Question about Yamaha Yst-r7 Receiver
The light in my yamaha tuner is burnrd out - Yamaha Yst-r7 Receiver
Yamaha rx850 stuck on tuner mode and volume nob has a blinking light no sound mybe stuck on standby mode?
Are any of the buttons stuck on/in , which would jam the processor?
Maybe the tuner button stuck in? Try spraying them with switch cleaner on the front. If not.
ELECTREPAIRUSA@ELECTREPAIRUSA or you can contact us at that address as we repair/renovate all items electronic and electrical old and new.
Jan 07, 2017 | Yamaha Audio Players & Recorders
Subwoofer not recognized and no sound from tuner
do a test tone which will test all speakers connected to the receiver.
Apr 19, 2014 | Yamaha Audio Players & Recorders
No sound from tuner with station tuned
Check you have the plugs in the correct ports, there are manuals at
Yamaha Manual Library
Feb 09, 2014 | Yamaha RX-V757 Receiver
Cr 420
Honestly, the only way you'll be able to find out is to simply break it down and troubleshoot it.
Sep 02, 2012 | Cameras
My yamaha htr 5250 suffered a shock from thunder storm, no sound out of channels, just humming
The thunder storm has damaged the audio output semiconductors, replacement of parts only option to correct.
May 21, 2012 | Yamaha Htr-5250
I have a yamaha Rx-v361 i get sound when in DVD mode, SAT mode but no sound in TUNER or AUX (MP3 player) modes, i checked all the wiring in the back of the unit and everything is connected. please advise
Tuner is internal so there's no way wrong 'wiring' could be the problem there.
Does the tuner actually 'tune' a station?
If you're using V-Aux on the front panel for your MP3 player, make sure you haven't assigned V-Aux to a digital function. Page 48.
http://www.retrevo.com/support/Yamaha-RX-V361-Receivers-manual/id/2526ci758/t/2/
Jan 16, 2011 | Yamaha RX-V361 Home Theater Receiver
I am trying to turn on my sirius radio (it has been working for 1 year) and all of a sudden it says 'check sr tuner'. Everything seems to be plugged in right yet it still won't turn on. Any ideas?
Page 62: If "CHECK SR TUNER" or "ANTENNA ERROR" appears in
the front panel display, the connection of the SiriusConnect
tuner or antenna is incorrect. In such cases, check the
connection of the SiriusConnect tuner and the antenna (see
page 115).
• If "NOT SUPPORTED" appears in the front panel display, this
unit does not support the connected SiriusConnect tuner.
Or the SR Tuner is fluky. Refer to its manual and start over with IT as the product, not the Yamaha.
Jul 13, 2010 | Yamaha RX-V663 Receiver
Yamaha RX-V757: Tuner not working
Is it set for XM / Sirius? If so, you need their special antennae unit; or are you talking AM & FM?
Jan 12, 2010 | Yamaha RX-V757 Receiver
No instructions for a yamaha erg 121 c electric guitar
i don't really know what instructions you expected, although you should have received something for the tuner and amp. I suspect that you are new to playing the guitar, as, I don't wish to sound disrespectful, you would know what to do! So first, and again I hope not to sound like I'm treating you like a dummy, plug the guitar into the tuner input. Or if It's a piezo tuner clamp it to your headstock. Most tuners are now automatic so it should pick up on the string you are striking.Repeatedly pluck the same string til the tuner changes colour, or flashes, or some other indication to tell you the string is at pitch. Repeat the above for all 6 strings.
Then plug the cable into the amp input, switch it on, and bugger about with the controls til you get a half decent sound. ( thats what the rest of us do).Don't expext too much from this package, it is budget level, but of quite good overall quality.hope this helps
Feb 05, 2009 | Yamaha Electric Guitar
How do I remove the limiter
buy a after market tuner like a commander power tuner.
Jan 11, 2009 | 1997 Yamaha XJR 1200 SP
Yamaha Yst-r7 Receiver Logo
14 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
