Question about Asko D1796FI Built-in Dishwasher
D1796 starts, pumps out a little water, pumps in water until it just gets above the filter then stops. Not sure what the problem is.
The motor and filter seem to be ok, but can't get it to prime. Everything is working,just very little water pumping into filter.
It sounds like you have a suction leak or a clogged impeller. A quick way to check the impeller is to fill the pump pot (where the basket is) with water, then start the pump with the lid OFF. The water should be sucked down into the pump immediately. Turn the pump off. If it took more than about half a second for the water to disappear you need to open the pump and clear the debris from the impeller.
Otherwise any leak from the skimmer to the pump will cause the problem. Make sure your pump lid o-ring is lubricated.
Apr 05, 2013 | Pool & Spa
D1796 3-4 years old. Power on, lights flash, but when close door to start d/w, no noises made, water does not flow or anything. Water supply is on. Water valve to d/w open. Worked flawlessly until today.
here could be two problems...The drain could be clogged, or the water pump could be bad. Or the belt that runs the pump is sliping or broken. [edit] Steps
  1. Fill washer with water and wait for the timer to get to the drain mode.
  2. Unplug the washer from the electric outlet.
  3. Open the case, and disconnect the water hose from the outlet of the water pump.
  4. If you get water pouring out from the pump, then plug that up and check the hose to the sewer. If that is clogged, then you have found the problem.
  5. Some washers have a self cleaning filter in that hose somewhere. Check that to be sure it is working properly.
  6. Reassemble hose from step 3.
  7. Plug washer back in. If it pumps out now, then you are done. If it doesn't, then the water pump is probably defective, so replace it.
  8. Reassemble washing machine case...you're done...
Mar 29, 2008 | Dishwashers
We got a above ground salt water pool an it's turning a little green what would be the best thing to put in it.
The first thing to do is to shock it with vinyl to about 10 ppm. This should start the progress to blue. Follow the Intex instructions to make sure the pool contains the correct amount of salt and stabilizer. The pump, filter and chlorinator should be run continuously until the water has clarified. The chlorine should then be kept between 2 and 4 ppm. One last suggestion, the filter gets plugged more quickly when you have shocked the pool to get rid of algae so make sure you clean the filter to keep the flow up. I hope this helps.
Please vote on this answer. Thank you.
Aug 26, 2011 | Intex Automatic Salt Water System for ...
Pond water draining out when pump is on. cleaned filters a week ago and I could not get it pack together drained water from pump and found littles balls floading around. I laid them on the bottome put...
If the little balls were perfectly round and steel, then they are balls from a ball bearing. Things are not going to run right until you find the bearing and replace it.
Aug 24, 2011 | Garden
My intex salt water system alarm goes off and code 90 is flashing and there is little flow. If I take out the type A filter to the pump that came with my Ultra Frame above ground pool, the flow is...
What you need to do is either clean out the filter cartridge or replace it with a new one. If you have a spray nozel for your hose you can clean the cartridge by adjusting the nozel so it is a small but strong stream. Run the stream up and down on the cartridge until all the area has been covered and then install it in the system. If you still have little flow then you should replace the filter cartridge.
I hope this helps.
Jul 05, 2011 | Intex Automatic Salt Water System for ...
I have a Lochinvar pool heater that on the dispaly is showing Air Pressure Switch Open. I looked at the manual and it talks about air flow from the supply vent and exhaust vent. Than it says about...
Hi and welcome to FixYa, I am Kelly.
Try this before taking anything apart to far:
The pressure switch is located in the front header, behind the
upper side jacket panel, above the water connections. When
required, the pressure switch can be reset with the following
procedure:
1. Clean filter and skimmer.
2. Start filter pump.
3. Set digital thermostat to highest setting.
4. Turn the adjustment knob on the pressure switch clockwise
until the combustion air fan in the front control panel turns
off. Fan will not turn off if system pressure exceeds 5 PSI.
5. Slowly turn the adjustment knob counter-clockwise until the
combustion air fan turns on. Turn knob an additional ΒΌ turn
counter-clockwise.
6. Turn filter pump off and on several times. The heater should
shut down immediately when the pump stops.
7. If the heater does not shut down immediately as the filter
pump stops, repeat steps 4, 5 and 6 until proper operation
is achieved.
8. Reset thermostat to desired temperature setting.
If after doing all of the above you still have the problem.... you can remove the switch and check for debris in the water passages. If you find debris remove it, reinstall the switch and repeat steps above.
- Still have the problem... Replace the switch.
Thanks for choosing FixYa,
Kelly
Mar 21, 2011 | Lochinvar ENERGY RITE 399000 BTU PROPANE...
How do i replace the water thmostat 99 6 cylider
WELL YOU NEED TO DRAIN COOLANT LEVEL BELOW THERMOSTAT LEVEL.YOU HAVE TO DISCONNECT MAF SENSOR LOOSEN AIRDUCT 2 LARGE CLAMPS LOOSEN REMOVE 4 SCREWS TO AIR FILTER COVER LIFT UP REMOVE COVER. THEN REMOVE AIR FILTER AND HOUSING, FIRST DISCONNECT MAF SENSOR.YOU HAVE TO DISCONNECT THROTTLE CABLE AND SHIFT CABLE.YOU HAVE TO DISCONNECT REMOVE THROTTLE BODY COOLANT HOSES DISCONNECT IDLE SPEED CONTROL VALVE CONNECTOR AND DISCONNECT TPS SENSOR CONNECTOR. THEN REMOVE THROTTLE BODY ASSEMBLY. YOU NEED TO BUY NEW THROTTLE BODY COOLANT HOSES AND NEW THROTTLE BODY GASKET FOLLOW TOP COOLANT HOSE TO ENGINE BLOCK.NOW YOU SEE CAN AND REMOVE THE THERMOSTAT HOUSING REPLACE THE THERMOSTAT.BESURE TO HAVE EXTRA COOLANT ON HAND.BLEED COOLANT SYSTEM WHEN DONE.TO BLEED COOLANT SYSTEM REMOVE RADIATOR CAP ON OVERFLOW JUG.THEN OPEN BLEED SCREW ON THE WATER PUMP BYPASS HOSE PIPE JUST A LITTLE.POUR COOLANT IN THE OVERFLOW JUG UNTIL LEVEL STOP DROPPING.STOP AT COLD MARK ON JUG.CLOSE BLEEDER SCREW ON WATER PUMP BYPASS HOSE PIPE.CRANK VECHICLE CHECK FOR LEAKS. START UP ENGINE LET IDLE FEW MINUTES THEN CHECK COOLANT LEVEL ADD MORE UNTIL UNTIL LEVEL STOP DROPPING.PUT RADIATOR CAP BACK ON OVERFLOW RESERVOIR. LET ENGINE IDLE WATCH COOLANT TEMPERATURE GAUGE.WHEN GAUGE START CLIMBING. TURN OFF ENGINE WAIT FEW MINUTES TAKE A LARGE RAG OPEN RADIATOR JUST A LITTLE YOU HEAR HISS NOISE.WHEN PRESSURE STABILIZE DONT GET SCALDED BECAREFUL.OPEN CAP LITTLE MORE.IF COOLANT PRESSURE STILL BOILS OUT WAIT 20 MINUTES ADD MORE COOLANT TO RADIATOR OVER FLOW WHEN COOLANT LEVEL STOP DROPPING.PUT RADIATOR CAP BACK ON START VECHICLE UP LET IDLE UNTIL THERMOSTAT OPEN. THEN FEEL TOP RADIATOR HOSE FEELS HOT THERMOSTAT OPEN WATCH TEMPERATURE GAUGE.IF GAUGE TEMP START CLIMBING TURN OFF ENGINE WAIT A WHILE.CHECK AND ADD MORE COOLANT.WHEN THE ENGINE CAN IDLE TEMP GAUGE STOP CLIMBING YOU HAVE BLEED COOLANT SYSTEM.KEEP CHECK ON COOLANT LEVEL.
Dec 29, 2010 | 1999 Oldsmobile Alero
Intake to filter has little suction
If you are still looking for some solutions, here they are.
Start by plugging both your out put and input in the pool
or simply close the plungers
If you are uncertain the flow sensor is ok then blast it out with the garden hose. Make sure it swings freely
now take out your cartridge and blast it too
now remove your hose from the inlet to the pump
even though you may be skimming and things go in the basket hair still gets through and cloggs up in front of the filter
this also will happen with out a skimmer
Put it all back together and now open the top bleeder on the cartridge cover
open outlet side hose first
when water starts comong out the bleeder open the inlet hose
now turn on pump for 30 seconds and then close the bleeder
This should do it
Please remeber to rate this solution
Jul 17, 2010 | Intex Automatic Salt Water System for ...
Hi my zanussi zwf1432s stopped halfway through washing green light on start/pause button flashs wont do nothing else all lights will change when cyle chosen but will not start justs beeps then back to...
Hello Paula,
Do not know how many flashes but 1green/1red = 11 water pressure low.
2green/1red = 21 blocked filter or pump fault.
You would be best firstly checking the filter and make sure it is clean and pump turns.with water drained and filter out shine torch into filter put on spin/drain and see if pump blade spins if not then try and turn with long screwdriver to free out any debris then refit filter and check for leaks and try donnt fill fully until you are happy it can drain water.
Hope I was of some help.
Good Luck
Apr 22, 2010 | Zanussi ZWF1430W Front Load Washer
My DE pool filter stops working after an hour? please help
Is your pool green? This will cause the filter to plug up. When you say stops working do you mean no water flo, passing dirt or are we talking about the pump not moving water? Can you clarify this problem some?spellcheck.gif
Aug 16, 2009 | Hayward EC-40 DE Pool Filter with pump
Asko D1796FI Built-in Dishwasher Logo
26 people viewed this question
Top Asko Dishwashers Experts
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
