Question about LG Heating & Cooling
Lg lw6511r Panel has no power
My a/c unit is very noisy. How do I diagnose and fix the problem?
Most likely is that on of the fans are hitting something. Take the cover off , turn fan shaft by hand . Bend item out of the way or adjust as necessary.
Jun 16, 2014 | LG Lw6511r 6,500 Btu Window Air...
No power for lg wm2277hw
Power supply has failed to the panel board and it can due to failure of the board, failure of the surge filter or the power circuit.
check the panel and if there is short within the board then the panel must be replaced
Jan 16, 2013 | LG WM-2277HW Front Load Washer
My lg wm1814cw won't come on but outlet have power
Possible that the power supply to the program controller unit has failed or that the program controller panel by itself has failed.
Remove the panel after disconnection of power and check for input power to the panel, check for fuse., if the fuse blows up again the board can have shorts within and will need a replacement.
Jan 15, 2013 | Washing Machines
LG LCD 26LX1D power blinking red ,all capacitor on power board are ok
try replacing relay on power supply had this twice on lg and goodman lcd tvs
Nov 25, 2012 | LG 26LX1D 26 in. LCD HDTV
Same power supply board LG L1910s and L1510s ?
just look the amper rating in the power supply if they are the same.
Sep 20, 2012 | LG Flatron L1951S 19" LCD Flat Panel...
No picture on LG Flat panel and no sound. Only
know how to sloder?Replaced parts like capacitors burst open or puff up in the power supply.Or replaced the whole refurbish power supply board.Shopjimmy.com,Ebay.com to buy.
Jan 14, 2010 | LG 27LC2R 27 in. LCD TV
Is there such a thing as circut board power pack for a Plasma tv 50P3CD?
There is such thing as power supply unit for LG 50PC3D Plasma TV with panel model PDP50X30010.Part number is 68709M0046A. LG part number is 6709900020A.
Nov 03, 2009 | LG 50PX5D 50 in. Plasma HDTV
LG LDS5811BB Dishwasher
Some of the LG LDS5811 had problems with the wiring harness in the door panel. This is nothing to mess with unless you have disconnected the DW from power.
You can open the door panel by removing the screws around the inside edge of the DW. Or, better yet, firmly but politely contact LG service and tell them you are aware of LDS5811 dishwashers having these symptoms being caused by _melting_ wires in inside the door panel. This is true and even if the DW is out of warranty, LG should fix this problem at no cost to you.
Good Luck!
Aug 09, 2008 | LG 24 in. LDS 5811ST Stainless Steel...
Heating & Cooling Logo
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
