Question about Uniden BC72XLT Handheld Scanner
I just bought a scanner "all lock out" is on screen
Code 2, 189,0
All scanners come with the scanning head locked to prevent damage to it during shipping. On the back of the scanner, where the power cord and wires connect, there will be a sliding switch, sometimes a turning type lock, with two positions, one with the icon of a closed [so locked] padlock and the other with the icon of a open [so unlocked] padlock. Every scanner I have bought describes this lock in the setup manual.
Oct 17, 2014 | Canon CanoScan 9000F Mark II Color Image...
Hi I have just purchased a Samsung CLX- 3185 Colour printer, scanner and copier and the screen states ' Scanner Locked'
The scanner may have a locking lever that locks the scanner head so you can transport it without damaging the scanner head.
Locate the locking lever and unlock the scanner head.
Jan 23, 2011 | Samsung CLX-3160 All-In-One Laser Printer
The screen shows "scanner locked"
just check the scanner lock & rlease
exist at lower side of scanner assy (inside the paper exit area)
Dec 26, 2010 | Samsung SCX-4720FN All-In-One Laser...
SCX 4216F Scanner LOCK
It can also be the ribbon cable connecting the scanner to the formatter board. Check that it is connected properly.
Aug 20, 2009 | Samsung CLX-3160 All-In-One Laser Printer
Samsung CLX3160FN: scanner stays locked
Hi Stijntje,
The scanner lock is actually a physical locking mechinism. It is not a control panel option.
the scanner is locked in a safe position before they ship the unit to prevent damage to the scanner.
I believe that this sliding latch can be located ( while looking straight at the unit ) on the under side of the scanner, above the area where the paper comes out, more to the left hand side.
locate the latch and slide it from the locked position to the unlock position.
Press stop/clear button to clear the error and try again.
Good luck,
Oct 11, 2008 | Samsung CLX 3160fn All-In-One Printer
Scanner locked
yep..this started happening to me also...it us to work perfectly....please help.
Thanks
Aug 02, 2008 | Visioneer 9020 Flatbed Scanner
Samsung CLX-2160N Sanner Locked
Same problem thanks for ignoring guys!
Dec 11, 2007 | Samsung CLX-2160N All-In-One Printer
How to restore locked out channel
Hi your scanner may be locked. if on the screen it has a small K/L symbo, then it is locked. to unlock it press the lock button and it should go away. now press the L/O key if there is a little L/O key that is on the screen. this should unlock out the channel. hope this helps A.Ryan ant_man-92@hotmail.com
Sep 19, 2007 | Uniden BC60XLT Handheld Scanner
Uniden BC72XLT Handheld Scanner Logo
44 people viewed this question
Top Uniden Radio Communications Experts
Jason
Steve
eradiostore
eradiostore
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
