Question about Miele T9800 Electric Dryer
Miele t9820 dryer does not turn - Miele T9800 Electric Dryer
5 Suggested Answers
  • 291 Answers
SOURCE: pop the top miele t9820 dryer gas
Open the door, at the top of the recessed door opening you will see two round plastic caps. Remove these and you will see screw behind that you have to remove. Some models the caps are on the right and left hand sides. Slide the top towards the back after removing screws and the top will lift off. Good Luck, Appliance Specialists
Posted on Jan 06, 2010
paulc118
  • 15 Answers
SOURCE: how do i replace the dryer belt
Don't mess with it. Call Miele. The front seal is probably worn and caused the belt to break.
Posted on Feb 27, 2010
  • 9 Answers
SOURCE: i have miele gas dryer
The problem is likely with the centrifugal switch on the dryer motor. This switch connects the start winding of the motor which provides additional torque at startup. Once the dryer is up to speed, the switch disconnects the start winding. If it malfunctions, the dryer will not turn and the motor will hum. By spinning the drum, you are providing enough torque for the start winding to be able to take over and bring the dryer up to speed.
You may be able to correct this by simply lubricating the centrifugal switch which may be sticking. I am not sure if the centrifugal switch is replacable, or if a new motor is necessary if lubricating does not solve your problem
Posted on Nov 28, 2010
  • 128 Answers
SOURCE: miele t9820 service manual
did you get your software update done during the campaign? Call miele for the software update. while the tech is there, ask him any question you want. it is free of charge, and it is a safety issue on that dryer. 800 999 1360. dsc software update.
Posted on Jun 27, 2012
Miele dryer doesn't stop
Stuck buttons have tech inspect
May 17, 2014 | Miele T9820 Gas Dryer
Miele t9820 service manual
May 02, 2012 | Miele T9820 Gas Dryer
The dryer doesn´t work
I had the same problem with my dryer. The Miele technician came and took a look at it. There was nothing wrong with any parts. My vent pipe was kind of crumbling, so he replaced that. He then scrubbed and washed the lint filter with dishwasher soap and
the green scrubber, He also did a PC update of the firmware. My
unit already had the latest version, but he did erase all the error codes.
After all these rather simple steps the dryer started working like a charm.
He said the most probable caused was gummed lint filter because of using the dryer sheets. Miele dryers are designed to prevent static cling and he advised not use these sheets as they contain wax-like substance.
I would suggest scrub cleaning the lint filter first and see if that helps.
Aug 02, 2010 | Miele T9820 Gas Dryer
Miele gas dryer drum won't turn, but turns on like it works
check out my tips on dryers
the tensioner and belt needs to be replaced more than likely
May 09, 2010 | Miele T9820 Gas Dryer
Clean filter / vent indicator stops unit after T9820 MIELE GAS DR
Call Miele and schedule a PC update. When the technician comes he will do the update, if needed, and will reset the error codes.
Apr 04, 2010 | Miele T9820 Gas Dryer
How do i replace the dryer belt on my t9820 miele gas dryer
Feb 04, 2010 | Miele T9820 Gas Dryer
Pop the top miele t9820 dryer gas
Jan 06, 2010 | Miele T9820 Gas Dryer
Dryer drum won't turn but dryer will turn on like its working. no fault notice or any indicator something is wrong.
Check the drive belt. Pop the top (spring loaded) to check. If broken, remove the front panel for full access.
Thanks for your quesiton
Jan 05, 2010 | Miele T9820 Gas Dryer
Miele T9820 runs except no heat
you have probably blown your thermostat especially if your condenser is blocked and hasn't been cleaned. this causes the unit to over heat and to protect the heater element the thermostat blows and breaks the electrical circuit. you will need a Miele service tech or service agent to repair the unit.
Sep 29, 2009 | Miele T9820 Gas Dryer
Check vent/lint indicator alert
Contact Miele 1800-999-1360 for a new blower fan
Jun 07, 2009 | Miele T9820 Gas Dryer
Miele T9800 Electric Dryer Logo
79 people viewed this question
Top Miele Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Are you a Miele Dryer Expert? Answer questions, earn points and help others
