Won't spin not spinning when lid is closed
  • 112 Answers
SOURCE: roper rax4232pqo wont spin
Still replace the lid switch. Most have multiple contacts.
Posted on Nov 08, 2008
Maytag317
  • 1136 Answers
SOURCE: Whirlpool LSR8233eq top load washer won't spin most of time
Hi, It sounds like your spin basket drive is going bad. Even tho you cleaned the brake, the pads get worn down enough they will not grab. The only other thing I can think of is the bloch that sits on top the basket drive shaft and lockes the inner tub. Sounds like you have done/checked everything else.
Please let me know if I can assist you further.
Vic
Posted on Jun 20, 2009
aasc
  • 1606 Answers
SOURCE: Won't spin, makes clunking noise, drains fine
If it agitates fine , with normal noise , drains with lid closed , then the problem is probably the transmission .
Posted on Aug 02, 2009
canbruce75
  • 1776 Answers
SOURCE: Kenmore 80 Series washer won't agitate/spin
Check out the video at the link that I'm attaching and see if it leads you in the right direction toward changing the lid switch. The switch should be checked for loose/corroded electrical connections and checked for continuity using a multimeter or ohmmeter. A lack of continuity means a bad switch. If bad it will have to be replaced, Sorry for your trouble and I hope this helps. Best wishes.
http://www.youtube.com/watch?v=fC8SY3cU1Yc&feature=PlayList&p=A8EAB62928245279&playnext=1&playnext_from=PL&index=61
Posted on Sep 08, 2009
SOURCE: Whirlpool LSB6300LW top load washer
We are trying to by-pass the lid swithc in our Whirlpool top loading washer. There are 2 gray wires capped together and one drker gray & red wire capped together. Which wires do we use to by pass the swith?
Posted on Mar 06, 2010
Kenmore 27 in. laundry center won't spin out
The lid may not be mechanically closing the switch even though the switch was replaced
Apr 11, 2013 | Washing Machines
Washer won't spin or drain
if it can't drain then it won't spin,something could be jammed in the pump,the clutch isn't falling on the trans. what does it do when it goes into spin cycle'do you hear any noises.when it does go into spin cycle listen if nothihng hapeens open the lid and close it listen to see if the clutch falls
Mar 06, 2013 | Whirlpool Ultimate Care II LSQ9549L Top...
Why won't my model 110 washer spin?
if it still has water in it check the lid switch,close the lid then open it a few inches and close it again,when you do this if you don't hear a clicking sound the lid switch is bad.watch this video and hope this helps
http://www.youtube.com/watch?v=MFsvLiuTniU
Sep 16, 2012 | Kenmore 18.3 cu. ft. Top Freezer...
Hoover elite 700 washing machine won't spin
There are several reasons that a washing machine won't drain or spin. The cause could be something as easy as a clog or something difficult that will need a licensed repairman. Start with the simplest possible cause and work down to the more difficult causes.
INSTRUCTION BELOW
# A washing machine won't spin if the water can't drain. Check hoses for any kinks or clogs that may prevent the water from draining. If a hose has kinks, try to straighten out the kinked hose. If it can't be straighten sufficiently, replace the hose. If hoses are not kinked, check for clogged hoses. This can be done by using the screwdrivers to remove the hoses and looking for clogs or running a water hose through the clogged hose to remove the clog. Use the rags and bucket to clean up the water that comes out of the hoses when they are disconnected. Once the clog is cleared, put the drain hose back into place. The washer should drain and spin now if a clogged or kinked hose was the problem.
# 2 If the washer still won't drain or spin, check to see if the lid is not closing all the way or if the lid switch is not clicking into place. Close the lid and make sure that it closes all the way down. When the lid closes, the lid switch should click. If there is no clicking sound, then the switch may need to be replaced. Follow manufacturer's directions for replacing the switch. If the lid does not close all the way, visually check for signs that the lid is bent. If bent, try to bend it back into place.
# 3 Loose or broken belts could also prevent a washing machine from draining or spinning. Pull the washer away from the wall and, using the screwdrivers and wrenches, remove the back panel. Using the flashlight, visually check for any broken or loose belts. Replace any broken or loose belts. Although replacing washing machine belts is difficult, anyone who has replaced belts on a car, lawn mower or even a bicycle chain should be able to accomplish the task.
# 4 Another possibility for a washing machine to not spin or drain is the pump. With the back panel still off the washer, check the pump with the voltmeter to ensure that the pump is getting power. If the washer is getting power, turn on the washer and listen to find out if the pump is running but the water is still not draining. It may be necessary to remove the pump and clean it or to replace the pump with a new one. Once the pump is replaced, turn on the washer to determine if it will now drain and spin.
# 5 If all of the above steps fail to produce a washing machine that drains or spins, then it is time to call a professional repairman. Use the screwdrivers and wrenches to replace the panel on the washer and push it back against the wall
Regards.
Jan 05, 2012 | Hoover Washing Machines
Why wont my philco washing machine drain or spin
Many washing machines won't spin or drain if the lid isn't closed. It could be that the switch detecting the lid close position isn't working or the tang that presses the switch isn't depressing the switch enough. Check to see if the lid is closing all the way, if so, then locate lid close switch and pressing on the switch with a Q-tip. If other functions stop when the lid is opened and work when the lid is closed then you have another problem. The problem could be in the wash cycle switch, try spin and rinse all the different settings.
Nov 21, 2011 | Washing Machines
Won't spin out water but pump works
1.A washing machine won't spin if the water can't drain. Check hoses for any kinks or clogs that may prevent the water from draining. If a hose has kinks, try to straighten out the kinked hose. If it can't be straighten sufficiently, replace the hose. If hoses are not kinked, check for clogged hoses. This can be done by using the screwdrivers to remove the hoses and looking for clogs or running a water hose through the clogged hose to remove the clog. Use the rags and bucket to clean up the water that comes out of the hoses when they are disconnected. Once the clog is cleared, put the drain hose back into place. The washer should drain and spin now if a clogged or kinked hose was the problem.
2.If the washer still won't drain or spin, check to see if the lid is not closing all the way or if the lid switch is not clicking into place. Close the lid and make sure that it closes all the way down. When the lid closes, the lid switch should click. If there is no clicking sound, then the switch may need to be replaced. Follow manufacturer's directions for replacing the switch. If the lid does not close all the way, visually check for signs that the lid is bent. If bent, try to bend it back into place.3.Loose or broken belts could also prevent a washing machine from draining or spinning. Pull the washer away from the wall and, using the screwdrivers and wrenches, remove the back panel. Using the flashlight, visually check for any broken or loose belts. Replace any broken or loose belts. Although replacing washing machine belts is difficult, anyone who has replaced belts on a car, lawn mower or even a bicycle chain should be able to accomplish the task.
4.Another possibility for a washing machine to not spin or drain is the pump. With the back panel still off the washer, check the pump with the voltmeter to ensure that the pump is getting power. If the washer is getting power, turn on the washer and listen to find out if the pump is running but the water is still not draining. It may be necessary to remove the pump and clean it or to replace the pump with a new one. Once the pump is replaced, turn on the washer to determine if it will now drain and spin.
5.If all of the above steps fail to produce a washing machine that drains or spins, then it is time to call a professional repairman. Use the screwdrivers and wrenches to replace the panel on the washer and push it back against the wall.
Thank you for using FixYa and please don't forget to rate me.
thanks,
Reymond
Oct 18, 2011 | Maytag Washing Machines
Why is my frigidaire washer not spinning?
  1. Stopped Mid-cycle
    • If your Frigidaire washing machine started spinning, but then stopped, verify that the power cord is still connected to the outlet. See if the outlet blew by plugging in a different appliance into the outlet. See if you blew a fuse. A blown fuse usually is either black or has broken wires. Replace the fuse. If you have a circuit breaker instead of a fuse box, reset the circuit breaker if it's been tripped. Check the lid switch, which is located inside the main housing of the washing machine, near the door frame. If the switch is burned out, order a new part from a Frigidaire parts dealer.
    Pump
    • The pump's sole responsibility is to remove water during the spin cycle. If the pump isn't working properly, see if it's clogged with debris or clothing. Use needle-nose pliers to remove these items. Check the pump pulley, which is connected to the pump. This component must move freely for the pump to work. If it won't turn, purchase a new pump pulley since you can't usually fix this component.
    Lid
    • Check the door latch assembly if the door isn't closing correctly. If any of these components are broken, order a new part from a Frigidaire parts dealer. If you do not, the washer won't start spinning since it believes the door isn't closed. Your Frigidaire washing machine won't start the spin cycle until the lid or door is closed. Always close the lid, and remove any items preventing the lid from fully closing. Always close the dispenser drawer.
    Additional Concerns
    • Never over- or under-load your washing machine. Your Frigidaire washer may not enter the spin cycle if the load is too large, since this can damage the washing machine. Remove a few pieces of clothing. If the load is too small, add a few similar items to the washing machine. Check the internal belt, drive motor and motor coupling. If any of these components are broken or very worn, they may not work properly, preventing the washer from entering the spin cycle. Order replacement parts from a parts dealer. Check the tub and basket bearings, and get new ones if the current ones have broken components or are defective.
Sep 27, 2011 | Washing Machines
On final spin,motor works but not spinning out. Acts like something is jammed up
o . Hello,
There are several reasons that a washing machine won't drain or spin. The causecould be something as easy as a clog or something difficult that will need alicensed repairman. Start with the simplest possible cause and work down to themore difficult causes.
INSTRUCTION BELOW
ยท A washing machine won't spin if the watercan't drain. Check hoses for any kinks or clogs that may prevent the water fromdraining. If a hose has kinks, try to straighten out the kinked hose. If itcan't be straighten sufficiently, replace the hose. If hoses are not kinked,check for clogged hoses. This can be done by using the screwdrivers to removethe hoses and looking for clogs or running a water hose through the cloggedhose to remove the clog. Use the rags and bucket to clean up the water thatcomes out of the hoses when they are disconnected. Once the clog is cleared,put the drain hose back into place. The washer should drain and spin now if aclogged or kinked hose was the problem.
2 If the washer still won't drain or spin,check to see if the lid is not closing all the way or if the lid switch is notclicking into place. Close the lid and make sure that it closes all the waydown. When the lid closes, the lid switch should click. If there is no clickingsound, then the switch may need to be replaced. Follow manufacturer'sdirections for replacing the switch. If the lid does not close all the way,visually check for signs that the lid is bent. If bent, try to bend it backinto place.
3 Loose or broken belts could also prevent awashing machine from draining or spinning. Pull the washer away from the walland, using the screwdrivers and wrenches, remove the back panel. Using theflashlight, visually check for any broken or loose belts. Replace any broken orloose belts. Although replacing washing machine belts is difficult, anyone whohas replaced belts on a car, lawn mower or even a bicycle chain should be ableto accomplish the task.
4 Another possibility for a washing machineto not spin or drain is the pump. With the back panel still off the washer,check the pump with the voltmeter to ensure that the pump is getting power. Ifthe washer is getting power, turn on the washer and listen to find out if thepump is running but the water is still not draining. It may be necessary toremove the pump and clean it or to replace the pump with a new one. Once thepump is replaced, turn on the washer to determine if it will now drain andspin.
5 If all of the above steps fail to produce awashing machine that drains or spins, then it is time to call a professionalrepairman. Use the screwdrivers and wrenches to replace the panel on the washerand push it back against the wall.
Please rate four thumb.
Thanks and good luck.
Sep 13, 2011 | Washing Machines
Good evening, My Roper washer RAX4232PQ0 will not spin...it seems to drain OK but won't spin...can you offer any help? Thanks!
I am thinking if all works good except won't spin, it is your lid switch. Under your washer lid you will notice a peg of some sort that when lidnis closed goes into a slot/hole and that triggers the spin cycle. That is in lamens terms know as a safety idiot switch. It is designed so when the washer is spinning at those high speeds,na child or not to smart adult does not open lid and put hand in while spinning. SO, if switch goes out, of course it won't spin. Switch is cheap , under 20 bucks at any appliance parts store, and they even can tell you at store how to putnin yourself by showing on one of there washers on display. Let me know if I nailed it!! Thanks Mike
Jun 09, 2011 | Roper RAX4233PQ Top Load Washer
Machine won't spin out the water in the clothes,has to be wrung by hand..What would you think the part is that's holding this up?
Check the washer lid safety switch . Sounds like it is a simple switch for when you close the lid it allows to spin only when lid is closed. It is a safety switch for spinning to not operated if lid is open durring spinning cycle. It's maybe a 20 dollar part and easy install.
May 07, 2011 | Washing Machines
Washing Machines Logo
10 people viewed this question
Top Washing Machines Experts
