Ford focus CD players have 2012 focus cd comes out scratched and skippes I have complained to dealer they say if problem not found I will have to pay for replacement I am on a fixed income and cannot afford to
fairlane
  • 50 Answers
SOURCE: CD PLayer won't play CD's
Hi First of all, you must find all the screws for the top cover and remove it. Make sure the unit is not plugged in! Then, making sure that you are not touching anything inside the unit, plug it back in,put a Cd in the drawer, and watch what happens. If the drawer closes, but you can still hear a motor running, then it is a belt drive unit, and the belt is slipping, if that part is ok, listen carefully for a ticking noise, which is the laser lense going up and down trying to focus on the CD, if the disk starts to spin then the mech has closed properly, and the unit is trying to find the directory. If the unit then spins the disk for a while then ejects it, then the laser is dirty or faulty. I would suggest getting it cleaned at a shop if the lense appears dirty. ***Never look straight down at the laser lense if it is exposed on your model of CD player, it is a class 3 laser, and you will be doing some harmful home laser surgery to yourself!!!*** Hope this helps! Good Luck! P.S. When following the steps above, if you hear the ticking of the lense moving up and down, but the disk does not spin, gently spin it clockwise with your finger, if it starts to play, or finds the directory, then the spin motor is bad.
Posted on Aug 16, 2006
localwonder
  • 6784 Answers
SOURCE: cd won t eject from 2006 Ford Focus mp3 player Get
HI, either the deck assembly is jammed or, the load motor has failed. In this case, you will need to disassemble the entire set in order to retrieve this CD.
The actual loading deck(the part where the CD is located), is surrounded by a metal housing. the gear assembly is probably locked, due to this jam or failed load motor. This will also require a set of precision tools as well. if you find this a bit overwhelming, i suggest taking this unit to a local automotive audio shop. they can dissemble it and, retrieve the CD for a small price.
Posted on Jun 21, 2009
SOURCE: Error 04 CD player
Hey...it's easy to fix. Open the fuse box under the hood. Find the audio fuse. Pull it out for 10-15 minutes to reset the cdplayer. Plug it back in and problem solved. If it still does not work just change the fuse. I had that problem and had to search high and low for a solution and found it
on some web site. IT WORKED...will save you $800 that Lexus charges to do the same thing.
Posted on Jul 06, 2009
SOURCE: not accepting cd's
I have the exact same car a 2005 Ford Focus ZX5 with a 6 disc MP3 player, when we first got the car the changer worked fine and would read all discs, after a few weeks it would kick out every disc and say that it was "bad disc", we tried buying just some office depot cleaning disc thinking it would clean the laser. This did nothing, tonight I got quite ambitious and removed the whole deck from the dash. You do this by carefully prying back the surrounding plate all the way around the heating controls and then unbolting the deck from the car. I unhooked the cabels that were running into and pulling it out. I then unscrewed all the small screws to the unit and took a look inside. As it turns out I wasn't able to find the laser eye as the changer had hidden it, so I screwed it back together and put it back in. Turned on the player and put in a disc and it played perfectly. So in the end basically unplugging it and plugging it back in did the trick. You may also have the same luck just unplugging the battery for about a minute and plugging it back rather than taking your dash apart. Hopefully that helps you since it's been 4 months since you posted this issue.
Posted on Jul 09, 2009
SOURCE: my ford fiesta 4500 cd
1. switch off the system.
2. switch on and press CD; it will display CD ROM or alike message
or press eject; it will show error E83
3. Press and hold eject for about 20 seconds
4. The cd will come out
5. If necessary, repeat the above steps.
6. If you don't succed see the dealer
Posted on Sep 01, 2009
Hello all, The factory fitted cd player on my
Read your owners manual
No manual-- go back to the dealer &
have then write down how to install the code
Sep 12, 2013 | 2005 Ford Focus
Ford focus RS sony cd radio key code for V015795
Ford focus cd player with serial number V019590, please tell me the keycode, thank you..=)
Sep 22, 2012 | 2007 Ford Focus (3 Door) Hatchback
How do you remove am/fm cd player from 2005 ford focus
There is a plastic "plate" surrounding your CD player; on the back of this "plate" there are 4 plastic guide/retainer pins about 3/4 of an inch long. Generally located in the 4 corners of the "plate." With that in mind, using a taped-up, flat-headed screw driver(tape the flat end as to not scratch the interior trim) and simply and ever so lightly, pry the coin dish(below the "plate" mentioned above)out and away from the dash,opening a hand sizes hole. From that hole using the same screw-driver, using the same technique, remove the plate; being oh so careful because the temp control knobs, cig lighter, etc, come out attached to the "plate."
You will notice, I believe, 4 small octagonal plastic bolt heads protruding from the area right next to the player......remove those bolts, unplug radio and whalll-laah..
Apr 03, 2010 | 2005 Ford Focus
Ford Focus radio/cd player. FM goes off for no reason , then comes back on, on its own. Switching it on and off does not make any difference. Checked supply voltage all ok as is the earth. Joe
Worth checking whether it's not just traffic news coming on. The volume level is independent to the normal level and if you've lowered the volume at some point in the past it will remember that level.
Dec 12, 2009 | 2000 Ford Focus
2005 ford focus 6 disk factory cd player isn't working.
That is a load of croc what the dealer told you. They service every component on the vehicles they sell. Right down to a screw you may be missing. I'm just wondering if your car is still under warranty because I know a lot of dealers that will make excuses so they don't have to pay for the work out of their own pockets.
Sep 17, 2009 | 2005 Ford Focus
Just bought a 10 year old ford focus estate with a 5000 RDS stereo and not sure wether it has a CD player or not. Think its a CD changer but not sure of its location?
Usually in the boot but not sure on an estate..suggest phone call your local ford dealer,they are usually very helpful
Sep 06, 2009 | Car Audio & Video
2000 Ford focus td cl estate fails to start
factory immobiliser call dealer to reset ECU
Jan 03, 2009 | 2000 Ford Focus
2004 ST170 problem
Start out by diagnosing it it is the CD Player. Pull the fuse for the radio/cd and drive it for a few days (or whatever it usually takes to drain the battery) and if the battery doesn't drain, you know that's the problem. Call a dealership and ask if the problem has showed up as a recall item yet. I'm still getting free repairs on my daughter's 2001 BMW due to recall items.
Jul 10, 2017 | 2003 Ford Focus
 Grubhead
Grubhead
