Question about AOC 2219S1 22 in. LCD TV
All graphics are stretched out on my LCD monitor
I work with graphics often, and this has become a pain in my side.
I am aware that I can change the screen resolution, however this does not solve my problem. The ratio of the screen stays the same, and it's wrong in the first place.
Is there a way I can adjust this "wide-screen" mode to a "normal view"?
I have a Windows Vista, by the way. I don't know if that information is helpful or not...
2 Suggested Answers
  • 10 Answers
SOURCE: Photos stretched
may be problem with graphics card.
lower your resolution
Posted on Jul 07, 2009
Stretching problem
You need to change the properties of ur graphics and change its resolution and see what happends.
The properties may occur by right clicking on desktop and goto the graphics properties next move to advanced mode under graphics properties.
May this helpful to u and enjoy.
Apr 21, 2014 | ASUS LCD Monitor
Getting 4:3 aspect ratio
off the monitor for few hours and use it
tell me what happens then
May 15, 2008 | Computers & Internet
Stretched screen
For best graphics and zero stretch select the highest resolution that your LCD supports. Which is the resolution of 1440X900
Right click on your desktop and select properties.
Click the Settings tab.
Slide the resolution Bar to the resolution of 1440X900
Also select (Highest 32Bit) colour quality on the right of the resolution bar.
Click Apply then Ok.
If you are not able to select the resolution of 1440X900 then you should update your graphics card drivers to the latest version.
To download the latest drivers for your graphics card click here.
Select the following:
Geforce
Geforce 5 FX Series
Geforce FX 5500
Select your operating System
Select your prefered language
Please be sure to rate this session.
Take care!
Norman-Wynne Damstra
Nov 14, 2011 | Belinea Maxdata 1925 S1W LCD Monitor
Vertical lines on inspiron 9300 laptop lcd
The possible reasons for this could be;
1.)A loose connection between either the graphics card and the computer mainboard or between the Graphics Card and the Computer Monitor.
2.)Your LCD monitor has become faulty and either needs to be repaired by a technician or replaced.
3.)Your graphics card need to be cleaned, clean the gold finger contact on the card.
However in my experience I would say that the monitor has become faulty, try this monitor on another computer and if it still displays vertical lines then you know that this is the case.
If your monitor works on another computer then I would say that your computer or Graphics card is having some troubles.
Overheating plays an important role here.
Kind Regards
damnor01
Feb 03, 2011 | Dell E173FPb 17" TFT LCD Monitor
Monitor wont support 1600x1200 resolution. it displays a four inch wide bar down the right side of the monitor. It worked fine for two years and all of a sudden this.
I had a similar problem recently, green bar down middle which became "scratchy" and would come and go. I fixed (I hope) by unplugging the plug to the internal LCD panel assembly, cleaning with IPA, and re-plugging. All the covers and metal shields had to come off to do this though, a bit of a pain, and risky to the front of the panel.
Or it could be a timing issue, I know the L2035 only likes to be fed the right graphics "timings" over DVI and VGA. If out, you'll end up with an offset picture that can't be fixed by adjusting position in the monitor's menu. Re-set to standard graphics driver timings and it goes away.
Oct 06, 2009 | HP L2035 20.10" LCD Monitor
Can't change W to H ratio
use another monitor crt not LCD. adjust first the resolution. then connect again to your acer LCD. or you can auto config your acer from menu.
May 29, 2009 | Acer X223WB 22" WIDESCREEN LCD Monitor
How to stretch screen compaq tft5015
Right click the desktop - select graphic properties - you should have the option to stretch to fit or something like that. This could also be that your resolution doesnt match your monitor. usual wide screen monitor defaults are 1280/1024 or 1400/1068.. have a mess around and alter these - see which one fits.
Jan 25, 2009 | Compaq TFT5015 15" LCD Monitor
Stretched images
on your monitor there should be a auto resize. is it dvi? or hdmi or vga?
Jan 03, 2009 | HP w1907 LCD Monitor
Distorted screen
Youre problem is because when a widescreen monitor is fed with a signal that is not ws it stretches the image sideways making people look short and fat. The only way to really fix this is to make sure the graphics card is providing a widescreen resolution to the monitor. In this case the native resolution (the resolution the screen looks best at) is 1680 x 1050 . If you right click ur desktop and go down to properties and settings u want to change the screen resolution to a widescreen res.
Hopefully 1680 x 1050 ... if this is unavailable try 1440 x 900
If you have an nvidia graphics card you can also go to the nvidia control panel and change the resolution attributes. If the widescreen res isnt available u could also try the 'change flat panel scaling' and select the do not scale option.
Please note before starting any of this make sure u have the latest graphics and monitor drivers available.
May 27, 2008 | Acer AL2016W 20" LCD Monitor
Aspect ratio
increase the resolution to the maximum then check
Apr 17, 2008 | ASUS LCD Monitor
AOC 2219S1 22 in. LCD TV Logo
294 people viewed this question
Top AOC Televison & Video Experts
Raj Patel
Are you an AOC Televison and Video Expert? Answer questions, earn points and help others
