Question about LG L1720B 17" LCD Monitor
L1720 monitor always showing light view - LG L1720B 17" LCD Monitor
Tried viewing my Swann H.264 DVR through a 14inchvia monitor it did not work, when I replaced the 7inch monitor supplied that does not work also now, any ideas?
When you try to connect different devices and nothing works, most of the time the common factor is defect. I mean when the DVR is defect, you can connect 100 different monitors, but non will ever show a thing.
On the other hand when you are not 100% sure you have a working monitor, how would you test a DVR?
Make sure you always have at least every thing in the cain working, before you use a chain to test an unknown device.
And in this chain also make sure the cables and connectors are all in working order.
Jan 27, 2015 | SWANN Home Security
How to solve light view on my l1720 monitor
Change your preset mode to factory default/normal (maybe ambient sensor?)
Apr 23, 2014 | HP Compaq WF1907 Monitor
My screen is extremely bright/white , difficult to
try to use the auto adjust button. if it doesn't work you have to go to the nearest service center in your place
Jul 18, 2010 | HP L1720 17 in. Flat Panel LCD Monitor
HP L1720 monitor on screen control frozen in center of screen
mcdevito75 here, Try to simply shut the monitor off at the monitor itself, Or with your computer shut down, disconnect and reconnect the monitor to the computer.
Jul 10, 2010 | LG 22" FLATRON LCD Monitor
My moniter display is not coming it alway show
You need to try this monitor on other PC to narrow down the problem, it can be the monitor, cable, PC. I f you try all the suggestions and it still does not work, then you need to open it up and see the pictures here: http://s807.photobucket.com/home/budm/allalbums
and check for shorted transistors or bad fuse.
Mar 11, 2010 | Dell E173FP 17" LCD Monitor
Message: OSD LOCKED'' when i press a button on my LG Flatron L1720
change all pressing keys..then press menu key 15 seconds for unlocked.
Jan 21, 2010 | LG 22" FLATRON LCD Monitor
HP L1720 flickering!
this is common, the display is bad.
all displays, fail. all do. no reason to get angry,
a broken display is worth nearly zero value $0
so how much money will you spend on worthless.?
you can get a new display at Walmart for $65, ,
lines are usually very serious. and is not ever the DC-DC inverter
a bad inverter (< it's power supply) is for the back ground lamps. not data side. the data side is failing and is common, if you twist the screen
it gets worse. ? bingo. data driver connections bad , screen.
IN most cases the part that is bad (screen), costs $100 new. or 50 used
why go there/
Jun 01, 2017 | HP L1720 17 in. Flat Panel LCD Monitor
We have the monitor hooked to a docking station for a laptop. I can not view the screen on the Viewsonic, but does display on laptop. I have been able to do an extende monitor view, but not the main view....
when you connect external monitor to a laptop u get two options in the monitor section of graphic properties tab
1.) extended
2.) clone
it is clear from ur post that u are using extended view
try using clone mode then both laptop screen and external monitor will show the main screen
other method is to disable the laptop screen and just allow external monitor to work, in this case laptop screen shows nothing but external monitor shows main screen
Sep 29, 2009 | ViewSonic VG700b 17" LCD Monitor
LG L1720B 17" LCD Monitor Logo
42 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
