Question about Logitech MX1000 Laser Cordless (097855023933) Mouse
Usb connector not working
Vx logitech revolution usb piece doesn't work all the time -- can it be reploaced?
  • 85 Answers
Have you tryed a differant usb port? If the usb port does work at least some times it is more than likely a regestry problem. try this and see if it works. click "start" then "run" type in "regedit" "ok" click the + next to "Hkey_Local_Mechine" + next to "System" + next to "CurrentContro;Set" + next to "Control" + next to"Class" then click on "{4D36E965-E325-11CE-BFC1-08002BE10318} in the right field, right click on "Upper Filters" click delete, then right click on "Lower Filters" click delete, restart PC. if this doesn't work the yes get a usb card to install. GL hope this helps you.
Posted on Jun 20, 2009
Logitech mx revolution
Hi
Maybe your registry is not clean. You can use registry fixing software and then run registry analyze. and restart your computer.
Jan 19, 2014 | Logitech MX Revolution 931689 Mouse
HI vx revolution mouse repair
no sorry, once the little pins and rollers inside have broken their isn't any way. I'm really sorry.
Dec 25, 2009 | Logitech VX Revolution 931690-0403 Mouse
My VX revolution is missing too much left clicks. Sometimes I need to click 5 times to get 1 click. All the others buttons are working fine. How I can fix this? thks
Seems that the left mouse button needs to be replaced. If you have an old mouse, you can use it as a source of a spare mouse button, & replace the defective button on your VX Revolution.
However, you need to make sure that:
1. The replacement button is identical to the defective one.
2. You have enough skills to solder/desolder electronic components.
Oct 25, 2009 | Logitech Cordless Click! Mouse
Wrong Receiver for Logitech Vx Revolution Mouse
logitech has connection software on their site you need to run
Jul 07, 2009 | Logitech VX Revolution 931690-0403 Mouse
Unresponsive left mouse click
I have that issue too. At the beginning I tought it was a connectivity problem but it does it even with the receiver side by side. Latelly it is working perfectly.
Jun 10, 2009 | Logitech VX Revolution 931690-0403 Mouse
Vx problem:movement
First try this
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver button and then press the button on the mouse. This should be done whenever you change batteries or glitch.
If that doesn't do it theen try this.
Normal 0 Disconnecting the Mouse Receiver from the USB port and reinstall the CD software program. When the program asks you to connect the Mouse Receiver to the USB port, do so and it should work.
Hope this helps. Bud
Dec 30, 2008 | Logitech VX Revolution 931690-0403 Mouse
VX Revolution Cordless Mouse for Notebooks dead as a door nail...
I see no reason that the mouse should not work. They have the Xop driver and the install software. Download both and also read henote that they are talking about in. red. I didn not download it myself. If this doesn't work you can get a common PS 2 mouse for a small amount  most anywhere including Walmart.
http://www.logitech.com/index.cfm/428/165&cl=us,en?softwareid=4338&osid=1
Dec 30, 2008 | Logitech Cordless Mouse
Mouse doesn't follow
I would venture that for some reason, the LED light at the bottom needs that much space to bounce back the signal for the LDR (light dependent resistor) to read properly. This could be due to a slight misalignment, dust in the bottom optics, weak battery (for wireless). A temporary workaround (which for some works as good enough solution) is to add a smooth spacer atop the rubber feet. Personally, I use a paper puncher to cut little circles on a slightly thick automotive sticker. The circles are then peeled of from the protective paper backing and attached to the existing/original rubber feet. This raises the bottom height which do improve light bounce and therefore mouse action.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 18, 2008 | Logitech VX Revolution 931690-0403 Mouse
Logitech MX1000 Laser Cordless (097855023933) Mouse Logo
587 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
