Question about Intel DG31PR Motherboard
Poor performance Hi I have upgraded may machine in Nov 09 with .. 1) Intel 2.66 C2D processor 2) Intel DG31Pr Board 3) Dynet 4 GB ram 667 freq. 4) Segate 320 SATA HDD I am using Windows xp service pack II , but overall performance is very poor. It takes 12-15 min to copy 1.5 gb data across the partition . Can you please suggest any tricks to diagnose the problem or any software ? Thanks , Vinayak.
  • rajmanevinay Jun 20, 2009
    Thanks rhinoking1 for your reply .
    Ohh.. okay if I don't want to use Vista then what will be the good solution ? may be upgrading service pack? (I can't give my pc to you in such bad condition ;) )
    I have also seen the temperature of board 87 d and processor 40 d is it normal ?
  • 85 Answers
First of all "DAMN" can I have your PC lol jk, you upgraded to high for XP you have a Visa compatible upgrade. That motherboard doesn't support XP servise pack II. sorry if you dont like Vista but this OEM is the only thing that will work properly now.
Posted on Jun 20, 2009
  • John Ashton
    John Ashton Jun 20, 2009
    You can try sevice pack lll, and upgrade your cooling or add another and see if this helps, I realy couldn't tell you if the temp is normal or not I'm more software than hardware. However the problem we face today is that almost all manufactures are makeing there products to work best with Vista makeing it hard to realy upgrade without useing this OEM. Vista realy isn't so bad once you learn it though. I myself perfer XP but have learned that there are somethings vista can do that XP can't. GL hope this info helps.
    New Friend:
    Problem Solver:
  • 5 Answers
I installed window7 also same proble
Posted on Nov 08, 2013
What type of RAM is compatible for my desktop pc for increasing speed ?
Your motherboard can support up to 8 Gb of ram, of type DDR2 667 MHz or 800 MHz. In practice 667 would do I believe as the performance difference is not great in practice. The board has 2 DIMM sockets for this.
It depends somewhat on your OS and what you want to do. I'd try 4 Gb first. Bear in mind that added ram doesn't actually speed the computer as such, only a faster CPU does that, but it will allow more windows to be kept open, and cut down on data swapping to virual memory on the hard drive.
Jun 05, 2016 | Intel Computers & Internet
HI I have a Gigabyte motherboard 945GCMX-S2, I have a 1GB ddr2 (667 Hz) hynix ram already installed ..to upgrade it i installed another 1GB dynet ram (666 Hz)..but my cpu beeps now...i remember runni
You should be able to as it can take 4 gig total according to the manual.
Memory:
2 DDRII DIMM memory slots (supports up to 4 GB memory) (Note 2)
Supports dual channel DDRII 667/533 unbuffered DIMMs (Note 3)
Supports 1.8V DDRII DIMMs
Note 2. Only for GA-945GCMX-S2.
Note 3. Only for GA-945GCM-S2.
Feb 06, 2012 | Gigabyte Computers & Internet
I have a Intel D102GGC2 motherboard with Intel Pentium D 805 processor having core speed of 2.667 GHz. I was using a 1GB of Dynet RAM (DDR2-667 MHz) earlier. Recently, I got a Transcend 2GB DDR2-667 MHz...
specs on that board from Intel is 2 gig max. when you install the 2 gig alone does it show you 2 gig in windows or only 1?......with a 2 gig max I would think that would max each slot at 1 gig...
http://downloadmirror.intel.com/15112/eng/D102GGC2_TechProdSpec.pdf
Jul 04, 2011 | Intel D102GGC2 Motherboard
Hi, I need standard spec info of VGA built on Asus P5GC-MX 1333 whether 64 Mb or 128 Mb. Many thanks & regards, Richard
you can use up to a maximum of 224 mb of your computer's RAM for the onboard video chip to use. You can install a video card with any amount of memory (which would give you a lot better video performance).
Jun 18, 2011 | ASUS P5GC-MX 1333 BULK C2D LGA775 945GC...
Hello Sir, I had 512 MB 533 MHz DDR2 RAM(Dynet). Now I have bought 1 GB 667 MHz DDR2 RAM(Dynet). My system has 2 slots. In one slot, I have 512 MB RAM and in another slot, I installed 1 GB RAM that I have...
The Intel D102GGC2 uses a Dual Channel Memory Architecture meaning that both slots need to be running at the same speeds. I would suggest getting another 667 MHz RAM card and installing it along side your current one, just as I reminder this motherboard only supports 2GB RAM Max so don't get one that is above 1GB.
Mar 28, 2011 | Intel D102GGC2 Motherboard
Machine randomly restarts after upgrading RAM
Ok thats the problem.
1 module with 2gb is not possible on this board:
http://www.memoryxxl.net/mainboard::4345_36366/Intel-D102GGC2.html
Intel D102GGC2 Motherboard Mainboard Speicher Technische Beschreibung Intel D102GGC2:
Bus Architecture: - Hersteller Standard Ausrüstung: Non-ECC only, Unbuffered only, Chipset: ATI Radeon XPRESS 200 - vom Geräte Hersteller empfohlener maximaler Arbeitsspeicher: 2048MB - Speicher Upgrade: 2 (2 banks of 1) -Speicher Beschreibung: Jeder Slot kann mit DDR2 PC2-4200, DDR2 PC2-5300, DDR2 PC2-6400 und maximal 1GB Speicher aufgerüstet werden. Eine bessere Performance erziehlt man bei paarweiser Modul Installation. (USB Support: 2.x Compliant, Graphics Support: PCI Express x16) - Speicher Bus Architecture:
You have to use 2 modules with max. 1 gb per module
Dec 30, 2008 | Intel D102GGC2 Motherboard
UpGrade
you could only upgrade the processor and RAM in this condition i.e.
you can only change your an upgraded p-III processor like 1.0 GHz, 1.1 GHz or 1.3GHz and
upgrade the RAM by changing to 256 in each slot.
that is all what u can do with ur pc
Oct 18, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Intel DG31PR Motherboard Problem
Memory is key element on all motherboards and hard to believe they are all selective of memory . You have the wrong memory for that motherboard . Sorry . Here is list you can select for the motherboard ( only ones that will work with it )
http://www.intel.com/technology/memory/ddr/valid/DDR2_667_dimm_results.htm
Anything other than what is listed will not work with your motherboard .
Aug 04, 2008 | Intel DG31PR Motherboard
Intel DG31PR Motherboard Logo
104 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
