Question about Yaesu Ft 2900r Vhf Mobile 75 W Two Way Radio Ft2900 R
WILL NOT POWER UP
STARTED AFTER WE JUMP STARTED MY TRUCK
    Problem Solver:
  • 7 Answers
How is the radio power connected? directly to the battery? or thru some accessory connection....... it should go directly to the battery with fuses on both leads. If there was not fuses on both wires, I suspect you have a serious problem caused by the "jump". However, if there are fuses on both, check them with a ohm meter and tell us the status. 73, Jim - K9KUZ and what is your call sign?
Posted on Nov 27, 2014
Fuel pump cut off switch
Do you have power at the starter posts and the main fuses in the fuse box in the engine compartment ?
Jan 23, 2014 | Chevrolet Colorado Cars & Trucks
My truck just died at an intersection, i lost all lights and power. the truck would not crank over nothing. I waited an hour later and the lights came on and the truck tried to start but battery was too...
Did you try to jump the battery with another battery....if it starts, then even though your alternatir us good, perhaps your battery has just had enough...they do die eventually
Oct 01, 2013 | 2003 Chevrolet S-10
F350 no start I just bought the truck installed a new soliniod on the fender and it started up fine 3 times I stopped on way home left truck for an hour at home now nothing the wire from key switch has...
Have you tried jumping the two big terminals on the solonoid. Careful if it is working you will get a spark,big srewdiver and just flash it.
Feb 20, 2013 | Cars & Trucks
No power at the in tank fuel pump
have you check the fuel pump relays and your imobliser if you have one
Feb 11, 2013 | 2002 Dodge Ram 3500 Truck
2004 porsche cayenna loosing power while driving
Sounds like the alternator has failed but without a good look i could say ,jump start vehicle then with engine running take a battery terminal off ,if it stops then the alternator isnt charging
Oct 05, 2012 | 2004 Porsche Cayenne
How do I get truck started after its been sitting for months
Charge up the battery with a battery charger or jump start the truck with a good battery. Connect the jumper leads from the good battery to the battery on the truck.
Connect the red lead from the + terminal on the good battery to the + (plus) terminal on the truck.
Connect the black lead from the - terminal on the good battery to the - (minus) terminal on the truck.
The good battery will supply power to the starter motor.
Then you can turn the key to start the truck.
Feb 24, 2012 | 1991 Ford F150
Rpms jump when started, engine hesitates until the...
fresh spark plugs and wires would most likely fix your problem same thing happened to my truck
May 20, 2010 | 1998 Dodge Ram 1500 4WD
F150 supercrew cab won't start,,battery good
If you're using your truck to jump start another dead battery in a different car..your truck should be runing when you do that.....
If you leave your truck turned off and are jump starting another car/truck that way..you are drawing your CCA (cold cranking amps) way down, and really shortening the life of your batery..you'll be needing to get jump started yourslf pretty soon.
Dec 13, 2008 | 2003 Ford F150 Regular Cab
Truck won't start
this sounds like crankshaft position sensor, my Cherokee was ding same thing it ended up being crank shaft position sensor. this part costs about $50 and is easy to install.
Dec 02, 2008 | 1998 Jeep Cherokee
My 93 toyota truck has no power at all to ignition, lights nothin
My truck was doing the same thing, and it turned out the starter was going bad, it started drawing too much juice from the battery, so the crank power from the battery wasn't enough to start the motor, but the battery was good, if you jump start it from another vehicle and it starts right away, it is most likely your starter.
Nov 22, 2008 | 1992 Toyota Pickup
Yaesu Ft 2900r Vhf Mobile 75 W Two Way Radio Ft2900 R Logo
87 people viewed this question
Top Yaesu Radio Communications Experts
Steve
eradiostore
eradiostore
Nyte_Ryder
Are you a Yaesu Radio Communication Expert? Answer questions, earn points and help others
