Question about Dishwashers
Not coming out dry - Dishwashers
KitchenAid kdte104dss0 is not drying properly. No steam comes out of side vent. Not sure if there should be steam coming out? It seems to dry somewhat but not completely.
is there any heat coming out of the dryer? If the heating system is not working the dryer will only blow room temp. air and will not dry the cloths.
Aug 02, 2015 | Dryers
In what kind of containers do freeze dried food come in?
Freeze-dried food come in convenient containers like plastic buckets, #10 cans, and pouches.
Aug 12, 2012 | Camping, Backpacking & Hiking
Does freeze dried coffee come in different types?
Sure, just like regular coffee, you can find both caffeinated and decaffeinated freeze dried coffee. Also, freeze dried coffee comes in different flavors just like regular coffee.
How do you dry on this machine? if you dry on the green, does it completely dry?
The automatic preheat and drying cycle kicks in as the final wash spin is under- way. The system employs a condenser dryer in which the hot air used to dry the clothes is channeled into a drum, instead of being released into the great outdoors via a dry vent hose. Cold water is drawn into the drum at the same time. The two mix, and the result is a condensing process.
The chlothes should be dry. there may be a damp feeling to them but otherwise dry. If your machine is not drying then the element could be going bad, or a thermal cutoff. those would be the easyiest fixes.
The BIG drawback is drying. It takes about 90 minutes to dry a load, and the clothes come out very wrinkled. Because the drum is so small, the clothes don't 'toss' in heated air and don't fluff at all. Clothes also come out stiffer than a regular dryer.
Jan 06, 2011 | Equator EZ 1500 Front Load Washer / Dryer
My tumble dryer is spinning and everything but my clothes are coming out cold and half dry, how can i solve this?
Clean the vent and make sure you have good air flow to the outside . You can disconnect the vent from the dryer and dry a load of clothes . Comes out dry , vent is the problem .
Jul 30, 2009 | Dryers
Jenn-Air JDB8910 dishwasher moisture coming out left side.
thats a vent fan to help with drying cycle its normal for steam to come out during cycle of drying you might use no heat air dry and turn your jet dry disp up but its a normal part of drying cycle
Feb 11, 2009 | Jenn-Air 24 in. JDB8910 Built-in...
Does not heat
"Steam drying will get how but the air that comes later to actually dry is cold so the clothes never dry"
I am assuming "how" means hot in this sentence, if so, I think I can help! There is no "steam drying" phase for your dryer so what is probably happening is; the wet clothes are being heated properly [as a result causing steam] however if this steam does not escape frum the dryer it will simply condense back onto the clothing [leaving them moist/wet].
Check your flexible tube from the dryer and the vent on the outside of your home to make sure they are unobstructed. Hope this helps!
Oct 13, 2008 | LG DLE2514 Electric Dryer
All electronic working but dryer will not turn on to dry
if you think you here the motor come on real lightly you have probly broken a belt the motor is turning but not turn the drum because the belt is broken
May 08, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Doesnt dry dishes
The heater on this unit only comes on twice, once in the wash cycle, and again in the Sanitary rinse. During the drying cycle all that happens is a vent opens and a fan comes on. The fan removes the hot moist air from the unit and the dishes dry off. If your water is not hot enough, this is why your dishes are still wet. Rinse aid also helps to sheen off the excess water as well.
Sgt 48
May 06, 2008 | LG 24 in. LDF7810 Built-in Dishwasher
My indesit widl126s
my washer works fine but the dryer wont heat up or dry the clothes it goes onto dry but all the clothes are still coming out wet and the drum is cold
Apr 01, 2008 | Washing Machines
Dishwashers Logo
12 people viewed this question
Top Dishwashers Experts
Owen Barnes
