Question about Hoover HDC6 Electric Dryer
Hoover Condensing dryer malfunction
After about 18months of problem free service our Hoover HDCC6 stopped working (at about 2 a.m.!). The first time this happened there was a strong smell of electrical burning and the dryer had tripped the main circuit breaker. If you try to switch the machine on now the element clearly heats up but the drum does not turn. Motor is not running and drive belt looks fine and truns manually witht he motor (which therefor seems not to be seized). Burning smell seems likely to be due to element being hot without motor running drum or fan perhaps?
I wondered if there was a motor start switch or capacitor the gave the motor its start up surge (which might be greater than it's operating current due to initial load?) that could be the problem...?
Any thoughts appreciated - seems a shame to ditch the whole thing if replacing a part could fix this.
mikebowen@hotmail.com
  • maelich Nov 07, 2007
    Thanks for this - really helpful. I'll give these suggestions a try.
    Is replacing the motor reasonably straight forward?
  • 709 Answers
Hi Mike,
The motor probably has experienced locked rotor current and fried the windings. Of course the capacitor could have shorted. If you can find it, look at the capacitor and if the can looks like it's lid is swollen or pooched out, then go for replacing the Capacitor. If you remove the motor and smell the case and it smells burned, you motor is shot. It does not have to lock down to be bad. The windings do not rotate in an AC motor.
Posted on Nov 03, 2007
  • Greg Stokes
    Greg Stokes Nov 03, 2007
    PS. www.repairclinic.com is a good place to get the parts you need.
  • Greg Stokes
    Greg Stokes Nov 07, 2007
    Hi Mike,
    If you have some mechanical skills and ingenuity, you should have no problem at all replacing the motor yourself. Just be sure to have the dryers Cord disconnected from the outlet. Remember they build about 300 of these things a day, with a handful of people. Go for it, you can do it. Check out the repairclinic.com website, sometimes they have good diagrams to investigate how things go together.
I have a candy hoover dryer 9kg its brand new it stops half way through and bleeps 3 times what is this
It is under warranty call service, do not attempt any repairs as it will void the warranty.
Dec 05, 2016 | Hoover Washing Machines
Beko DRCT 70w condenser dryer not heating inside drum element is new and works any ideas ?
check the 2 thermostats with the element.........if ok.....
check the condenser unit.......they fill with fluff and stop condensing.......i use a hose pipe to shift all the fluff.....
cheers
Nov 23, 2016 | Dryers
Bosch dryer beeps
Two Beeps on my Bosch WTE84100au Condensing Dryer means a thermal overload but also means one of the thermal sensors is faulty .... as if it is always on.
Open the door, pull out the lint catcher and clean around the silver probe (it's like a shiny 1/8" nail sticking into the cavity below the lint catcher). If it still doesn't work (and still 2 beeps), just flick it lightly a couple of times. If it still doesn't work, flick again from the other direction.
Mar 24, 2014 | Dryers
Hoover vhc180
Sounds like an overheat sensor is tripping. Remove the exhaust duct from the dryer and see if it stays heating. If it does you have a clogged vent.
If it still acts up you have an internal blockage or a weak sensor and the dryer will have to be taken apart to service it.
Nov 04, 2013 | Hoover VHC391 T-80 Dryer
Hoover hd condensing dreyer cuts out and water light is on after 15 min with towels in and takes ages to reset
Make sure that drain is free, that the dryer has adequate ventilation and that the lint has been cleaned from inside. Those are all reason.
Sep 21, 2011 | Hoover HDC6 Electric Dryer
Tumble dryer only tumbles when swhich is held in
It sounds like the centrifugal switch on the dryer motor is malfunctioning. Needs service.
May 13, 2009 | Hoover Dryers
Dryer will not heat up
heater has a built in micro temp which are usually the problem on hoover t/dryers..if not technical minded then your best replacing the heater as the micro temp is solderd into the heater wiring
May 28, 2007 | Hoover HDC6 Electric Dryer
Hoover HDC6 Electric Dryer Logo
255 people viewed this question
Top Hoover Dryers Experts
Tim Whalen
John Tripp
John Tripp
Are you a Hoover Dryer Expert? Answer questions, earn points and help others
