Question about Hoover U5780-900 Windtunnel Cyclonic Bagless UprightVacuum
Uh70400 height adjustment level located - Hoover U5780-900 Windtunnel Cyclonic Bagless UprightVacuum
How do I adjust height for carpet brush on DC28 Dyson animal?
Hi Laura, it's Jack at Dyson
DC28's selector pad (located by the red on/off switch) allows you to select the correct height setting for the particular flooring you're cleaning. Patented Dyson Airmuscle technology will then raise or lower the rotating brush bar within the cleaner head to the correct level for optimum performance, or shut it off for cleaning bare floors or delicate rugs.
I hope this helps, but if you have any further questions or if you're having difficulty with your DC28, you're welcome to get in touch directly. You can reach our experts by emailing askdysonUS@dyson.com
Mar 01, 2015 | Dyson Vacuums
Can I fix the high, medium, low level switch on vacuum piece?
The height adjustment lever on Kenmore Power Nozzles is one of the machine's weak points. It's not well made as far as being protected from dirt and dust and moisture. It's always easier to move these things when the vac is on it's side or at least with the front end in the air. That takes the pressure off the adjuster. The mechanism may need nothing more than to taken apart in the presence of a good air compressor which can be used to blow out any of the aforementioned debris.
Nov 11, 2013 | Kenmore Vacuums
Oreck xl
It's hard to push because it's literally sucking itself to the floor. Adjust the height control to raise the level and allow more air to get in around the edges, should relieve the vacuum pulling it down. Possibly somthing is wrong with the height adjustment control, allowing machine to sit too low to ground. Hope this helps.
May 11, 2013 | Vacuums
Brushes spin slowly then when applied pressure they stop
lower the height setting, using a setting that is not correct can cause the brushes to hang up. Is your machine the type that has an automatic height adjustment or is there a dial
Jul 27, 2009 | Hoover F5906-900 Upright Steam Vacuum
Height adjustment on power head
Generally, there are screws that hold the beater bar onto the vac head.  Loosen them, remove the glop that got in there and you should be okay.  If you remove the screws, note the location of all parts...Digital cameras are great things. If you forced the adjustment, you may have broken or bent something.
Nov 29, 2008 | Kenmore 25614 / 25615 Progressive Bagged...
Sweeper vibrates when pushed forward.
do u put it on drive or neutral? does the wheels spin when on drive? is the height adjuster on the right level?
Sep 09, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Height adjustment
You'll have to turn the upright to its side to show the sole plate where the rolling brush is. Check where the front wheels are located and ensure there is no blockage obstructing the rotary dial. Sometimes the spring mechanisms can work themselves loose.
Inevitably you'll have to remove the sole plate and/or the rotary dial which may be screwed down. If it has cracked then you may have to seek a replacement.
Dont forget to rate this suggestion.
May 25, 2008 | Electrolux Oxygen 3 Upright Vacuum Cleaner...
Hoover U5780-900 Windtunnel Cyclonic Bagless UprightVacuum Logo
21 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
