Question about Garden
John deere lawn tractor rx 95
Starts up runs a few seconds and then gas pours into carb starts up and runs a few seconds when gas pours into carb
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,069 Answers
Carburetor needs cleaning. sounds like the Needle valve is not doing its job
Posted on Jun 25, 2014
SOURCE: illustrated parts list for john deere 102 riding lawnmower
Go online to www.johndeere.com click on residenial tractors,then click on services and support. You should be able to get an answer there. Otherwise contact them through email.
Posted on Apr 08, 2009
SOURCE: gas tamk removal john deere 115
I had the same thing happen. I got the tank out, but it wasn't easy. Take out the bolts out that hold the rear end on. Take off the two springs that support the seat. Take out the battery and the battery tray. Take out the 6 bolts that hold the black cowling and the front of the green platform to the frame. This will allow you to lift the seat platform far enough off the rear end to allow the tank to be pulled out through the side. You also have to remove the metal bracket which holds the front of the tank and has caused the tank to leak in the first place. New tank is $56.00 not installed. I used a soldering gun and melted the plastic back together. I think it will hold quit a while. I know this is a little sketchy, but It worked for me.
Posted on Jun 02, 2009
wilsodfarm
  • 986 Answers
SOURCE: 3020 carburetor ? john deere gas tractor, 3020
those carbs are real simple you will not have any problem
Posted on Jul 29, 2009
  • 548 Answers
SOURCE: can't get front wheel off my john deere lawn tractor
remove the cap on wheel then there is a ring or cotter pin to remove then pull wheel off
Posted on Aug 22, 2009
nova2nv
  • 197 Answers
SOURCE: John Deere Lawn Tractor LX176. Battery discharge
Locate voltage regulator above battery to the left as you sit on machine,its behind frame that supports steering wheel.Once you have found it use a light to shine on harness and follow the brown wire that leads into regulator.The plastic around that wire should not be burnt or showing any other color.The LX series machines had a problem with brown wire coming loose and causing the charging light to stay on.Remove plug from reg and use small screwdriver to clean out wire and work it a little so it makes good contact.
Posted on Nov 13, 2009
I have a john deere stx46 that will crank but not start. Gas is getting to the carb but nothing seems be be coming out the other side of the carb. Could the carb be clogged?
pour a little bit of gas in the carburetor and try it. if it starts for a few seconds it may be clogged and need to be cleaned. change the spark plug first. and try if it wont start then try the carburetor.
Jun 09, 2016 | John Deere Garden
I have a John Deer riding lawn mower SX95 with a fb460v kawasaki engine that only starts with fuel dropped into carburetor I have a good spark , I had changed the oil and filter , I also took the carb...
in the carb did any of the screws have any micro bored holes for gas to go through like in many small engine iv found . clogged with goop. does it have a gas bowl an a screw on bottom take it out if does an look it over close.
Jul 25, 2014 | John Deere Garden
Gas pouring into carb
carb float problem
Apr 22, 2014 | John Deere Garden
John deere 116 no fuel to carb
Blocke inline filter, or if it has a pump, then this is not working.
Feb 29, 2012 | John Deere Garden
My john deere L130 riding lawn tractor has spark and gas going to the carb but wont start. it has new spark plug and fuel filter When starting fluid is sprayed into carb it runs till its burnt up and...
I had a JD 111 rider that may have had the same problem. Turned out to be the fuel line had a weak area and would **** together and not allow the fuel through. It's a cheep place to start.
Good luck!!
Jul 11, 2011 | John Deere Garden
John Deere 115 lawn tractor - won't start. Replaced fuel filter, fuel pump, spark plug, oil filter (changed oil), but still won't start. Engine cranks, but won't run.
I have a 115 john deere tractor that runs but the engine will not run smooth I've put a new fuel cap on it a new pump and clean out the carb.
Apr 16, 2010 | John Deere Muffler 1010 Diesel Tractors
My john deere 245 lawn tractor will not start only backfires out the muffler.
There are 2 likely problems.
First spray a prime in the carb and see if the motor runs on a prime. If it does then you need to remove your carb and clean- there is likely water in your fuel.
Second- check for a sheared flywheel key.
Dec 28, 2009 | John Deere Garden
Garden Logo
75 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
