Question about Delta Model DT2400CS Pressure Washer 5.5HP
While using washer if you let the trigger go it kills the engine
Runs great while sprayer is in use,just replaced the carburetor because it has been setting up for six or seven years was used it was new when it was set up used once I got it at a garage sale
Pressure washer start fine and idles appropriately trigger is depressed washer runs for about five minutes then just shuts off. Engine restarts fine but when trigger is depressed engine shuts off
looks like the fuel cap may not be venting try it with the cap loose allowing air into the tank sounds like lack of fuel entering into the carburetor.
Aug 03, 2013 | Karcher 2500 PSI Pressure Washer
I have a Honda pressure washer. Trigger must be pulled and held while starting. After starting the sprayer works OK but engine lugs down and dies as soon as trigger is released. Anything I can do, or need...
The problem with the engine is going to be a cleaning of the carburetor. Remove the carburetor and clean you may need a rebuild kit but try the cleaning first. The problem with trigger being held to start, I have herd this problem before and most people just except the fact that this is what they have to do to start. I would remove the pump and clean the check valves and unloader valve. If you are some what machanically inclined you can handle this, but if your not sure you should take this to the shop.If you need parts or just want to see a parts breakdown of pump and carburetor you can go to jackssmallenginerepair.com and go to parts look up and type in your model #. I hope this helps.
Jul 25, 2011 | Honda Black Max 2600 PSI Pressure Washer
Engine runs fine and then shuts off when I turn on sprayer
When the gun trigger is pulled, the back-pressure holding back the engine is reduced and the engine accelerates.
Your engine is dying when it should accelerate.
Good news is you have spark and combustion and fuel and the engine runs.
1) Check the exhaust port for build-up of carbon or dirt >>> the hot exhaust gas has to fly out of the exhaust port and if the port is clogged, then the engine stalls
2) Check the amount of fuel getting through to the carburetor >>> pull off the rubber hose entering carburetor from the gas tank >>> does gas run out freely? If gas does not run freely, then take apart your gas filter located just below gas tank
3) Remove air filter and see if problem continues. A dirty air filter can cause engine to stall since combustion requires oxygen coming through the filter. Replace the air filter.
4) Mess with the choke lever and see if you can find a setting where the engine works >>> our old power washer would never run when lever was moved to full throttle >>> we just left the choke lever at half throttle and the engine was happy
5) If above fixes don't fix the problem >>> the final suspect seems to be the carburetor >>> try some gun-out >>> maybe a trip to small-engine repair shop is required.
Oct 19, 2010 | Honda Black Max 2600 PSI Pressure Washer
What would cause a pressure washer to cut off after you pull the handle to get the water started
We used power washers for years
When you pull the trigger, the engine is supposed to accelerate because the back-pressure on the pump is released.
The back-pressure is why you're supposed to keep the gun trigger open when starting the engine. It sounds like you're starting the engine with no water passing through the gun.
Inspect the exhaust port >> if exhaust is clogged with carbon or dirt, then the engine will not run at high speed.
The problem may also be cause by a rusted choke lever. If you notice when a small engine accelerates, the choke lever moves up as the carburetor demands more gas.
Start the engine with water passing through the gun >>> move the choke lever a little bit at a time and see what happens. Keep water going out of the gun. When the surfaces are cool, spray WD-40 on the lever and see if you can free it up. WD-40 is extremely flammable.
If your engine will not fire at all by starting with water passing through the gun, then your gas supply might be limited or your carburetor gummed up. Pull off the rubber gas line that connects to the carburetor and see if gas flows.
Next, pull off the air filter and see if the machine runs good without air filter. You may have clogged air filter.
While the carburetor is exposed, spray WD-40 into carburetor. See if you can get engine up to full throttle while spraying WD-40 into carburetor. Keep spraying the WD-40. Keep the water flowing out of the gun.
If the engine throttles up all the way on WD-40 but won't run without it, then your carburetor is probably gummed up.
Our old power washer won't run with the choke set at full throttle. We just got into the habit of leaving the choke alone. We'd pull off the air filter and spray WD-40 into the carburetor so the engine would spark healthy without messing with the choke at all. And we kept the choke about 2/3 open all the time.
Oct 15, 2010 | Garden
My troy built 2200 pressure washer was running fine but then shut off instantly I then noticed it had low oil I filled it but now it won't start
Pressure washer takes oil in two places:
Pump oil is 20-30 weight SAE non detergent and comes half way up/ do not fill more than 1/2 way
Engine oil is 10W30 and comes half way up dip stick
IF you overfilled the oil >>> DO NOT turn power washer on it's side or upside down to drain oil >>> because engine oil will fill carburetor
When engine won't start
We pull off air filter so we have direct access to carburetor
Spray WD-40 into carburetor while starting
The engine will fire on the WD-40
You can keep spraying WD-40 into carburetor to keep engine running while moving choke to see if engine will run on it's own
Squeeze gun trigger so water comes out gun and pump pressure doesn't stop engine
If engine will not fire on WD-40
Spark is suspect
Your spark plug gets power from ignition coil
If coil is bad you get no spark > and coil needs needs replacement
Take out spark plug, clean it with WD-40 and use a bit of sandpaper in the spark gap
Put spark wire back on plug
Touch threads of spark plug to metal part of engine > pull cord and look for sparking between spark plug and engine
If you do NOT have any sparking, then coil is bad
If you HAVE spark, then your spark plug needs cleaning or replacement
If engine fires on WD-40 but will not keep running
Then either fuel or carburetor are suspect
Loosen hex nut on fuel filter located below gas tank >> if fuel flows, then re-tighten hex
Next, pull off rubber hose connected to carburetor to see if fuel flows to carburetor
If fuel is flowing to carburetor, then the carburetor is suspect.
Small engine repair shop will have carburetor cleaners
Check exhaust
There is a screen over exhaust
Make sure it is clean of carbon build-up > Use WD-40
Change air filter
Oct 12, 2010 | Briggs & Stratton Garden
I have a Briggs & Stratton pressure washer, Model # 20292 (True Bilt 2200). I have no problem getting it to turn over and it will run for 3-5 seconds, but then die. Any suggestions.
If #1 doesn't work, the ports in your carb could be clogged. I just dealt with this problem this weekend. This is a relatively easy fix. Locate your carburetor and find the aluminum bowl underneath. On the bottom of the bowl, you'll find a bolt. Loosen the bolt (gasoline will come out because the bowl is a reservoir for gas, but please make sure you've turned the gas supply off) and remove the bolt and the bowl. Clean any debris out of the bowl. The ports are holes in the bolt you removed. Make sure that air can pass through these holes (I blow through them, but I don't mind the taste of gas too much. Probably NOT healthy. You can use thin wire, carb cleaner, etc..) Reassemble and your motor may start, if this was the problem. Make sure that the bowl seats properly and that you are careful screwing in the bolt, lest you cross-thread it. Hope that helps.
Apr 06, 2010 | Briggs & Stratton Gas Pressure Washer...
Troybilt pressure washer won't run
If you ran the pressure washer without water running through it on startup you probably got your pump.You are supposed to engage the trigger on start up with water running through it so as to release the pressure off the pump so it will start easier. Hope this might help you.
Sep 15, 2009 | Briggs & Stratton Prosumer 20324 Gas...
Pressure Washer Engine will not stay running
My Kracher 2500 pressure washer has no pressure unless I remove the nozzle. If, I remove the nozzle and pump the trigger several times and quickly replace the nozzle it works fine until I release the trigger. Karcher (online) suggested I remove and clean the unloader which I did. It still doesn't work correctly. What another solution?
May 29, 2009 | Garden
Laking below sprayer large rubber piece covers area that is leaking
Sounds like your thermal relief has popped and is not reseting. These are an easy replacement. Usually availble as a "thermal relief valve" in sizes 3/8npt or 1/4"npt ..national pipe thread. Might also mean that your pump is overheating. Check and replace the pump oil. Make sure you do not allow this sprayer to sit and run without triggering the gun every couple of minutes.
May 01, 2009 | Garden
Delta Model DT2400CS Pressure Washer 5.5HP Logo
Top Delta Garden Experts
John Trevino
ray012965
Neil Hadrich
Neil Hadrich
Level 1 Expert
Are you a Delta Garden Expert? Answer questions, earn points and help others
