Question about SVP 2.8" Dual SIM Quadband Q70 White with Micro 4GB Touch Screen Phone Unlocked
Svp model c6 at&t data connection issues - SVP 2.8" Dual SIM Quadband Q70 White with Micro 4GB Touch Screen Phone Unlocked
Good Afternoon..... I cant receive or send pictures what is the APN code for SVP G13 watch phone
An Access Point Name (APN) is the name of a gateway between a GPRS, 3G or 4G mobile network and another computer network, frequently the public Internet. A mobile device making a data connection must be configured with an APN to present to the carrier.
For AT&T
Programming non AT devices with the correct APN and MMS data settings AT...
For Tmobile.
Mobile apn settings Step by Step Configuration
Oct 16, 2015 | SVP G13 Gsm Unlocked Watch Cell Phone...
Do I have to have a special charger for my svp s580
Any 5 V 2000 mA charger will work. The issue is the power connector. Here is what they look like: http://www.amazon.com/SVP-Tablet-Wall-Charger-inch/dp/B00DEO9OT2/ref=sr_1_1?ie=UTF8&qid=1423228831&sr=8-1&keywords=svp+charger
Feb 06, 2015 | SVP Cameras
How to get built in dongle working
To connect to the web with built in 3G, you have to pay for whatever service the 3G adapter is for. It looks like SVP tablets use EVO/WCDMA which is used by Sprint or Verizon in the United States. You will have to contact them about adding a tablet to your wireless pan, or signing up for a new mobile data plan for set price per month.
Jul 19, 2014 | SVP 10-inch Tablet Pc With Touch Screen...
Nokia c6 2
need serial key for stopzilla
Feb 05, 2014 | Computers & Internet
My Nokia C6 phone hangs about 20 times a day. and the only solution to make it start working again is to take the battery out of the phone and then put it back. What can be done to resolve this HANGING...
Sometimes this would happen due to phone software corruptions. back up the phone 1st using the PC suit. Type the code *#7370#, phone will be restart and will be setting up to the factory settings.use the phone before restore the backed up data. if its running smoothly, then restore the back up. dont install too much of softwares on phone memory.(drive C:/)
Feb 28, 2011 | Nokia C6 Smartphone
I am getting a 1005 2082 error on my HDS 9985 (NCS-55) when I try to delete a LUN assignment. Can you help?
1. RDP (mstsc ->IP address) to SVP of this storage (you can also connect via serial cable to storage)
2. Make sure SVP is in modify mode
3. Go to Install -> Change Configuration -> LUN Confirguration
4. Go to particular port on which your Host Group is reside.
5. Check LUN status: If it's other than "Normal" then you have to generate password to unreserve LUN. (password you will get from HDS support.
6. Once you have password right click LUN & do force reset. Enter Password & it's Done :) LUN status will come back to Normal & you will be able to release the LU path.
Oct 28, 2010 | Computers & Internet
What automatic transmission was used in the 1992 Ford F-250 Diesel
A.T., 4x4, AOD (5.0L)
EAC}G}}400" type="radio" name="userInterchange" />A.T., 4x2, AOD (5.0L), 11-1/4" ext hsg
EA}}}400" type="radio" name="userInterchange" />M.T., 4 spd (Warner T-18), 4x4
M.T., 5 spd, Mazda/Toyo Kogyo, 4x4
M.T., 5 spd, ZF, 4x4, 8-460 (7.5L)
M.T., 5 spd, ZF, 4x4, 8-445 (7.3L, diesel)
EAA}N}}400" type="radio" name="userInterchange" />A.T., 4x2, AOD (5.0L), 10-1/4" ext hsg
M.T., 4 spd (Warner T-18), 4x2, 12" ext, cable drive speedo
M.T., 4 spd (Warner T-18), 4x2, 12" ext, elec speedo
M.T., 4 spd (Warner T-18), 4x2, 4" ext, cable drive speedo
M.T., 4 spd (Warner T-18), 4x2, 4" ext, elec speedo
F>}A}}400" type="radio" name="userInterchange" />A.T., 4x4, C6, 8-460 (7.5L), (elec speedo), (tag F2TP-YA)
M.T., 5 spd, ZF, 4x2, 6-300 (4.9L), cable drive speedo
M.T., 5 spd, ZF, 4x2, 8-351 (5.8L), cable drive speedo
M.T., 5 spd, ZF, 4x2, 6-300 (4.9L), elec speedo
M.T., 5 spd, ZF, 4x2, 8-351 (5.8L), elec speedo
M.T., 5 spd, ZF, 4x2, 8-460 (7.5L), cable drive speedo
M.T., 5 spd, ZF, 4x2, 8-460 (7.5L), elec speedo
M.T., 5 spd, ZF, 4x2, 8-445 (7.3L, diesel), cable drive speedo
M.T., 5 spd, ZF, 4x2, 8-445 (7.3L, diesel), elec speedo
M.T., 5 spd, ZF, 4x4, 6-300 (4.9L), ID E9TA-TA & TB
M.T., 5 spd, ZF, 4x4, 8-351 (5.8L), ID E9TA-TA & TB
M.T., 5 spd, ZF, 4x4, 6-300 (4.9L), ID F4TA-BA & BB
M.T., 5 spd, ZF, 4x4, 8-351 (5.8L), ID F4TA-BA & BB
>C}}}400" type="radio" name="userInterchange" />M.T., 5 spd, Mazda/Toyo Kogyo, 4x2, elec speedo
>D}A}}400" type="radio" name="userInterchange" />M.T., 5 spd, Mazda/Toyo Kogyo, 4x2, cable drive speedo, 2.73 ratio
>D}A}}400" type="radio" name="userInterchange" />M.T., 5 spd, Mazda/Toyo Kogyo, 4x2, cable drive speedo, 3.08 ratio
>D}B}}400" type="radio" name="userInterchange" />M.T., 5 spd, Mazda/Toyo Kogyo, 4x2, cable drive speedo, 3.55 ratio
>D}B}}400" type="radio" name="userInterchange" />M.T., 5 spd, Mazda/Toyo Kogyo, 4x2, cable drive speedo, 4.10 ratio
A>}}}400" type="radio" name="userInterchange" />A.T., 4x2, E4OD, 6-300 (4.9L), (elec speedo), ID F2TP-BA
A>}}}400" type="radio" name="userInterchange" />A.T., 4x2, E4OD, 6-300 (4.9L), (elec speedo), ID F2UP-DA & DC
A>}}}400" type="radio" name="userInterchange" />A.T., 4x2, E4OD, 8-302 (5.0L), (elec speedo), (ID F2TP-DA)
A>}}}400" type="radio" name="userInterchange" />A.T., 4x2, E4OD, 8-351 (5.8L), (elec speedo), ID F2TP-FA
A>}}}400" type="radio" name="userInterchange" />A.T., 4x2, E4OD, 8-351 (5.8L), (elec speedo), ID F2UP-EA, EB & EC
?}}}400" type="radio" name="userInterchange" />A.T., 4x4, E4OD, 8-351 (5.8L), (elec speedo), (ID F2TP-HA)
}}}400" type="radio" name="userInterchange" />A.T., 4x2, C6, 8-460 (7.5L), (elec speedo), ID F2FP-CA & DA
A.T., 4x4, E4OD, 8-460 (7.5L)
E}}}400" type="radio" name="userInterchange" />A.T., 4x2, E4OD, 8-445 (7.3L, diesel)
A.T., 4x2, C6, 6-300 (4.9L), w/o ID F2FP-BA; w/o ID F2UP-CA
A.T., 4x2, C6, 8-351 (5.8L), w/o ID F2UP-CA
A.T., 4x2, C6, 6-300 (4.9L), w/o ID F2FP-BA; ID F2UP-CA
A.T., 4x2, C6, 8-351 (5.8L), ID F2UP-CA
A.T., 4x2, C6, 6-300 (4.9L), ID F2FP-BA
A.T., 4x4, E4OD, 8-445 (7.3L, diesel)
A.T., 4x2, E4OD, 8-460 (7.5L)
A.T., 4x2, C6, 8-445 (7.3L diesel)
EF}D}}400" type="radio" name="userInterchange" />A.T., 4x4, C6, 8-351 (5.8L)
Good luck
Aug 10, 2010 | 1992 Ford F250
Making Slimscan C6 work
Your best bet is to go to http://support.microtek.com/ Enter your model number and download the manual, from there you can use the same site to download any software you may need to get things working.
Jul 13, 2007 | Microtek Slimscan C6
SVP 2.8" Dual SIM Quadband Q70 White with Micro 4GB Touch Screen Phone Unlocked Logo
Top SVP Cell Phones Experts
Computer Repairing
Computer Repairing
 Mikey
Mikey
Are you a SVP Cell Phone Expert? Answer questions, earn points and help others
