Question about LG LFX25971ST Bottom Freezer French Door Refrigerator
LFX25975ST water coming out slow - LG LFX25971ST Bottom Freezer French Door Refrigerator
    Habit-Forming:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 111 Answers
Check if the water supply main valve for the unit is fully opened. if it is , check for obstructions in the line. if waterline has no obstructions , find out if water solenoid valve is working fine. with all the mentioned working alright but problem is still present , call a service man .thanks.
Posted on Mar 05, 2016
Changed the filter but water is coming out slow from the water dispenser
Most likely your water flow is restricted by Ice build up within the small reservoir located in the refrigerator section. If that is not a problem then you could have a flow valve that's not opening fully.
Jul 25, 2014 | LG LFX25975ST (247 cu ft) Side by Side...
Why would the water be coming out really slow in my refrigerator
your water filter or lines to and from the water supply to the filter and to the dispenser can be plugged with lime,also if you use a saddle tap from the water line in the house feeding the dispenser hose they can plug up with lime also
Apr 08, 2013 | Frigidaire Refrigerators
LFX25975ST ERROR 1F.
needs longer to defrost water line in the door turn it off again and use a hair dryer on the door
Mar 27, 2012 | LG LFX25975ST (247 cu ft) Side by Side...
I open the frige and no light or compressor sound. I checked the power source and no issues.... how do i reset the power board control ??
http://appliancedigest.com/index.php?/files/file/135-lfx25960xx-lg-247-ft-french-door-refrigerator-with-ice-in-door-service-manual/ Closes I found.
Nov 15, 2010 | LG LFX25975ST (247 cu ft) Side by Side...
Can water flow be adjusted water comes out very slow
Yes, providing the water filter has been changed regulary. That would be number one reason for water slowing down. If you hae done that we will work with supply, Sea Breeze
May 19, 2010 | GE GSS25SGPSS Side by Side Refrigerator
Water going into machine slow, water coming from
there will be either 2 or 3 screws on the rear of the lid,remove and slide the lid backwards, lifting slightly on some models.
Oct 04, 2009 | Washing Machines
Water in door too slow coming out
A strainer before the inlet valve can get stopped up restricting flow. It's on the back where the water supply connects.
You have two points where you can check the dispenser water. At the rear where the water supply comes in is the water inlet valve. If you disconnect the dispenser water line and then see how fast the water comes out when you try the dispenser. If it's slow here there is a valve our water supply problem. If it's normal, disconnect it at the bottom of the freezer door and try again.If it's normal here it may be frozen in the door. If this is the case open the door till it thaws. A blanket over the opening will prevent thawing of all the food.
Sep 20, 2009 | Refrigerators
Why would the water start coming out very slow?
If you are referring to water coming out the fountain it could be a leak in the system somewhere allowing air into the lines that run the water, if you are referring to water coming out of the ice maker itself you need a new ice maker the lining is bad
Jul 14, 2009 | Kenmore 52632 / 52634 / 52639 Side by Side...
Cold water will come in verry slow
if your water pressure is good the water valves are bad.
Dec 14, 2008 | Washing Machines
LG LFX25971ST Bottom Freezer French Door Refrigerator Logo
116 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
