Question about Sta Rite Sr200na - Max E Therm - Pool & Spa Heater - Dual Electronic Iginition Lo - Nox - 200,000 Btu - Natural Gas
The sta-rite maxitherm heater I am asking about is for an inground pool
  • gherib Jul 10, 2009
    I have a sta-rite maxitherm heater, I replaced the HSI and it still would not fire, I turned off all power to the system, turned it back on, it tried to fire then stopped, and now nothing is being powered up, there is 120 volts going to the system.
    thx for help
  • Delita Foltz May 11, 2010
    What do you need to know about the heater?
  • 83 Answers
I would like you to try a reset of the system. Turn off the power on the heater, then turn off the circuit breaker that goes with the heater. Wait about 20 minutes and then try and start the heater. If it still will not power up, turn the display panel over, there are diagnostic lights on the back side. If the light is on next to the AFS, that is the Air Flow Switch.
Posted on Jul 10, 2009
How do i set up the hoses on the BHR170 pump?
front of pump goes to skimmers and main drain if inground pool skimmer if above ground top goes to inlet of filter then outlet of filter goes to pool returns
Jun 01, 2014 | Sta Rite Sta - Rite 24" Sand Filter & 1 Hp...
BHR170 hose set up
in form skimmers out to filter in to out of filter to returns
I have a pentair master temp 400 that is 3 years old. It is turning on by itself when the pool timers kick on. The temperature changes from say 54 degrees to 240 degrees. When changed from pool settings...
You heater has brain damage. I wish I had better info for you but this heater has been a consistent source of aggravation for pool techs.
Sta-Rite, a division of Pentair acquired about 12 years ago, manufactured the heater under the name MaxiTherm (and still does).
Pentair decided to make their own version of it and unfortunately they are hard to keep running. I don't know what they tweaked but they managed to wreck one of the best heater designs out there.
A tech can come out and change the malfunctioning parts but it won't be cheap, and very likely will have to service it again within a relatively short period of time.
I'd advise to get in contact with your local Pentair rep and see if you can get any credit toward the Sta-Rite version. For what these things cost you have to demand better performance.
Jan 15, 2014 | Pool & Spa
3 hp hot tub motor Sta-Rite tub has two speed low for filtering and high for jets low starts and then stops high speed works fine
make sure you make a wiring diagram or just unplug the plug from the mother board and search your area for your local pool pump repair guy with free testing. these are a high $$$ motor and not a good one to practice on, save it for a pro ! it might just be a dirty switch or need to be reset I don't charge any thing for that, and while your there ask him how to take better care of your $$$ pump ?
jay the pool pump repair guy longwood Florida
Sep 05, 2012 | Sta Rite Sta - Rite 1hp Dura - Glas...
How to replace motor
if you have the motor I recommend you have a pro do it. search your area for you're local pool pump motor repair service. cost should be around $20.00 this way its done right and protects the motor from getting damaged. ask them how to take better care of your pump and motor, that's the best pump you can get. sta rite dura glas
Prime the pump after any repair
Jay the pool pump reapair guy in longwood Florida 32750
Mar 12, 2012 | Sta Rite Sta - Rite 1hp Dura - Glas...
I have a sta-rite inground pool heater Therm-max and it's showing one light blinking which indicates AFS problem? However, I tried changing the AFS and still (Service Heater stays on light Blower...
You should not have any gas at the union until the heater tries to fire. The Air Flow Switch circuit should have 24 volts at the switch and should be tested. If the voltage is not correct then more trouble shooting will need to be done.
Jul 23, 2017 | Sta Rite StaRite 400000 BTU Heavy Duty...
Sta-rite problem
Pump is heating up and kicking the breaker try cleaning the pump filter and let me know by posting to this solution.
Sep 29, 2009 | Sta Rite Sta - Rite 1hp Dura - Glas...
Pool in off mode but pump keeps running.
Replace filter pump relay if you have an automated system.if you have a timer it is not wired correctly
Sep 16, 2009 | Sta Rite Sta - Rite 2hp Max - E Pro...
Owners manaul for SR400NA
If you have not received an answer to this issue, you can find an Owner's Manual online at:
http://www.pentairpool.com/pdfs/MaxEThermOM.pdf
I hope this is helpful!
Jul 12, 2009 | Sta Rite Sr400na Max E Therm Pool & Spa...
I have a sta-rite maxitherm heater, that is not getting power
check for 24 volts after transformer.does fan come on?does ignitor glow?
Jun 18, 2009 | Heating & Cooling
Sta Rite Sr200na - Max E Therm - Pool & Spa Heater - Dual Electronic Iginition Lo - Nox - 200,000 Btu - Natural Gas Logo
306 people viewed this question
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
Oloyede Monsuru
john h
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
