Question about GE Spacemaker JVM1640SJ Microwave Oven
My Advantium oven is mounted directly above my stovetop. I was boiling water for pasta, and a great deal of condensation formed on the Advantium. After the indicent, the Advantium controls started working strangely. Before, when you'd twist the select knob, the menus would scroll either upward or downward depending upon the direction you turned the knob. But now, it only scrolls from up to down, regardless of which direction you turn the knob. For example, when you push the knob it goes to the highest alpha menu option, then scrolls down toward the lowest alpha item. If you select Time, it starts at 15 seconds. When turn the knob, it goes right to 99 minutes, and regardless of which way you turn the knob, it only decrements downward. I'm still ablt to use the oven, but it's a pain to operate the controls now. So, I think the steam from the pasta damaged the unit. I did unplug the unit, waited a few minutes, then replugged it and reset the clock etc. but it didn't help. Is there a reset function?
  • pkrabacher Jun 20, 2009
    Avantium 120 Oven Control Knob stopped working correctly. My Advantium oven is mounted directly above my stovetop. I was boiling water for pasta, and a great deal of condensation formed on the Advantium. After the indicent, the Advantium controls started working strangely. Before, when you'd twist the select knob, the menus would scroll either upward or downward depending upon the direction you turned the knob. But now, it only scrolls from up to down, regardless of which direction you turn the knob. For example, when you push the knob it goes to the highest alpha menu option, then scrolls down toward the lowest alpha item. If you select Time, it starts at 15 seconds. When turn the knob, it goes right to 99 minutes, and regardless of which way you turn the knob, it only decrements downward. I'm still ablt to use the oven, but it's a pain to operate the controls now. So, I think the steam from the pasta damaged the unit. I did unplug the unit, waited a few minutes, then replugged it and reset the clock etc. but it didn't help. Is there a reset function? PS. It has been more than a month since the malfunction started, and I live at 8,000 ft. elevation, so I'm sure the unit has dried out thoroughly by now.
    President:
  • 392 Answers
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for maybe an hour.
Then let us know if the hard reset does not fix it.
Can you post a good photo of what the display shows?
Posted on Jun 20, 2009
  • 71 Answers
Use hair dryer to dry the control panel. when boiling water the steam sip inside the controller box.
Condensation between door glasses
This moisture can accumulate from certain types of cooking (lots of boiling) in the microwave or in extreme cases, from a blocked grease filter or exhaust vent duct.
Spills or large amounts of accumulated moisture should be wiped off. Minor amounts can dry out by themselves easier if you leave the door open after cooking.
Also, when boiling on the stovetop, you should always use the hood vent exhuast fan to keep steam and grease out of the controls and the door area of the microwave. I always recommend using the vent fan with any cooking on the stovetop.
As long as it is not rusting the metal mesh screen or other parts of the door, it can be allowed to dry out over a period of days with the door open.
If it is a convection microwave, using the convection heat will help it dry.
May 19, 2013 | Microwave Ovens
How to replace door switch on advantium
Happened to my 2005 Advantium120 twice, both times after extended cooking/simmering on the cooktop (17" below). Solution was to leave unplugged for a good 48 hours (to dry out?) then plug in again and all is good. GE says to either raise the microwave 4" or stop boiling pasta on the stove, neither a good solution. Good luck!
Jan 28, 2013 | GE Advantium 120 Convection/Microwave Oven
GE Advantium 120 oven: Was boiling water and oven completely powered off. House circuit breaker is OK and not tripped. Plugged into another working outlet with extension cord to see if display came on. It...
You will need to remove the top grill vent first, then you can remove the screws coming in from the top of the grille vent then that will expose a screw holding down the control panel at the top. Remove the screw and remove the control panel. The fuse is located in a little 1" fuse holder just behind the front panel near the top.
Feb 05, 2010 | GE Advantium 120 Convection/Microwave Oven
HOW TO GET SPATTER OFF ADVANTIUM 120. SOAP & WATER DID NOT GET THE JOB DONE
easy stick a bowl of water and stick it in the wave and boil it.. but be careful to let water cool before you open the wave for a minute or two ! the steam from the super heated water will loosen that stuck on mess .. boiling water in a m wave is dangerous the water will explode when exposed to cool air
Jan 31, 2010 | GE Advantium 120 Convection/Microwave Oven
Advantium 120 convection/microwave oven dead after power surge
The removal instructions are on page 34 of the service manual, and we have uploaded it to our site here to help you.
Jun 28, 2009 | GE Advantium 120 Convection/Microwave Oven
Need to know how to remove Advantium 120 convection/microwave oven Model SCA1000DWW03 from mounting above stove so that it can be taken to repair shop - problem is completely dead after power surge during...
Usually there are 3 or 4 mounting bolts located in the floor of the cabinet above. First you will have to disconnect the power and then the duck work if the unit is ventde to the outside. To remove the unit requires two people, one to support the unit and the other to remove the bolts. If you are doing it alone, quite difficult, you'll have to juryrig a deadman support. Ther is a wall plate behind the unit that has a lip that the back bottom of the microwve is locked into. After the bolts are removed slowly lower the front until you are able free the unit from the lip of the support plate.
Whenever anyone uses the stovetop to boil water, the steam seems to affect the microwave and causes it to turn on by itself and the panel buttons will not work
did it come with the exhaust fan under it? if so just turn it on when boiling water if it didn't try to find one that goes with the unit and hve it installed, this is theonly way to fix the problem
Jun 27, 2009 | Magic Chef CMV1000B Microwave Oven
GE Microwave Profile Spacemaker Runs on its own
Your microwave turning on by itself is a "self preservation feature" of the GE Profile Advantium and maybe some other models. Read the manual, When your over the range oven gets warm enough, for whatever reason the venting fan comes on until a satisfactory oven temperature is reached. You are not permitted to shut the vent fan off. Also it seems a temperature near room temp must be achieved before it shuts the fan motor off, it is very annoying. We had to return our Advantium because of fan noise. I configured the ovens vent fan to the recirculate direction because we do not have a vent duct that exits the house over our range. When the vent fan acting as the ovens cooling fan automatically turned on we would have to leave the house to hear each other talk. Too bad we really liked the oven other than that major problem. G-Man
Apr 19, 2009 | GE Profile Spacemaker Over-the-Range...
Sca2001bss03-Advantium oven-built 06/2000
If you or a friend decide to work on it, we have *critical* safety and disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts (such as "button") by entering your base model number (without the suffix) here: http://tinyurl.com/gv383 If you find you need control panel repair, we do that nationwide for $39.95 in most cases. See: http://tinyurl.com/yzjozk
Mar 19, 2007 | GE Advantium 120 Convection/Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
57 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
