Question about Maytag LAT3600A Top Load Washer
Maytag Washer lid switch
Maytag LAT8506AAE top load washer. Is it possible to ''jump/bypass'' the lid switch in an attempt to see if it is bad? The wires going into it are 2 white, 2 yellow, 1 black, and 1 green. Using an insulated wire, which ones should i connect to see if the washer works?
  • gmfltchr Jun 20, 2009
    Correction: the wires are white (2), Black (1), Yellow (2), and Blue (1). They are associated with Neutral,Line, Motor, and Machine on the switch. Which one's would I connect to see if the machine then has "power?"
  • 37 Answers
Ohm out the blue/ blk terminals on the sw (remove wire harnes first and notate wire color connection) with an ohmmeter-- Reading should be zero (closed lid position)
Then ohm the ylw and white sw terminals-- reading should be 0 as well.
If I am not mistaken this sw has a plunger that sticks out, if hte unit goes off balance this could push the plunger in. to reset- pull the plunger out
Lou
AFFORDABLE APPLIANCE REPAIR
(949) 855-0788
Posted on Jun 20, 2009
Maytag bravos x lid lock overide or bypass
dpthom's wife is the smartest woman on earth! :)
Feb 11, 2013 | Maytag Bravos Top Load Washer
My washer has filled up with water and then just stopped and wont begin the cycle...
Try manually advancing timer . If washer starts , timer motor is bad or gets stuck , or water level switch is bad and not sending power to timer.
If washer doesn't start ,the lid switch is stuck not sending power to timer or god forbid, timer is shot.
In some models , lid switch controls everything which may be your problem .Try manually operating lid switch or jumping it with jumper wire.Or just replacing. Its' the easiest to fix and most likely problem.
Good luck
Aug 15, 2011 | Maytag PAV2300 Top Load Washer
HOW DO I BYPASS KENMORE SERIES 80 LID SWITCH ON THE WASHER. IT WILL NOT SPIN , BSD LID SWITCH.
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part and only requires you to access the console and remove the cabinet.
Jun 07, 2010 | Kenmore 22942 Top Load Washer
Kenmore top load washer, it washes but won't rinse or spin, I tried to lift the top off to check the lid switch becuse the lever pad is stuck down, but how do the tops lift off
If it works, the Lid Switch is a relatively inexpensive part.
Apr 18, 2010 | Kenmore 22622 Top Load Washer
Washer won't wash when lid is closed.
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
Newer model Kenmore / Whirlpool top load uses a Lid Switch to prevent the washer from operating when the lid is opened. Older models only used the switch to prevent the washer from spinning when the lid is up.
If you cannot hear the motor trying to turn the pump, (but the washer will agitate) the problem points to the Timer, or the Lid Switch.
Following is a description of how to release the console for access to the pins.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
Dec 05, 2009 | Kenmore 24032\24036 Top Load Washer
How to Find Lid Switch on Maytag Washer
i would recomended, becouse it is not just lid switch, on this model it is a small conroler..but if you still want it...it is on thge back of your top lid, right on the center..open your lid and look under
Aug 25, 2009 | Maytag LAT3600A Top Load Washer
Top load washer says door open ( od )and will not
did you tested your led switch? you can bypass lid switch just have to be very careful after that....if it is a bad lid switch better replace it....unexpencive and more safe
Aug 25, 2009 | Maytag Washing Machines
Washer is "dead." Was stopped after fill up, and now no power.
Hi, I would check the lid switch first. Remove the two screws that hold the control panel to the cabinet and let it rest on the hinges. Locate the lid switch connection and either test it for continuity or use an insolates wire and jump the switch by inserting the wire into the gray and brown wires. Turn the washer on and see if it works.
Please let me know if this helps or if I can assist you further.
Thanks
Vic
Jun 20, 2009 | Maytag LAT3600A Top Load Washer
Washer won't agitate, drain or spin
quite possible that the fuse has gone bad again, if that s the case i would recommend replacing the fuse, and the lid switch.
Dec 08, 2008 | Maytag LSE7806A Top Load Stacked...
Maytag washer
You have a bad lid switch. You can buy these very cheap at your local dealer. Sometimes you can just bypass them if you have no kids in the house that will open the door while its running. Good luck!!
Aug 18, 2008 | Maytag SAV4655A Top Load Washer
Maytag LAT3600A Top Load Washer Logo
1,225 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
