Question about SanDisk Cruzer Micro MP3 Player
U3 is gone - SanDisk Cruzer Micro MP3 Player
    Problem Solver:
  • 9 Answers
Download the u3 software from www.u3.com and install it. It should work as before.
Posted on Jun 22, 2009
My SanDisk 1gb flash drive says i only have 1 try left at trying to unlock it. I didn't even know i had locked it. Can you please Help?
This will get the drive back, but you WILL lose the data. If you need the data. I do not know the answer. Repost your question to go to Sandisk site below
'.............U3 smart drives come preinstalled with the U3 Launchpad which emulates the Windows OS start menu, and controls program installation and hence facilitate the portability of software. However, if you would like to use the USB flash drive or memory key as a pure normal USB mass storage device, or you don't use operating system that U3 supports (i.e Windows XP and Windows 2000 operating systems), or you simply feel that U3 Launchpad and applications have bugs such as unable to eject due to locked files in use, consent on privacy and automatic installation of U3 software and pop-up etc, you can uninstall and remove the U3 Launchpad from the USB storage device.
To remove and delete the U3 Launchpad, you need to download U3 Launchpad uninstallers or U3 Launchpad Removal Tool that remove the U3 Launchpad and re-configure the USB drive to be a single mass storage USB drive. Currently, U3 Launchpad uninstallers are only available for and must be run on Windows XP or Windows 2000 machine. When uninstalling, the U3 smart drives USB device has to be plugged in with U3 Launchpad running.
U3 Launchpad Removal Tool for SanDisk USB U3 devices can be downloaded here, http://u3.sandisk.com/
WARNING: U3 Launchpad removal is irreversible. You won't be able to install U3 again. Beside, backup your data before begin uninstallation process as ALL data will be erased.
UPDATE: It's impossible to reinstall U3 LaunchPad........."
Thanks for using FixYa - a 4 THUMBS rating and POSITIVE TESTIMONIAL is really appreciated for the FREE answering of your question.
Feb 12, 2011 | SanDisk Cruzer Micro 2GB USB 2.0 Flash...
Tip
Safely remove and reinstall the U3 software!
First of all, sorry for my worse english :P Reinstalling U3 on your drive is sometimes not possible. To solve this you must remove it using the OFFICIAL U3 remover from SanDisk. If you delete U3 using the launchpad itself, or using the U3 removal utility from U3, you can't reinstall it. I've archived older versions of this utility's, because they're the most stable versions. U3 removal tool: http://tinyurl.com/ysu7bt U3 installer: http://tinyurl.com/23e7rl Just use this utility's. Note if you have deleted NOT using this utility's, it's possible it won't succeed. Hope this works for you! I've tested this using two SanDisk Cruzer's. Kind Regards, Stijn.
on Jul 04, 2007 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
SanDisk 8gb drive with u3 installed How can I
  1. Run the launchpad program.
  2. Double click on the icon to open up the main windows.
  3. Click on Settings and the U3 Launchpad Settings.
  4. Click on Uninstall tab on the side and then Uninstall U3 Launchpad. Before you do this, make sure all the programs on the flash have been closed and all the explorer windows are closed, too.
After uninstallation, the drive has only one partition. The pesky ready only partition with U3 program is gone.
Dec 01, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
I have inserted the Cruzer Micro 2GB flash disk, its detected as unknown device i've gone to device manager tried checked driver details it says no drivers i've tried reinstalling the U3 launchpad but it...
I would try a different computer first if that does not work it may be the drive is bad and would need replacement. For the most part memory has a good warranty so you may be able to have it swapped by contacting the manufacturer.
Nov 15, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
I can not format it
How do I uninstall U3 from my flash drive Most U3 smart drives come with an uninstall utility that converts the U3 smart drive into a regular USB flash drive. This utility can be accessed from the U3 Launchpad. Open the U3 Launchpad and click on Settings, then select U3 Launchpad Settings and click on the Uninstall tab. Some devices have a link to the Uninstall utility under Help and Support.
If you can not find the uninstall utility on your U3 smart drive you can download it from the following locations:
Remove U3
U3 removal tool for MAC
Jan 11, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Can i install u3 smart launchpad on my kingston data traveller G2
well U3 system software is pre-loaded to USB devices by the manufacturer and requires special flash drive controller line and thus it is not possible to install u3 by user.
Good Luck.
Jan 06, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Where i can find skype for U3 to download
Check out the same Q in Skype Forums. You can use regular skype with a regular USB stick, but have to change the executable string on the shortcut so it tells skype to use /removeable.
U3 has to use Skype for U3 - it is a version unique to the U3 stick, but is not being upgraded regularly. here is a current copy:
http://u3.disk2go.com/dl/skype.php?id=SkypeSetup-U3.u3i
Oct 28, 2009 | Electronics - Others
Cruzer program no longer on flash after viruses were removed
New ones avail:
  1. Microsoft and SanDisk team up on U3 replacement - Engadget Microsoft and SanDisk team up on U3 replacement .... is actually pretty good, but they charge you extra to be able to install any program not on their list. ...
    www.engadget.com/2007/05/11/microsoft-and-sandisk-team-up-on-u3-replacement/ - 99k - Cached - Similar pages
  2. GnU3zer U3 LaunchPad replacement (download torrent) - TPB Oct 28, 2006 ... GnU3zer U3 LaunchPad replacement ... The windows CD autorun function can execute ANY program specified in the autorun.inf file provided it ...
    thepiratebay.org/torrent/3547144/GnU3zer_U3_LaunchPad_replacement - 16k - Cached - Similar pages
  3. Microsoft, SanDisk to Replace U3 Drives Microsoft and SanDisk on Friday announced a technology-sharing agreement that will produce a replacement for SanDisk's U3 line of USB smart drives by the ...
    www.physorg.com/news98193946.html - 55k - Cached - Similar pages
  4. Microsoft and SanDisk still working on StartKey - the new U3 ... Mar 7, 2008 ... Microsoft and SanDisk still working on StartKey - the new U3 replacement ... Microsoft and SanDisk Expanding on and Replacing U3 Smart ...
    www.u3-info.com/sandisk/microsoft_and_sandisk_still_working_on_startkey_the_new_u3_replacement - 13k - Cached - Similar pages
Jan 13, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
SanDisk Cruzer Micro MP3 Player Logo
98 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
