Question about Utilitech 1-HP Cast Iron Shallow Well Jet Pump PPSWJ100
I have a utilitech 1 1/2 hp in and above ground pool pump it has plenty of power and won't run
It has the necessary 220 volt going to it
Changeing 115volt to 230 volt
Most power Flo pumps run above ground pools and run on 115v only.You can look at the wiring diagram on the motor label to see if it is convertible, it will show wiring configurations and amps for both 115v and 230v. If not, it is a 115v motor only.
Sep 11, 2013 | Hayward Power Flo Lx 1 Hp Pool Pump Sp1580
New Versa 130 won't stay lit
if wired 120 volt then make sure wired correctly they come wired for 220 volt if 120 volt have to change wires if wired correctly change black and white its not rectifing
May 18, 2012 | Raypak Pool & Spa
Pentair superflo electrical wiring
if 220 volts 2 blues 1 to L1 one to L2 green to ground or case
Feb 08, 2012 | Pentair Super Flo 1 Hp Pool Pump 340038
I have a Hayward Power-Flo LX SP1515-Z2-EBK3 that is being used to pump water through 2-4x8 solar water heater panels. The pump intake is 1 1/2 inch, discharge out is also 1 1/2 inch. The pump is located...
I have a 3/4 hp hayward pumping thru solar panels, too. 1-1/2 discharge thru 50 ft of 2inch pipe, up 12 ft then thru (4) 4x12 panels. Mine is on 115 volts ac.
You have plenty of pump and when you run a pump with low flow, amperage is low. You are not tripping your breakers, it sounds like the pump is overheating. Is it hot to the touch when it shuts down?
Do you have an ammeter so you could check your amps?
What size wire is running the 60 ft to the pump?
I don't have any other ideas to share.
Sep 06, 2011 | Hayward Power Flo Lx
We have a proline above ground pool pump. Model PE71 III V. Been working fine the last two weeks. We vaccumed pool and then pump just stopped working. We don't hear any there is no...
at home depot the sell a pen that beeps at the sight of voltage (sensor) 12$ good house hold tool to have.. check the cord running to pump see if the pen beeps when held against cord if its a 110 set up the pen beeps and youve the 110 V needed to run the pump if 220 V a bit different .. if left powered But not running in a few min, touch motor housing the metal part of this unit. is it hot as a grill (internal winding problem) or still cool .. Motors are a wear item like tires on ones car.. motors are inexp like 110$ for a 1 hp unit
Jun 04, 2011 | Hayward 3/4hp Super Pump Inground Pool...
How to install hayward motor?
Just the motor? Three things you must consider: There are 4 bolts that fasten the motor to the pump housing. You need to determine 110 Volts or 220 volts - 220 will run the pump more efficiently. Bonding. Your motor must be bonded to all other metal parts of your pool system.
Aug 22, 2010 | Hayward 1 Hp 2 Speed Super Pump Inground...
When on filtration not a strong pump at all
Is this a 220 volt pump running on 110 volts? Check it out ...
If possible, you should run it on 220.
Aug 01, 2010 | Hayward Power Flo Lx 1 Hp Pool Pump Sp1580
Looking for a diagram on a hayward pool pump electrical wiring model super 11
What specifically are you looking for (beside the fact you asked for a diagram)?
It should be setup for 220 Volts ... the only thing inside is a start cap.
Can you tell me more? I maintain 5 2 and 1 1.5 hp such pumps.
Oct 14, 2009 | Hayward Super Pump 1 1/2 - Hp for In...
Utilitech 1-HP Cast Iron Shallow Well Jet Pump PPSWJ100 Logo
228 people viewed this question
Top Utilitech Plumbing Experts
Paul Carew
Are you an Utilitech Plumbing Expert? Answer questions, earn points and help others
