Question about General International Masonry Tools
4 inch jointer - General International Masonry Tools
How do i set knifves in wards powr-kraft jointer mod.no. 2508a
Lower the in feed table to keep it clear of your work, hold a straight edge on the out feed table, both sides, adj the knives to just touch the straight edge, both sides the same, all knives set the same, should work like a charm, do not answer the phone while you are doing this. check all jib screws twice to make sure they are tight. Hope this helps.
Jan 28, 2012 | Delta Jointer Blades 6 Inch Fits , Jet...
Delta jointer, where do i find the wrench to loosen the nuts for the blade
go to Dewaltservicenet.com and with your model number you can download a schematic for this tool and also order the parts online. I tried finding them but there are too many jointers listed in the Delta category.
Apr 16, 2011 | Delta Jointer Blades 6 Inch Fits , Jet...
Eg2175need manual for craftsman 6inch jointer model number 113 20 680
Go to partsdirect.com and type in your model number. From there, you can order whatever you need for your jointer.
Feb 06, 2011 | Delta Jointer Blades 6 Inch Fits , Jet...
I need to find blades to fit a delta 6" X5 jointer, model 37-866x
go to Dewaltservicenet.com and under the service locator on the right hand side type in your information. The blade set number that I came up with is 37-658 and they show that as qty 3 in one package.
Mar 19, 2010 | Delta Jointer Blades 6 Inch Fits , Jet...
Outfeed table will not go back down after i raised it all the way up
Table may have disengaged from the threads---apply pressure on the table to reengage as you try to lower it
Feb 28, 2010 | Delta Jointer Blades 6 Inch Fits , Jet...
Need to find out haw to adjust cutter head and blades.
I called Jet and they e-mailed me a pdf file with the older manual. There is a toll free number on their website.
Jan 26, 2009 | Delta Jointer Blades 6 Inch Fits , Jet...
Masonry Jointer Usage
While the final effects of a stone or concrete wall are stunning, the work to make it beautiful is time-consuming and difficult. Tools are very important in masonry work. Having the right tools for a certain job make all the difference. Jointers come in many different sizes and shapes. Learn the various types and how to use them and you can make quick work of a difficult task. Use an e-jointer for narrower spaces between the stones. There is no handle on the e-jointer, making it easier to smooth and shape the joints between the stones. Whenever your hand is closer to the surface, you can exert more control. Get a bead jointer for raised masonry bricks. These jointers come in two sizes, 1/4-inch by 5/16-inch and 3/8-inch by 1/2-inch. They are small, strong, simple tools that can chip off the excess of a joint that is sticking up off the brink. You do not want to make a deep joint between raised bricks. Change your joint tool to a brick masonry mortar joint raker tool if you are making your project from rougher materials, such as adobe brick or split stone. This tool has many more grooves, which will fit in various sized joints. Turn it on the end for narrow joints and use the curved notch for more intricate patterns between the stones. Switch to a grapevine mortar jointer for very clean lines between the bricks. This tool is used primarily for a colonial look, which is even and measured. Your can get this jointer with a wooden handle for a more even grip.
Aug 27, 2008 | Delta Machinery Delta 37-658 Jointer...
Masonry Tools Logo
60 people viewed this question
Top General International Masonry Tools Experts
Tom Chichester
Are you a General International Masonry Tool Expert? Answer questions, earn points and help others
