I have a seimens siwamat xb 660 washing machine. front loading. my kid broke the door locking handle. i opened it up and the handle parts fell out. i am looking for a scematic to put it back together again. any advice??
  • p_jamula Jun 20, 2009
    sorry!!!! i already look up that site and they have nothing to offer immediately... i am looking for a quick solution please...
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 123 Answers
Well the best advice i can give is, dont use a scematic, just dig in and figure it out, its actually easier that way, trust me, i have repaired many many household appliances without using a scematic, and im only 15, if i can do it, you can do it to
Posted on Jun 20, 2009
    Sergeant:
  • 326 Answers
2instructions.com/search.php?...SIEMENS...SIWAMAT%20XB%20660
Broke handle off of siemens TOP WD1200 champion, the settings are all in chinese and my clothes are locked inside. help?
This is a common and easily fixed problem. The door should NOT be opened after the wash is completed. You have to wait for AT LEAST 2 minutes to try the door, do not use force. There is a built in mechanism for most front loaders to delay the door opening, so be patient.
If you have used force you have already damaged the door lock, so replace. You are lucky if the door can be opened after the lock sign goes off - otherwise you just have to change the door lock.
Click if helped.
Mar 30, 2013 | Siemens Washing Machines
I have a broken door catch for a Siemens Siwamat XB 1061. Can I get a replacement part
I feel for you because we have exactly the same problem : our door broke, the handle in fact. Everything else works wonder but the screw driver trick is bound to give in one day eventually and we'll be left with no washing machine at all. Has anyone found any infor on the door anywhere? thanks guys
Mar 19, 2011 | Siemens Washing Machines
Need a new door opening handle?? the handle broke
You should be able to order one from Splendide. In the meantime, try using a screw driver to manually push the door release button.
Michael Lee
Thor Appliance Company
www.thorappliances.com
Sep 22, 2010 | Splendide 2000S Front Load Washer / Dryer
Door is locked, handle is broken, how do I open the door?
YES!!! Samething happened to me!!!
I haven't fixed it yet BUT I know how to get in~You have to take the handle off...completely. May have to break the plastic...
You'll need 2 flat head screwdrivers.
You have to push the metaal part that would have been attached to the plastic handle and then pull the door out where it meets with the machine. Like where the grey inner seal is. Be gentle but firm handed. Think push with one driver~pull out with the other. Be patient as it will be fustrating the first time.
Good luch tho!!!
~yve.
Mar 05, 2010 | Equator EZ 3612 CEE Front Load...
Can't open the kick plate of my samsung j845 washing machine
Happened to me too today. As I was pulling the handle, a piece inside snapped. The handle felt loose, as though it wasn't pulling the catch. To get the door open, I used a screwdriver. I pulled the handle as far out as I could, so that I could get the screwdriver in. The dark black metal part has to be levered away from the washing machine - in the direction the door would open. That will release the catch and then the door will open.
After the door is open, the challenge is to remove the handle. You'll need to undo all 10 (or so - from memory) of the little screws, so that the inner part of the door comes off. Be careful as you get to the last one - things will fall away. The handle and the small broken tab just fell out for me. Once the handle is out, you can put the door back together again. I use a small hex key to help open (and close) the door. With no handle, the catch springs a bit too far over for the door to close, so you'll need something (e.g. 1/8" hex key) to hold it over a little. So now, I can use the washing machine while I try to find a new part.
Apr 11, 2009 | Washing Machines
Door handle of washing machine broken
if clothes are still in washer? and machine has finished cycles? then handle broke so unable to open ??? your best option is to unplug/ and if necessary disconnect water supply hoses then remove the top screws from rear panel which also secure the top panel as you will observe ? then pull backwards top panel and loft off ? you now have access/visual of the door catch inside front machine look?? at the catch and you will see how it locks ? you can lever the catch gently and door opens to fit a new door catch is easy diy and not expensive if you are confident usual problem these break ? is the time delay micro switch sticks with age /moisture try dw40 and work plunger b4 you refit door back after replacing handle/catch assy
Feb 16, 2009 | Hotpoint Aquarius WD640 Front Load...
Broken door handle for a Thor washing machine
there r 2 ways to get the door open 1)use a normal knife and place in front of the door handle push it in and it should open 2)pull the plug out take the lid off now place your hand down to where the catch goes into the washer using your fingers u should be able to pop it open with a bit off fiddling
Dec 15, 2008 | Hotpoint Aquarius WD640 Front Load...
Indesit W 125 X Washer Handle Broke Off and Door Will Not Open
use something lopng and thing, a thin screwdriver operhaps. Pull the metal bar ( part of the spring) to the left. When this is fully to the left push the white plastic part in and jiggle about util the door comes off. Might be easier with sumone to help you pull the dor out as you uch in
Oct 22, 2007 | Indesit WA 125 Front Load Washer
Washing Machines Logo
368 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
