Question about Revere Rt1640 Transformer 120v 60hz 048a 165vac 40va
Transformer is hot
Hot to the touch? We don't use the system. Is it safe to unplug or will alarm go off?
1997 crown Victoria. viper alarm kill switch has turned all power to car. How do I reset
there is no override. Otherwise it would defeat the point of an immobilizer. I would find out why the alarm went off and deal with the rot cause rather than trying to bypass something made to be un-bypassable.
You may be able to reset the alarm by unplugging the battery from the car for a minute or 2 but I would start with the alarm manual to be safe. Possibly even remote the alarm and put the wiring back to stock.
Oct 16, 2016 | 1997 Ford Crown Victoria
How do u know when a circuit board gets hot
Usually, it's one or two components that get hot - not the entire board. You should never touch a circuit board while powered to "feel for heat". Disconnect from power (unplug, shut off circuit, etc.) and wait a moment for capacitors to safely discharge. Check all components with a volt meter BEFORE touching them with your hands. You may also look for discoloration on the board near a component. If the component is raised off the board - it may not cause the board to discolor - as the further away from the board it is the less likely it will be to cause discoloration. High heat components have "heat sinks" that are larger pieces of heat conducting materials that are in physical contact with this components designed to wick heat and transfer it to the chassis, frame or air. These components will be warm or even hot to the touch - but it will be difficult to know if "too" hot as a result.
Oct 27, 2015 | Pool & Spa
How do I get a copy of the instruction manual?
Is Safe-T-Alert Surface Mount 12V RV CO Alarm a carbon monoxide detector?
Sep 30, 2014 | Alert Safe-T-Alert SURFACE MOUNT 12V RV CO...
My Toyota Highlander alarm keeps beeping at a few minutes to11am and 2pm without anyone touching it. I want it reset
Disconnect the battery ground for a couple of days.It will reset once you hook it back up.Otherwise,unplug the alarm from the system.
Apr 09, 2014 | 2003 Toyota Highlander
Power transformer over heating
Transformers will get hot if you are running the receiver hard. Most transformers have a built-in thermal fuse. If this fuse goes, then you have to replace the transformer. Just make sure you have good ventilation around the unit. don't have anything on top that might block airflow
May 19, 2013 | NAD T751 Receiver
I'm getting the registry file failure screen it
If you unplug, remove battery, plug in, reboot to the system restore.
Dec 11, 2012 | Computers & Internet
Frigidaire freezer compressor is hot to the touch and not cold inside
If the compressor is hot, then the temperature inside the unit may be compromised if there is a sealed system issue or a restriction in the unit. Call a professional to be safe.
Jul 26, 2012 | Frigidaire 14.1 cu. ft. Upright Freezer...
If the compressor is hot to touch and it is not cooling, contact a service professional as soon as you can. Sounds like you have a sealed system issue or cooling restriction and you don't want to ruin any food items in the unit.
Jul 26, 2012 | Frigidaire Refrigerators
I've got an oil leak under the car and I guess it's from the trans, a Honda 1994 Accord vti, how do I check the fluid and refill
Don't guess please, pressure wash wash the engine and confrim it. You refill through the dipstck tube to the safe line when the transmission fluid is hot to the touch.
Jun 28, 2012 | 1994 Honda Accord
Horn just goes on its not the alarm so took horn use out
  • The horn relay contacts are welded or the armature is stuck on. Replace the horn relay.
  • The horn switch on the steering wheel is stuck on (this is generally rare, but not a do-it-yourself repair because of the risk of exploding the air bag if you don't know how to safe it).
  • The horn switch wiring insulation has been cut and there is a short. This would probably be intermittent.
  • If you have a factory alarm, there may be a solid-state switch that takes its input from both the driver's horn switch and the alarm module. This switch could be shorted - it's probably a simple transistor, but may be mounted on the alarm module board. If so, disabling the alarm would not stop the horn unless the module is physically unplugged.
Jun 16, 2011 | 1997 Lincoln Town Car
Revere Rt1640 Transformer 120v 60hz 048a 165vac 40va Logo
Top Revere Home Security Experts
Lawrence Oravetz
Are you a Revere Home Security Expert? Answer questions, earn points and help others
