Question about Sony Televison & Video
HOW TO OPEN REMOTE CASE THAT HAS NO SCREWS
HOW TO OPEN CASE THAT HAS NO SCREWS
How to install replacement battery on nevo q50 remote
Switch off with the main power switch. Remove the stylus. Remove the rubber feet. They prise out gently with a fine tipped flat blade screwdriver. Undo the two screws beneath. It should now be possible to use your nails to split the clamshell case. Start at the end that was screwed together. Work the case open as if it were hinged at the IR emitter end.
Sep 13, 2014 | HQRP Battery for NEVO Q50 Remote Control /...
Hi, My sony remote failed recently Model
There is some locks on its upper and lower case. You can locate it by its side slits.
Oct 06, 2013 | Televison & Video
How do I open toshiba ct-90287 case to dry buttons
I guess this is a remote control.
Remove the batteries and look around including inside the battery cover for any small screws.
Remove all screws - Even If there isn't any screws.
Next>
You need a fairly wide but thin flat bladed screwdriver to split the case. Place the blade of the screwdriver between the two casings of the remote control and gently twist the blade and the case will begin to split apart. work it loose - but don't foce it apart. Apply even pressure around the remote control with the blade of the screwdriver.
Once you have seperated the two halves - clean the rubber buttons with either Meths or Isopropyl Alcohol and also clean the circuit board with the same where the buttons make contact with the circuit board. Then reassemble. Your control should then be ok!
Jun 22, 2011 | Televison & Video
How do I remove the back of the remote control for a Sony TV? The model number is RM-ED002. I have located two small screws in the battery compartment but removing them doesn't seem to be enough to do the...
The two screws inside the battery compartment would not really hold the case together. Try using two flat screwdrivers working on the side of the remote control; one levered open a bit and the other slipped in further and levered more to split it open. I think a blunt knife may also do the job; but never a sharp one because it will be too dangerous.
Aug 22, 2010 | Sony RM-Y132 Remote Control
How to open remote control Sony RM-Y181
There should be small screws (usually phillips head) at either the top, bottom or both ends of the back of the remote. Unscrew those and pry loose. If not, they will be under the batteries, inside the battery cover.
I assume that's what you mean by open?
:D
Aug 10, 2009 | Televison & Video
Onkyo RC-649M remote
Remove any screws you can see and pry the case open. you will see a rubber pad and a circuit board. Clean both with alcohol and dry. reassemble and it should be OK
Jan 23, 2009 | Panasonic ET-RM100 Remote Control
Volume switch do not work properly
After you remove the 2 little black screws, must use a 'minus' (-) screwdriver. This screwdriver must be pushed between the 2 semi parts (shell) of the remote body and gently rotate until they get apart little by little. Must do this around the remote control body.Success!
Aug 26, 2008 | Sony RM-945 Remote Control
Opening the case of a JVC Remote Control
Not having seen that particular one, remote cases usually have a couple screws under the battery to lock the case together and then a number of plastic tabs around the perimiter that hold the joint closed. find the screws (sometimes they hide them under labels) - I don't know what it is about screws that manufacturers don't like to show. Either think they are not cosmetic or don't want us take-it-apart maniacs to get in. Anyway, get the screws loose then (this is the hard part) carefully pry open the case joint, feeling where and how the tabs snap out and then be careful not to have everything inside go flying when the last one lets loose. Almost impossible to not leave little gouge marks in the joint.
Hope Ya Fis It!
Jan 08, 2008 | JVC AV-27230 27" TV
Televison & Video Logo
16 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
