Question about Frigidaire Affinity ATF7000E Front Load Washer
Affinity agitators loose - Frigidaire Affinity ATF7000E Front Load Washer
  • Frigidaire Master
  • 5,323 Answers
CHECK THE CAM DOGS IN THE AGITATOR>
Posted on Mar 31, 2015
Why will my affinity front load washer not spin?
No spin, try these:
Using a multi meter check for continuity the door switch, which when bad may not allow agitation or spin. The lid switch assembly can fail either mechanically or electrically.
Check the clutch, brake assembly and transmission, one way to check for slipping is to get under the machine after a spin cycle ( this is if u get a lil spin but not much leaving clothes still wet) mix in a spray bottle a lil water and some dish detergent, then spray it on the clutch assembly ( the metal round pc. Connected to the tranny) if it sizzles and steams up then u know its bad and slipping. Another way to check clutch if u get no spin at all? Is to take it out and use ur hand to try and turn the inner spring assembly pushing it around the inside? If its very easy, it BAD should be hard to push by hand.
Next check the motor coupler which engages the tub and tranny to the motor. ( if its bad u usually get no wash or spin or very little of either)
Next check for a loose, worn or broken belt if belt driven.
On some front load models u may need to check the STATOR assembly.
The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Apr 27, 2014 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire affinity not spinning
No spin, try these:
Apr 02, 2014 | Frigidaire Affinity ATF7000E Front Load...
Sock stuck under agitator
Good Afternoon Haley - Based on the model number posted above, it shows that you are speaking about a front load washer. Is that correct? If so, then generally speaking front load washers do not have an agitator. If a sock is caught underneath it is typically because it got caught in between the door and drum because the seal is either damaged or off the track. If you have a top load washer, you may try to twist the agitator and then pull it out to remove it, as you would for maintenance cleaning.
Jun 24, 2013 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire affinity dryer putting holes in clothes
Its probably not your dryer. I had the same problem and it turned out to be the washer itself. The agitator[probably not spelled right] needed to be adjusted. I could not see the holes when taken out of the laundry only when dry. If not in right position little metal clips under agitator hook on cloths and rip them during wash.
Dec 11, 2012 | Dryers
Frigidaire Affinity Front Loader Washer
Check if there is any gap or if the bearing are worn on the agitator, check by pushing the agitator for any play. If so the bearings must be replaced,
Sep 26, 2012 | Frigidaire Affinity FAFW3511KW 3.5 Cu. Ft....
The thin straps on all our shirts are tearing off during wash cycle
Check the drum for a loose agitator bar.
A worn tub bearing or support can pinch and damage clothes, but it likely would show up as damaging more than just shoulder straps.
Try using a garment bag made for washing delicates.
Here's one:
http://www.kmart.com/shc/s/p_10151_10104_011V067138942000P?mv=rr
Good luck from Detroit, MI.
Jul 19, 2011 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire Affinity Glacier Stackable upright washer. Washer will not agitate and makes a buzzing sound from the pump that extracts water from the drum. Water collects and remains in bottom of washer.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 29, 2010 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
Affinity washer will spin as if off balance
well there's a counter weight that could be loose or broke or the support hangers for the tub may be broke or loose.
Sep 17, 2009 | Washing Machines
On "spin only" setting, it's just doing a gentle agitate
defective motor control board,,,motor and motor control board (or)speed control comes as 1 part..onthejob
Jan 14, 2009 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire Affinity ATF7000E Front Load Washer Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
