Question about Frigidaire Washing Machines
I have a Frididaire gallery model # GLWS1339ESO washing machine. It will fill up with water and agitate but then it will not go to the next cycle. I can put it to the next cycle and it will drain but then it will not spin the clothes when I put it to the spin cycle. I can put it on the power spin cyle on whites and it will spin but it will stay in that mode until I stop it. Thanks!
    New Friend:
  • 40 Answers
I WOULD SAY YOU HAVE A BAD TIMER
Posted on Sep 02, 2014
Oceti
  • 51 Answers
SOURCE: Will not drain or spin
Unless you jarred the machine it's the timer. You can check this by bypassing the lid switch and seeing if it will cycle.
Posted on Dec 13, 2007
  • 20 Answers
SOURCE: machine fills and agitates, but won't drain
Please empty your machine and run the machine empty. If the washer goes through the whole cycle without any clothes. Please let me know
Posted on Jan 19, 2009
  • 1214 Answers
SOURCE: GE Top Load Washing Machine -- Agitator will not cycle
Agitator's don't spin on wash cycle.
I would suggest washing the clothes without soap until they rinse clear. If you have hard water, the soap will not easily rinse out of clothes, or off of you when you use soap to wash or shower.
Reduce the amount of soap you use in each wash if this is the case. It sounds like your washing machine is working right.
Posted on Jan 26, 2009
kram26
  • 544 Answers
SOURCE: washer will not agitate or spin
HI,
you can view this site to have some ideas about your agitator problem.
http://sites.google.com/site/sublimeappliancerepair/washer-will-not-spin/agitator-woes
any further question let me know.
thanks,
Posted on Mar 29, 2009
SOURCE: old model rca washer machine...will not agitate/wash the clothes,does spin.
If the washer fills up with water and you hear the motor running but the agitator doesn’t move, the agitator coupling is the most likely problem. First pump the water out by turning the timer to spin. Once the water is out, turn the washer off. Now pull up on the agitator until it comes off (it may be hard to pull off). Now that the agitator is off, you can see the agitator coupling, reach down and try to turn the coupling. If the coupling turns freely, it is striped out and needs to be replaced.
Posted on May 07, 2009
Beko WMP652W washing machine will start cycle but get stuck at end of wash, doesnt go onto rinse or spin any help please?
see the next steps and use the common sense: God bless you
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Aug 01, 2012 | Washing Machines
The agitator will not spin
The problem will be in the pressure starter kindly check whether water stops after certain level and ready for washing,if it is OK means kindly check the wire connections from the operational panel to the motor, in most of the case the timer will not send signal to the motor for that kindly change the operational panel and check it
May 18, 2010 | Frigidaire Gallery GLWS1339EC Top Load...
Washing machine won't spin and drain
the drain pump is not working,after wash cycle the washer should drain the used water,if it does not function-all the next cycle will not commence.
Mar 19, 2010 | Washing Machines
Top load washer not agitating. buzzing noise from motor
1st check pump is pumping out water/ next could be motor not running due to fault, not sure if brushes are in this motor if so check for wear, quite old so could be the motor gone...
Oct 31, 2009 | Washing Machines
Frigidaire washing machine gets stuck on cycles
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Apr 01, 2009 | Frigidaire Washing Machines
Will not move to the next cycle.
  • Jan 07, 2009 | Kenmore 24032\24036 Top Load Washer
    Washer fills with water but will not agitate to wash the clothes.
    REPL/ PUMP GRINDING NOISE IS BROKEN IMPEELER INSIDE PUMP SHOULD FIX PROBLEM
    Nov 30, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
    Washing machine fills, but won't agitate
    maytag washer dryer stack unit , model # lse7806ace washer fills with water but won't agitate or do anything else. I had the same problem a year ago and replace the lid switch asssemby and fuse and it worked fine until now. the switch clicks when I open and close the lid and the pink and orange wires show continuity with the lid closed.
    Aug 29, 2008 | Maytag LSE7806A Top Load Stacked...
    Washing Machines Logo
    71 people viewed this question
    Top Frigidaire Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
    Charles T Nevin
    Charles T Nevin
    Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
