Question about Vehicle Parts & Accessories
No fire on the plugs it has 2 plugs and coils either fires
It's not a gas problem,, it's a firing problem it don't fire on either coil,I put new plugs in,it started road about 20 min. it stop running, now is not getting fire to the plugs
  • 44 Answers
Check your coil(s).
Posted on Sep 26, 2014
2 Suggested Answers
dickandannet
  • 2485 Answers
SOURCE: Why my cadillac fleetwood brougham engine not getting any fire?
check crank sensor ,check coil or coil pack,check for fuel pressure.
Posted on Aug 10, 2014
Replaced coil on 49cc will not fire
u got spark put a dime in the plug that's the gap u need hope this helps or just a bit of gas into the head where the plug goes good luck
Jan 05, 2014 | RTO 47cc / 49cc Pocket Dirt Bike Atv...
Truck is not firing on 3 cylinders yet it runs.. Runs really rough, back fires, under powered.. Plugs are Wet, Firing order is correct. New Spark plug cables. Don't know that is wrong! Please Help
Check for spark at the plug ( may have coil problem).
If spark is good then do a compression check. Pressure shouldn't be less than 75% of known good cylinders.
Apr 17, 2013 | 1995 Dodge Dakota
Coil wont fire all three wires have power but no fire to plugs replaced twice
Crank sensor if it has one,timing belt skipped is a possibility,and always the dread security key problem.don-ohio
Apr 01, 2013 | 2001 Ford Focus
1993 Nissan 300zx: Number 4 cylinder doesnt fire.
Please read about misfire diagnosis and repair here.
Oct 01, 2012 | 1993 Nissan 300ZX
Firing order. took the spark plug cables off and don`t know where they go back
First,look at the coils see if the towers are numbered.Each coil fires 2 cylinders!
look on intake manifold for fireing order display! The v6 engine fires from one bank across to the other in a straight line example,cylinders 1&2 3&4 and 5&6 at the rear of the engine or farthest right side. 1&2 left side faceing engine 3&4 in the middle. All you need to do is find cylinder # 1 hook up the # 1 wire to the # 1 coil tower to the # 1 plug or cylinder,follow the fireing order 123456,its simple if you cant see coil tower numbers look at another car with same engine that has distributor less ignition.The coil pack for the 4 cylinder gm has plug wire terminals or towers numbered as well.Only in a harder place to see like behind and underneath!
Sep 08, 2010 | Buick Skylark Cars & Trucks
I have no fire on my pro 40cc 18 inch. what part
new are used coil is what you need distance between coil and flywheel is the thickness of a business card
Sep 02, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
1999 S10 will crank over but will not start.
Check the air gap on the crank shaft sensor, if it does not have a .50 gap it will not send signal to fire coil pack repy to this post if you need more help.
Aug 30, 2009 | 1992 Chevrolet K1500
4 cyl. won't start,new plugs, wires,cap,etc.
a crank sensor tells the coil to fire.are you getting a signal at the coil to fire?
May 25, 2009 | 1995 Jeep Wrangler
Vehicle Parts & Accessories Logo
67 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
