the engine only cranks.
If fire (ignition) and gas (fuel) is good, then you either have a distributor that is totally out of time or you have severe engine damage or wear. If you have proper ignition, fuel, timing and compression, the engine will run. One of these things is missing.
Jan 24, 2011 | 1998 Toyota Corolla
I have a cadallic escadale. It will turn over but wont start.
The fuel pressure should be 60 to 65psi in your system with the engine not running and fuel line primed, (ignition key's to the run position). Once engine is running the fuel pressure should drop by 5psi, change the fuel filter and recheck the fuel pressure at the shredder valve. it's known for the fuel pump to fail when the gas tank runs low or out of gas, the pump will end up burning it self out since the gas is what keeps the electric fuel pump cooled. The other thing to is putting gas through the top of the throttle body to start the engine on the SEFI is a NO NO, well a BIG NO NO. it's been know for the gas in the intake to catch fire and burn up the poppet valve in the injection system causing the replacement of the fuel injection system. Keep me posted and good luck, be gald to help you get your truck running again for the july 4th. OH and it was not mentioned but did the fuel filter get replaced???
Jul 01, 2009 | 2000 Cadillac Escalade
Garden Logo
19 people viewed this question
Top Simplicity Garden Experts
Dennis Key
Dennis Key
dannydoesita
ray gallant
Are you a Simplicity Garden Expert? Answer questions, earn points and help others
