Question about Dmm Vision Fitness T9500 Treadmill
T9250 treadmill has dashes on the display will not run
Display is showing 3 dash marks. the treadmill will not come on at all. please help
You may have a control board failure, it must be checked by a repair tech.
Aug 31, 2016 | Confidence Gtr Power Pro Motorised...
My belt has stopped working, but all other functions are fine. I've removed the motor cover, but now what should I look for?
Try to check the carbon brush of the motor. If it's OK then the motor control board would be faculty
If you wish to get some more details about treadmill repair then check the following link
http://electro-medical.blogspot.com/
Aug 20, 2016 | Vision Fitness T9250 Treadmill
How do i fix a lifegear treadmill 97520?
Try below:
ERROR CODE
DESCRIPTION
E1
Speed error (The treadmill running speed is 3.2 kph faster than the displayed
speed). The treadmill will stop immediately when the console detects this error.
E2
Speed error (The treadmill running speed is 3.2 kph slower than the displayed
speed). The treadmill will stop 16 seconds later after the console detects this
error.
Troubleshooting / Resetting error codes
In the rare event of the treadmill displaying an error code ("E" followed by a number), simply reset
the computer by:
1. Step off the treadmill. Ensure that you are clear of the running belt.
2. Turn the treadmill off at the master power switch located near the motor housing.
WARNING: Ensure nothing is positioned near or under running belt which may possibly block
it's normal operation.
3. Turn the treadmill on at the master power switch.
4. Ensure that the Safety Tether Key is securely and properly installed onto the console or just
reinstalling the Safety Tether Key can also reset the display.
If the above does not clear the error code, please contact the nearest Dealer/Service Center
LifeGear 97320 Owner Manual Page 17
May 22, 2016 | Exercise & Fitness
My Vision Fitness T9250 treadmill. Can hear a low noise when no one is on it but gets much louder when anyone is on it and operating...any ideas where to start looking for repairs?
Try to open and separate the motor carefully from treadmill chasis, turn the motor shaft with hand if it not easily turn or you hear a unsual sound try to open the motor and add a lubricant to motor bearing, and turn the motor on if its still noise replace all the bearings with new one
Dec 14, 2014 | Vision Fitness T9250 Simple Folding...
E4 coming up on my screen display , what is this and how do I fix it so it will work again ....
What device are you talking about your stereo ATV a computer or a cell phone?
Most manufacturers have a support site on the Internet and given the error code and the model number they'll give you a solution
Nov 25, 2014 | Vision Fitness T9250 Deluxe Folding...
Technogym no power to display
Assuming all the cables are ok, your display is probably dead and needs repaired. But more often than not the inverter is the problem.
If you have a way to swap it with another Technogym inverter I would try that first.
Jun 13, 2014 | True Technogym Excite Run 700 Treadmill
Treadmill display problem
The equipment is blocked... (2) this is the message I get in my Run excite 700 technogym treadmill.
Can some one help.
Thanks a lot
Jan 08, 2014 | True Technogym Excite Run 700 Treadmill
Getting E2 error on my vision fitness t9250 treadmill
68a1477a-4453-48c8-9f94-cd15c6c6fea7.giffollow this steps and fix it. God bless you
This is probably a faulty speed sensor or the speed sensor is not plugged in properly. Its also possibly a faulty motor control board or lower board. The error codes will differ between makes and models but could be e1.
See the diagram attached.
Oct 13, 2013 | Exercise & Fitness
I have a vision fitness treadmill T9250 and now the console display isn't working properly. Some of the
Dear Sir:
Please see the diagram attached from REED switch, adjust, clean, and tight the connector wires very well.
2) change the batteries by new ones, use the best.clean the contact batteries.
3) tight the ribbon cable from keypad .+ tight the connector from display board vs lower board.
4) after you fix it RUN THE sofware calibration for diagnose, troubleshooting, See my personal tips for help
sincerely. God bless you
Apr 30, 2012 | Vision Fitness T9250 Deluxe Folding...
Dmm Vision Fitness T9500 Treadmill Logo
37 people viewed this question
Top Dmm Exercise & Fitness Experts
fretlessbass
fretlessbass
Level 1 Expert
Electro Med Services...
Techmotionusa.com
Techmotionusa.com
Are you a Dmm Exercise and Fitnes Expert? Answer questions, earn points and help others
