Question about Parat 1:32 Scale Diecast Replica: 1920 Ford Model T Cargo Truck
Hydraulics hesitates when raised and lowers slowly
Hydraulic loader hesitates when raised and lowers slowly
Loader stuck in down position, the joy stick will not raise or lower loader. The joy stick will work the tilt movme
didnt specify type of machine( generic answer)some machines have an electrical assist joy stick check switchs if hydraulic check the r check fluid level in the hydraulics the tilt uses less fluid to the piston than the lift arms ----check the hydro lines and connections doesnt happen all the time but try bleeding lift lines air or debris in lines
Sep 15, 2015 | Cars & Trucks
I have a te20 tractor and the 3point hitch won't lift or go down . why ?
The hydraulic control valve for the hitch is not opening correctly, take it apart and clean it
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Aug 31, 2014 | RTO Massey-Ferguson Tractor TE20, TO20,...
How to change motor mount
if you don't have an engine hoist you'll need a couple of hydraulic jacks. loosen the bolt that bolt the engine to the mounts. then raise the engine with the hydraulic jacks. once you have just enough clearance to get your hands and tools into the bad mount remove it. put in the new one. slowly lower the engine back into place with your hydraulic jacks and tighten then engine back down to the motor mount. be careful the engine doesn't shift while it's suspended on the jacks one it's dangerous and 2 it will make it harder to realign the engine when your lowering it back onto the mounts
Jul 16, 2012 | 2002 Chevrolet TrailBlazer
Top worked fine yesterday but today tried to let down only clicked
It is a hydraulic pump that applies pressure to the 2 hydraulic pistons to raise & lower the top. So, check for something obstructing movement first.
The convertible top:
  • is motor-driven.
  • requires parking brake engaged to complete circuit for operation.
  • is equipped with a back window glass (42006) . The back window glass is permanently attached to the folding top back window curtain (52500) and cannot be opened.
VISUAL INSPECTION CHART Mechanical Electrical
  • Damaged fluid reservoir.
  • Damaged folding top hydraulic cylinders .
  • Damaged folding top motor upper and lower hose .
  • Damaged convertible top regulator.
  • Parking brake not engaged.
  • Open power distribution box circuit breaker CONV TOP (30A), fuse junction panel Fuse 1 (15A).
  • Circuitry open/shorted.
  • Damaged convertible top switch.
  • Damaged raise/lower relay .
  • Damaged folding top hydraulic lift motor and plate kit .
  • Convertible Top Does Not Raise/Lower
  • Open circuit breaker or fuse.
  • Damaged folding top switch.
Jun 29, 2011 | 1998 Ford Mustang
Ford TRactor 1710 hydraulic problem
raise front loader....loosen hyd. line a little lower loader till all air is released and only fluid is coming out and retighten.....its like bleedig brakes on a car
Nov 16, 2009 | Plumbing
IJohn Deere whinning noise
Is the device that lowers or raises the loader a hydraulic piston type device, or more of a hydrostatic type device? Whining noises are not uncommon with hydrostatic devices...
Mar 26, 2009 | Garden
Convertible top
here's some info
Symptom Chart Condition Possible Source Action
  • Folding Top Does Not Raise and/or Lower
  • Blown fuse(s).
  • Go to Pinpoint Test A.
  • Top Hesitates and/or Comes Up Uneven
  • Damaged folding top hydraulic cylinder .
  • Damaged folding top linkage.
  • Go to Pinpoint Test B.
  • Top Does Not Raise or Does Not Go All the Way Up
  • Go to Pinpoint Test C.
  • Hydraulic System
  • Go to Pinpoint Test D.
Lift Cylinder, Power Top Removal and Installation
NOTE: The cylinder rods should be in the fully-retracted position.
  1. Remove pump and motor as outlined.
  1. Remove the upper and lower hose fitting from the folding top hydraulic cylinder (50600) . Use absorbent rags or a container to catch any hydraulic fluid that leaks out when removing the fittings.
  1. Remove each of the service cylinder plugs one at a time and attach the hose fittings. NOTE: Be sure each fitting is installed in the correct position on the folding top hydraulic cylinder .
    NOTE: Make sure that the tetra seal is installed in the bottom of each of the folding top hydraulic cylinder ports before attaching the upper and lower hose fittings.
  1. Connect the folding top hydraulic lift motor and plate kit (533A00) to a 12-volt power source and cycle the folding top hydraulic lift motor and plate kit in and out several times to purge the air from the hoses. Some noise squeal may be noticed due to the air.
  1. Carefully remove the rubber fill plug from the back and the reservoir and check the fluid level. The level should be at the bottom of the filler hole. If necessary, add Synthetic Mercon® Multi-Purpose Automatic transmission fluid E6AZ-19582-B (ESR-M2C163-A2) or equivalent.
  1. Replace the fill plug with a new fill plug.
  1. To install, reverse Removal procedure.
Jan 04, 2009 | 1989 Ford Mustang
Parat 1:32 Scale Diecast Replica: 1920 Ford Model T Cargo Truck Logo
Top Parat Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Parat Toy Expert? Answer questions, earn points and help others
