Question about Gestetner Office Equipment & Supplies
Functional problem gestetner 2000le sc:545 - Gestetner Office Equipment & Supplies
drichards
  • 87 Answers
SOURCE: Gestetner DSM616
Turn the machine on, and press clear modes, 1, 0 ,7, and press and hold the clear stop key. It will beep, and a menu will appear. Select copy SP (1), and then select data log (#7) scroll until you get to 7807 (sc/jam counter reset). select it, and press execute. exit all the way out, and recycle the power. If it comes to ready, it should be ok. If it happens again after that, there is a fuser problem of some sort.
Posted on Mar 08, 2008
SOURCE: Ricoh 3006
go to service program 5-810 ( sc reset) press on, turn off the machine an the turn on again. The service code should be gone, if it come back again check for a paper jammeed or wrapping the upper
fusing roller if this is not the case replace the thermistor;
Good luck
Vittorio
Posted on Dec 16, 2008
  • 86 Answers
SOURCE: Gestetner 3218 Aficio 180 Fuctional Problem SC 543
Enter SP mode - Clear button (yellow key), 1 0 7 and hold and press stop button (orange key).
Enter SP5-810 (SC code reset) and select “1”.
Then hold down the “Photo mode” key and the enter key(hash) at the same time for at least 3 seconds (it is not necessary to turn the main switch off andon). If the machine beeps 5 times, the reset was successful. If it only beeps twice, the reset failed, and you need to repair the machine.
Possible causes are the fusing thermistor in the fuser unit, or the power supply unit defective.
Good luck and please rate me, thanks.
Posted on Jan 17, 2009
SOURCE: Gestetner DSm615 giving error SC:552,How do i clear it
Are you sure of the code? I don't have the exact manual for that, machine but the number seems strange. "5xx" errors are usually related to the fuser, so could be a bad lamp, thermistor, or fuse. see note to reset (if there is not a problem) as follows:
There are 2 levels of service call conditions.
Level Definition Reset Procedure
"A"
To prevent the machine from being
damaged, the SC can only be reset by a
service representative.
The copier cannot be operated at all.
Enter SP 5-810 (SC code reset) and
select “1”. Then hold down the Original
type key and the OK or ! key at the
same time (this does not require the
main switch to be turned off and on).
Posted on Feb 16, 2009
joel_baleta
  • 155 Answers
SOURCE: ricoh 1045 showing code SC545. First was SC 546
SC545 and SC 546 are fuser temperatyre error. pls. check thetmistor/ thermostats, connectors if thernistor are deffective replace thermistors. after replacement or checking of this parts do the SC reset. 107 # turn off copier then on after 5 sec.
Posted on Jan 26, 2010
The Ricoh Mp 2000 copier displays "Error occured Sc:545 Functional problem"
It's a fuser overheat error enter service mode to clear, if it comes back service call ( push in sequence clear modes(yellow) 1 0 7 hold down stop for 5 or so seconds, screen will change, power down, red switch. -Carl
Jan 30, 2014 | Ricoh Aficio MP 2000 Black and White...
Our Gestetner MP 2000Le have an error sc551 and we can't troubleshoot it using the (Clear mode+107+hold the Clear/stop button) ..can you pls. advice us for other options ? tnx
Enter in the service mode: Clear(yellow key) 107 press/hold Clear/Stop more 4 second,enter in the SP mode open the front cover ,turn OFF the copier,wait 1-2 minutes close the front cover and turn ON the copier.
Jan 30, 2013 | Ricoh Aficio MP 2000 Black and White...
Error SC 545
that mean thermistor is defective due to some one try to clean it from incenerat toner 2- halogen lamp is defective
Jan 31, 2011 | Gestetner DSc424 Color Copier
Sir, My copier model RICOH MP 2000Le shows error . ADD TONER & some time it shows SC 302
sc 302 - charge roller current leak. strip the drum unit (dmu) and clean the unit
Sep 04, 2010 | Ricoh Aficio MP 2000 Black and White...
Gestetner 3245 copy machine
You have a problem in the heater, sensors detected temps over 220c for more than 6 seconds. It will be an expensive repair. Most likely around $400 parts plus labor. Not something for the average Joe to troubleshoot.
Aug 21, 2008 | Gestetner Office Equipment & Supplies
12 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
CheckitRight
CheckitRight
 Larry
Larry
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
