Question about Kenmore 14.1 cu. ft. / 399 liter Upright Freezer 24422
25328459808 how to turn on after accidently turning off
Pannel off freezer not turn on ?
Thank you for your question, Friend.
It sounds like the temperature control of your Frigidaire freezer (FKFH21F7HW) is possibly in the off position. When this occurs the temperature control turns off the compressor, but does not disconnect the power to the light bulb or other electronics. Let's try reactivating your freezer by pressing the UP arrow until display shows "4" or desired setting. Please allow 24 hours for temperature to stabilize. For future reference you can lock the control to keep from accidently changing the temperature setting.
If this is not the case and your freezer has no power, can you please elaborate prior to your problem any other symptoms? For instance, did notice any error codes, or other strange functions? Also, may I have your model number please? The serial tag, which lists your model number, is normally located inside the cabinet on the left/right side wall. Thank you and I look forward to hearing from you. - Z
Sep 03, 2014 | Frigidaire Freezers
I accidently turned off freezer.How do i turn it back on?
Turn the interior temperature control back on by setting at approx halfway between "off" and "coldest". (Make certain the branch circuit is hot - you should hear the compressor turn on when you set the control, possible an interior light will come on as well).
If the freezer does not run, check to see if you accidiently pulled the flash defrost plnger (if equipped). (See age 8 in your manual).
If you don't have a manual, you can download one here:
ShopYourWay KENMORE Upright Freezer ShopYourWay
(This is for Kenmore model 253.23024-101 or -102).
Apr 22, 2014 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Accidently turned OFF.How do i get it turned on?
Keep it opened for about 30 minutes, the shut it up, and switch On. There is no problem.
Top 3 shelves don't freeze
Cold air sinks. If evaporator temp is not low enough only the items on bottom of freezer will get cold and possibly freeze - stuff on top will not.
Throw a digital thermometer in there towards the top shelves and I bet your temps are high. Low refrigerant will cause this; furthermore, if you leave the refrigerator door open by accident, the refrigerator will never shut off, the freezer evaporator will freeze over with a block of ice, and the freezer temps will be higher. If that is what happened, simply unplug the unit and allow it to self defrost and then turn it back on for proper operation and make sure that the refrigerator door is properly closed!
Nov 20, 2013 | Whirlpool Freezers
Of error code
Good Afternoon Jason, thank you for allowing me to assist you!
Based on the symptoms you are describing it sounds like the temperature control is in the OFF position. When this occurs the temperature control turns off the compressor, but does not disconnect the power to the light bulb or other electronics. Let's try activating the freezer by pressing the UP arrow until display shows "4" or desired setting. Allow 24 hours for temperature to stabilize. For future reference you can lock the control to keep from accidently changing the temperature setting. I hope these troubleshooting tips help you in some small way. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if the unit's status has changed successfully.
Aug 30, 2013 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Freezer reset button
Hello Stella, based on the symptoms you are describing it sounds like the temperature control is in the OFF position. When this occurs the temperature control turns off the compressor, but does not disconnect the power to the light bulb or other electronics. Did you try activating the freezer by pressing the UP arrow until display shows "4" or desired setting and allowing 24 hours for temperature to stabilize? For future reference you can lock the control to keep from accidently changing the temperature setting. If so, I recommended resetting the unit by either unplugging it or flipping the household circuit breaker off. It is important to wait roughly ten minutes, then turn the freezer on and redo the previous steps. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if the unit's status has changed successfully. Thank you.
Aug 05, 2013 | Frigidaire Freezers
Lffh21f7hwa
Hello Michael - Sounds like the temperature control was accidently turned OFF. When this occurs the temperature control turns off the compressor, but does not disconnect the power to the light bulb or other electronics. Let's try activating the freezer by pressing the UP arrow until display shows "4" or desired setting. Allow 24 hours for temperature to stabilize. For future reference you can lock the control to keep from accidently changing the temperature setting. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if the unit's status has changed successfully. Thank you.
Jul 01, 2013 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
I have this majic chef freezer about 7 cubic ft. 3 years old turned it off to defrost and when turning it back on it won't get cold?? Compresser is hot so I believe it is working and lights on in front...
I'd let it dry out totally then try it again, some of the electronics may have gotten wet when you defrosted it. Give it a week somewhere warm and dry like a garage. If you didn't attack built up ice in the freezer with a knife while defrosting it it should work after it dries out. Most people end up killing freezers by accidently poking holes in the evap coil while trying to remove built up ice.
Aug 14, 2011 | Magic Chef Chest Freezer MCCF5WBX
Freezer is on, but not working
sounds as if the temp control knob has gone bad or maybe turned off by accident.
Jul 13, 2010 | Frigidaire 11.6 cu. ft. / 328 liter...
Kenmore 14.1 cu. ft. / 399 liter Upright Freezer 24422 Logo
75 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
christian nielsen
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
