Question about Mitsubishi VS-50605 50" Rear Projection Television
Convergents lines turn tv on , 10 seconds later , it turns off
SOURCE: VS-60111 turns off on its own after few hours
I would say throw it away and get a new TV, they are cheap these days. Plus, everything is going digital next year, so it's time for a change.
Posted on Jul 26, 2008
  • 2920 Answers
SOURCE: mitsubishi vs-60719
yourpower supply is weak
Posted on Aug 22, 2008
  • 14 Answers
SOURCE: my tv ws-55819 tv won't turn on it cliks on but it won' syat on
ok when the power is plugged in hold down the menu + device buttens for five sec what is the error code there should be two sets of numbers....
like 1 pause 2 let me know and i'll see what i can do!
Posted on Feb 10, 2009
SD Tech
  • 14553 Answers
SOURCE: TV turns on, then turns itself off about 2 seconds later.
set has a self diagnostic---after set does shut down press and hold MENU AND DEVICE(INPUT) buttons on front of set for 5 seconds----if 2 blinks, a pause and 2 more blinks: this is short protection error code---The set does use 2 Stk394-250 and each is protected by a pico fuse in the power supply---if either fuse is blown the set will shut down(it detects no voltage or missing voltage;) It is not uncommon for a shorted IC to cause this problem; if you locate the STK's look carefully at the resistors around them---if any are discolored or burnt---you have found your problem.
Posted on Aug 17, 2009
SD Tech
  • 14553 Answers
SOURCE: Alright so I've had this TV for about 10 years and
I have answered this as this question appears here for some reason several times. see previous answer.
Posted on Apr 29, 2012
Hello, my 55513 tv when turning it on was blurry. after a few minutes it became clear. shut off and came back about 3 hours later and it was blurry again for about 10 minutes. about 10 minutes later it...
in the customer menu select convergence when set acts up---look to see if grid of lines is skewed, see some photos and let me know if your problem anything like this..........
Apr 08, 2012 | Mitsubishi WS-55513 55" Rear Projection...
If I turn the tv off an try to turn if on again the screen is either solid green, multiple colored lines, or is constantly blinking. If I turn the tv on and off, it will eventually go to a normal screen...
The tv having a problems known as a convergence problems,it dying,going to be dead sooner or later.The tv colors lines R,B,G mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dying going to be dead.These parts on the tv convergence board,must replaced these parts to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Oct 28, 2010 | JVC AV-48WP30 48" Rear Projection...
Turns off after 30 seconds
i think the convergence amps are weak, or the akb circut has caused the tubes to go bad, google your model number to see if it is in the tube problem. sony made some projos w/ bad tubes in them. tv lasts only three or four years,no cause i had one
Jul 10, 2009 | Sony KP-65WS500 65" Rear Projection...
Turn on the tv a few seconds later it shuts the power light blink
Replace both of your convergence ICs they are STKs big black ICs will have part number on them.
Jun 19, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Turn it on and turns off again
sounds like your powersupply is bad. usually reasonable repair. 150-250 parts and labor
Jun 05, 2009 | Mitsubishi WS-65907 65" Rear Projection...
My Panasonic CinemaVision 47" won't turn on.
Thats the error for the convergence. The following repair kit will usually repair that. The kit contains the parts and instructions with pictures on how to do the repair. Heres a link to the kit for your model. http://servicemanuals.vstore.ca/product_info.php/pName/panasonic-projection-tv-convergence-repair-kit-2/cName/convergence-repair-kits
May 17, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Picture(Color Convergence)
Go to menu look for convergence on menu if it is not on menu then you have a open fuse located next to Flyback Transfomer on deflection board.
Sep 18, 2008 | RCA D52W19 52" Rear Projection Television
Curved horizontal lines in picture
Its Sounds like Convergence Circuit,If you take the Back off and look on the right side you should see a Board with Big black Ics Mounted beside a Large Heatsink,Mark the wires where they go and Make sure the POWER is Off Pull the Board out and Inspect the Connections from the ICS,you find Circle Breaks,They need to Be resoldered and That should fix the Set....
Jul 20, 2007 | Samsung PCK5315RX TV
On/Off Tv
The first suspect on a LCD projection if yours is a KF50WE610 is the lamo itself. The second issue with the blue line is a possible bad LCD panel. There is NO convergence settings on a LCD set.
May 06, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Mitsubishi VS-50605 50" Rear Projection Television Logo
19 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
