Question about Exercise & Fitness
Lifestrider 3325 treadmill reset button
Treadmill won't turn on...trying to find the reset button
3 Suggested Answers
dgforeman
  • 29 Answers
SOURCE: dp lifestrider 3325 treadmill
Dp went out of business many years ago. S & R Workout Warehouse bought all their parts. They are in Tyler Texas at 903 581 6568. I just talked to them yesterday. Central time 8-4:30
Posted on Jan 28, 2009
maxtreadmill
  • 832 Answers
SOURCE: Lifestrider 3325 will not turn on.
Keep unit unplug check your outlet if power is good then plug unit in make sure your safety is engaged if that does not work, open motor shroud and under that shroud their should be a paper with a wiring diagram and with a Ohm meter check where you have a open circuit.
Posted on May 06, 2010
I have an Ifit treadmill. I was changing speeds and it turned off and won't restart. It beeps when i turn it on but no lights on console.
Power issues with ProForm treadmills fit into two categories: the power does not turn on or the power shuts off when using the treadmill. If the power will not turn on, make sure that the treadmill is plugged into a working power outlet. In addition, you should use a single-outlet surge protector for the treadmill. Single-outlet surge protectors protect the machine from any voltage changes that may occur in your home.
If the machine is plugged into a working outlet, make sure the safety key is in the keyhole on the console. If the safety key is not plugged into the machine or if it is pulled out during operation, the treadmill will not operate.
Finally, make sure the circuit breaker located on the frame near the power cord is set to "Reset." The circuit breaker is set to "Reset" if the top of the button is pushed in. When the breaker is tripped, push it back to the "Reset" position and wait five minutes before powering on the treadmill.
If the ProForm treadmill shuts off during operation, check the power cord and circuit breaker as described above. You can also try removing and reinserting the safety key.
Increase Engine Horse Power.
Jun 02, 2012 | Proform Exercise & Fitness
I have an athletech performance treadmill it won't turn on on button doesn't click as does the off button
Dear Sir:
1) Try to reset the c. breaker in your treadmill.
2) Inspect if your see some loose wires.
3) Open the keypanel and tight the flexible cord or ribbon cables.
4) Tight the connector coming from display planer to lower boar or main motor board.
5)Test the Transformer for there are voltage in primary and secondary winding.
6) Measure the input to the power board
7)See there are +5VDC to the main motor board and display board?
8) Run the calibration Software read your user manual or see under the Hood the motor the instruction for more easy diagnose and troubleshooting . Attached is my block diagram that I did design for purpose of diagnose. sincerely. God bless you
ernesto cuadra
managua, nicaragua. c.a.
Feb 12, 2012 | Exercise & Fitness
Treadmill buttons don't work right. TV won't turn off. Treadbelt won't run.
1) Try to reconnect the plug between console and pcboard very well.
2)Clean the contacts with special contact cleanear( radio schack or computer store) with carefully only the buttons, if you can open the cover better.
3) adjust the Sensor SWITHC.
4) Look for any wire loose, or making bad contact, or break wiring( continuity) test the fuse and breaker.
If after you did those steps, and the problem persist, the console board is faulty.but first change the sensor switch, you must be shure after adjustment.11_18_2011_12_23_17_am.gif
Nov 17, 2011 | Exercise & Fitness
Error 100 won't connect to network anymore to use ifit live
Check the power cord to ensure it is connected to the power supply and the treadmill if the power does not stay on or does not turn on. Look at the circuit breaker, located near the base of the unit, to see if the circuit was tripped. Push the switch back in to reset the circuit.
  • 2 Take the key out of the console, wait a minute and place it back in the console to resolve issues with the power turning on and off during use or if the console displays are not functioning properly.
  • 3 Remove the console key and press the "Stop" button to turn off the "Demo" mode, which is often the default setting when the treadmill is first purchased.
  • 4 Reset the incline by holding down the "Stop" and "Speed increase" buttons and putting in the console key. Release the buttons and then press the "Stop" button, followed by the down or up arrows for the incline. This step can be taken if errors are occurring with the incline function.
  • 5 Turn the treadmill "Off" and unplug the unit if errors continue. Wait five minutes and then plug the unit back on, insert the console key, and turn the treadmill "On." This will reset the treadmill and should return to normal funcTION
  • Oct 04, 2011 | Nordic Track NordicTrack Elite 9500 PRO...
    I dont know how to incline my lifestrider treadmill
    It should say "Incline" with 2 arrows 1 up, 1 down. If you don't see them i don't think you can. Did the box or ad say with incline How do you know there is incline Maybe it doesnt say "Incline" it might say "Raise"
    Aug 19, 2010 | Exercise & Fitness
    May 05, 2010 | Exercise & Fitness
    Hp deskjet 3325 light flashing have turned device
    no problems
    :just go ahead and take out the power cable when the printer is still on
    :nw press and hold the power button fr 30 seconds
    ;while holding the power button,plug back the power cable
    :nw u will be able to work well
    Jun 28, 2009 | HP DeskJet 3325 InkJet Printer
    Dp lifestrider 3325 treadmill
    Jan 08, 2009 | Exercise & Fitness
    Exercise & Fitness Logo
    19 people viewed this question
    Top Exercise & Fitness Experts
    Howard
    Howard
    Sportsmith LLC
    Sportsmith LLC
    Tom Chichester
    Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
