Question about Binks Air Tools & Compressors
Wont fan out - Binks Air Tools & Compressors
My oven wont turn off
The thermostat for the fan is shorted out
Jan 28, 2016 | Ovens
Fan wont come on
Make sure that the fan is 12 DC Volts.. If that is 12 DC volts?... you can connect that fan to power supply of your desktop wired color (+)yellow and ( -)black. If its doesnt work... that fan is defective.
Aug 16, 2014 | Computers & Internet
Heater fan wont turn on
first check the fuse for the blower fan. if ok check if there is current going to the fan plug on top of the passenger kick panel or behind the glove compartment if there is current change the blower fan and the fan resistor next to it.
Jan 09, 2014 | 2004 Dodge Caravan
Ac fan wont blow
I would disconnect the fan connector and use contact cleaner to clean the connection. Usually corrosion. Also fan might be going bad (Common Problem).
Mar 27, 2013 | 2000 Saturn L-Series
2004 grand marquis fan quit working..replaced fan but still wont work
is this the blower motor fan for you heating and A/C or the cooling fan cooling fans have a relay blower fans are fused but controlled from switches inside as well as fuses
Aug 27, 2012 | 2004 Mercury Grand Marquis
I have a 901650 intertherm and the fan outside turns on but the air conditioner inside does not work. What could it be?
!st off, do you mean the indoor unit does nothing period as wont run? or wont cool?if it wont run, the checking breakers/fuses etc is a waste of time, as the transformers clearly providing the 24 volts to operate the contactor outside.If you switch your fan to "on" does the fan run?if not, check fan relay, or board or motor/cap etc.If the fan does run with the fan switch set to on, but not in cool mode, the auto function that sends power to green /fan via yellow?cool terminal in the tstat is open and not allowing the 24v to energize the fan relay.
Feb 24, 2012 | Heating & Cooling
Processor fan wont work.
Hi tenfive64,
Try another fan in the cpu power slot, to see if there is no power getting to that source. If the fan turns on, well! Something ain't right with the fan. If it doen't then you'll need a power extension connector to reach for another fan power source on the board. DON'T hook it up to a non-fan power source, you will fry the fan, if not the board.
Good Luck,
Mark
Dec 16, 2009 | Compaq Computers & Internet
Oven fan wont work
You need to determine if you are getting a mains feed to the fan motor, if not, then you need to trace the wires bcck to source and work from there,
If you are getting a 240 volt supply, then the new fan is faulty.
Hope this helps you.
Dec 15, 2009 | Ovens
Radiator fan
either the fan is bad or you need a temp. sensor, to check fans, run a wire from positive on fan wires to positive on battery, if need be ground fans!! if they are ok the fan should start running,,
Sep 01, 2009 | 1991 Ford Mustang
Air Tools & Compressors Logo
Top Binks Air Tools & Compressors Experts
JOHN LAPIER
Rick Amick
Rick Amick
john h
Are you a Binks Air Tool and Compressor Expert? Answer questions, earn points and help others
