Question about Computar Cameras
Need power cord and wiire connections - Computar Cameras
I'm adding a tach to 02 super glide . Is there a connector in harness,if not where should wiires connect?
Hi, Anonymous the signal wire from the tach connects to the pink wire going to the ignition module the orange wire is power and the black wire is ground sorry you can not find the first and best tool you ever bought for your Harley despair not, for a mere $10 you can download another one. For more information about your issue and valuable free downloads that you will need please visit the websites below, and for specific information or questions, please feel free to contact me at xlch@mail.com. Good luck and have a nice day.
Harley Davidson Manuals Mark Workshop
http://www.stcharlesharleydavidson.com/OEMpartfinder.htm
Owner Manuals Harley Davidson USA
Instant Tech Relief only $6 a month
Feb 28, 2016 | Super Motorcycles
How to wire a plug
In USA, Either the male or female plug connector would be wired the same. Black is hot wire and would connect to the BRASS colored round head screw ( Smallest flat prong or slot ). White is the neutral wire and would connect to the SILVER colored round head screw ( Largest flat prong or slot ). Green is the ground wire and would connect to the GREEN screw ( ONLY HEX shaped screw ). 1) FOR YOUR LIFE SAFETY, ALWAYS USE 3-WIIRE PLUGS WHEN REPAIRING 3-WIRE EXTENSION CORDS! 2) Check the male plug connector. It should have two flat and one rounded prong. The rounded prong is the ground wire connection. If the ground prong is missing, replace the plug. 3) Inspect the outer cover for damage. 4) Do not use cords with damaged outer covers. Taping over the damage is not an adequate repair, for safety, replace the cord.
Apr 04, 2014 | Woods Industries 12/3X100FT Yellow Jacket...
Pc not booting, no fans spinning, nothing lights up. HALP
REWIRE THE ELECTRIC WIIRES.SHOULD THAT NOT HELP TRY WITH A OTHER PSU.
Dec 06, 2013 | Computers & Internet
Replaced stereo system in my 2000 sonata. When I turn off the ignition and restart it the stereo resets it self it has no memory.
you did not hook up the memory power wire, the factory wirring has two power wires a orange wire that is hot all the time and this is the one you hook to the memory circuit and there is a yellow wire that is hot with the key on this is the power supply wire for the unit it take both wiires to make the system work....
Sep 01, 2011 | 2000 Hyundai Sonata
Where the cord enters the rubber stress relief, the wiires are broken. If I wiggle it around, it comes back to life. Can you help?
stick it permantly with duck tape (personal experience) or get a new one, they are very cheap
Mar 07, 2011 | Computers & Internet
I need to convert my dryer from a 4-prong to a 3-prong power cord. I understand all steps of the installation except for the grounding wire. Since there are only three cords now I no longer have a...
On your cord, the outside leads are the hot leads, with each one carrying 120 volts. On a four wiire cord, the two inside lines are neutral and grounds. For a three wire cord to be used with four lugs, the middle wire connects to one of the middle lugs, and the inner lugs should be connected together, Normally, a drier comes with a bridging plate to connect the two lugs, and it is removed for a four wire cord, or left in place for a three wire cord. You can bridge the two terminals with a piece of substantial insulated wire. I have never tried to buy a bridging plate, but you might try Lowe's, etc. for one.
Best regards,
--W/D--
Jan 21, 2011 | Dryers
I tried to connect the mobile phone to external speakers by cutting the ear phone cable and then joining it with wiires of the external spaekers but it didn't work.Please suggest
pda phones comunicate wuiz speaker wuiz an rezistance 3ohmi paces in speakers from + too- i recomand bluetooth conect too pc audio is beter then theat
Nov 12, 2009 | HTC P3300 Smartphone
Digitech rp6
Try contacting their service center rep at (801)566-8800. They might send you a schematic for the pedal if you explain your situation. They do recommend using the original power supply PS0912 which should still be available. Hope this helps.
May 25, 2009 | DIGITECH VOCALIST LIVE 2
Need wiiring code for an Alan 9001 5 pin mic.
Here's a link to general info on the radio, including a pin out list for the mic connection:
http://www.cbradio.nl/alan/frames_midland_alan_9001.htm
Bill B.
San Antonio
Mar 29, 2009 | Radio Communications
Cameras Logo
23 people viewed this question
Top Computar Cameras Experts
Are you a Computar Camera Expert? Answer questions, earn points and help others
