Question about Hoover U5780-900 Windtunnel Cyclonic Bagless UprightVacuum
Uh70400 height adjustment level - Hoover U5780-900 Windtunnel Cyclonic Bagless UprightVacuum
Height adjustment does not work
Hello! The vacuum does not move up and down when you change the height setting. When the handle is reclined is when the height of the nozzle will adjust. Hope this was helpful!
Jun 26, 2014 | Hoover Tempo Widepath Upright Vacuum -...
How to adjust height on bagless dirt devil featherlite
Hello! The M085435 has an automatic height adjustment. The vacuum will adjust to the carpet height without you having to do anything. Hope this helps!
Apr 25, 2014 | Dirt Devil FAN, FEATHERLITE MODEL...
Can I fix the high, medium, low level switch on vacuum piece?
The height adjustment lever on Kenmore Power Nozzles is one of the machine's weak points. It's not well made as far as being protected from dirt and dust and moisture. It's always easier to move these things when the vac is on it's side or at least with the front end in the air. That takes the pressure off the adjuster. The mechanism may need nothing more than to taken apart in the presence of a good air compressor which can be used to blow out any of the aforementioned debris.
Nov 11, 2013 | Kenmore Vacuums
Oreck xl
It's hard to push because it's literally sucking itself to the floor. Adjust the height control to raise the level and allow more air to get in around the edges, should relieve the vacuum pulling it down. Possibly somthing is wrong with the height adjustment control, allowing machine to sit too low to ground. Hope this helps.
May 11, 2013 | Vacuums
Height adjustment won't work on Hoover windtunnel
In my experience, Hoover height adjustment are "stops" rather than being attached to an axel. Look for something that rould resemble a set of circular steps somewhere in the path the axel would take as it goes up and down. It is usually on the underside from the knob that sets the height. Each 'step' represents a height with the shortest step being the lowest setting from a certain perspective.
On some Hoovers, therte is a ratchet petal on the right side. The ones I have seen are similar in operation to the above.
Let me know if this helps you.
A
Sep 21, 2009 | Vacuums
Height adjustment on power head
Generally, there are screws that hold the beater bar onto the vac head.  Loosen them, remove the glop that got in there and you should be okay.  If you remove the screws, note the location of all parts...Digital cameras are great things. If you forced the adjustment, you may have broken or bent something.
Nov 29, 2008 | Kenmore 25614 / 25615 Progressive Bagged...
Sweeper vibrates when pushed forward.
do u put it on drive or neutral? does the wheels spin when on drive? is the height adjuster on the right level?
Sep 09, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Chatter
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=11557&thid=576381
Chatter
Posted by CANRN on May 06, 2008
We have a Kirby Ultimate G. Since we purchased it bounces across the floor and the level of the sweeper has nothing to do with it. To get it to stop, it has to be at the highest level. The place we bought it, has done nothing to help us. We tried a new beater brush, no help. If I have to use it at it's highest level to sweep my carpet, I might as well not waste my time. Any suggestions?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
The only thing I can suggest is that the brushroll could be in backwards, as you look @ the bottom of the brushroll from the bottom plate, the head of the screws should be facing the floor on each side of the brushroll, so check the brushroll because I thing that is what is happening, what you can do is adjust the brushroll down using the screws doing a ¼ or ½ turn
Until the brushroll stops bouncing across the floor, once you get it adjusted correctly then raise the height adjustment to the highest level and adjust downward to listen for the tone to change and then try it, it should work and if not go down one more adjustment – also change the belt every 4 to 6 months as recommended by the manufacturer. Feel free to contact a local vac dealer in your area for the brushroll height adjustment if you have problems. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
For a owner manual contact the Kirby Factory Dealer.
http://kirby.com Contact Us by Phone
United States and Canada 1-800-494-8586
Between the hours of 8:00 am to 5:00 pm EST
Monday thru Friday
Don – The Vac Man
Go Ahead. Use Us.
May 06, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Hoover U5780-900 Windtunnel Cyclonic Bagless UprightVacuum Logo
20 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
