Question about RCA E13309 13-Inch Diagonal XL-100 Color Television Television
Wii wont display on tv input - RCA E13309 13-Inch Diagonal XL-100 Color Television Television
Wii will not display but has power, will eject disk, and has light.
if it doesn't display picture try putting your TV on channel 2 or input
Apr 17, 2013 | Nintendo Wii Console
My wii when i turn it on it only has lines going across the screen.. about a week back it was saying something about the memory. now it wont load the wii menu nor will it load any games... if anyone knows...
Picture Is Black and White or Does Not Appear
Situation:
The console powers on and shows a black and white image on the television screen
The console powers on and there is no image on the television
What to do:
Determine whether the Standard AV Cables (packaged with the system) or the Component Cables (sold separately) are being used.
AV Cables
Ensure the yellow, red, and white cables are connected to the correct corresponding inputs on the TV. (How To)
Try another set of inputs on the TV, or hooking the Wii console up to another TV.
If the TV does not have the yellow, red and white inputs, it will most likely have component inputs which allow standard AV cable use. Try these AV hookup steps. (How To)
Component Cables
Ensure the red, blue and green video cables are connected to the correct corresponding inputs on the TV. (How To)
Still Not Resolved:
If the television is continues to show a black and white image when powering on the Wii console, then the problem is likely with the system and it will need to be repaired. Please call 1-800-255-3700 so that we may assist you further.
Was this information helpful?
Nov 02, 2012 | Nintendo Wii Console
I have a 1998 zenith color tv and i want to attach a wii. I plugged the video cords to the inputs and turned the wii on and the tv on to aux The wii does not display on the tv. Please...
Are you SURE that you have the wii plugged into the inputs of the tv - red to red, white to white and yellow to yellow? (You would be surprised how many people plug them into the output rca plugs.) Are you SURE that you have the correct aux selection - many tvs of that timeframe have two: a front and a rear. If your wii cable works on another tv (try it if you don't know), then my guess is that your tv is not working right. You could try using an rf converter to plug it into the rf connector (threaded) of the tv and run the tv on ch 3 or 4.
Nov 30, 2010 | Televison & Video
Wii help
Hello :
1:Insert the AV Multi Out plug on the Wii AV Cable into the AV Multi Out connector on the back of the console.
2:
Insert the RCA plugs on the Wii AV Cable into the input connectors on the TV. Plug the colored connectors into the following inputs:
Yellow = Video Input
White = Audio Input Left (or Mono)
Red = Audio Input Right
3:Once the cables are inserted and the Wii is powered on, you must find the Input Select for your TV to view the game (it is likely not going to be seen on Channel 3 or 4). Typically this is found by pressing the TV/Video button on the Television's front panel or remote control. If you have more than one input channel, keep pressing TV/Video until you see the display from the Wii.
If you do not have a TV/Video button, then the input could be labeled something different. Some other common input selects to look for on the TV or remote are: Input, Input Select, EXT, AUX, or a channel such as 00 or 99.
I hope this will help .
Mar 23, 2010 | Nintendo Wii Console
Bush LCD tv wont allow Wii to be tuned thru AV
Hi, the av lead with the three connectors at the end make sure you have them connected correctly -
Yellow - Video
White - Left Audio
Red - Right Audio
It's a simple mistake to make , but check it.
Let me know - Anthony
Feb 10, 2010 | Televison & Video
Not able to get the Wii to play on my TV
im not able to get the wii to play on my tv. is there a code i need for my remote controll
Dec 25, 2009 | Nintendo Wii Console
Bought a Wii and using the standard cables it played great on a new 50' Panasonic Plasma as well as on our 2 year old 32' VIZIO LCD. Just upgraded to a 46' Sony LCD (W series) and the Wii looks terrible...
The Wii can display on a HDTV, but keep in mind the output is only 480p. It is not true high definition, and it will only display this using a component video cable. There shouldn't be a difference with LCD and plasma.
You will also need to go to the display settings to force the Wii to display in 480p.
Try a different input (safe to assume your Sony has multiple?) and see if it is that specific input. Also, try a different device like a DVD player or VCR and see if you get the same result.
Good luck.
Dec 07, 2009 | Nintendo Wii Console
Installed a Wii to YPbPr1 port. display is B&W, no color. How do I get the display in color?
Unless the Wii is sending the video signal in component form, you have a case where the signals are not compatible. The Wii is sending "composite" and the TV is expecting component. With the composite signal the Y input, the result will be a B&W picture. Either set the Wii to send component or connect it to the composite input on the TV.
Dan
May 12, 2009 | Televison & Video
Nintendo wii wont work with older model of Sanyo TV
how are you connecting the wii to the tv...through the rca jacks?  If so, you can not get to the input channels by the channel button.  On the remote there will be a button called either AV, Input, AV Video, Video, A/V, Input or something similar.  Hit this button until your tv goes to the appropriate av channel.
Mar 07, 2009 | Nintendo Wii Console
RCA E13309 13-Inch Diagonal XL-100 Color Television Television Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
