Question about Mtd Garden
Gas leak carb overflow
Gas fills up carb body and air tube
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 140 Answers
Carb needs rebuild.
Posted on Jan 07, 2015
2 Suggested Answers
vincob
  • 718 Answers
SOURCE: have marvel-schebler tsx-428 carb on'53
Ya know what maybe check your floats.
Posted on Aug 21, 2010
Why is bike flooding and pushing gas out top over flow hose on carb after it runs for a min or two. Carb float been replaced still doing it.
Hi, Paige and the usual suspects are:
1. Damaged or restricted fuel tank venting system.
2. Loose float bowl screws.
3. Damaged float bowl o-ring.
4. improper fuel level in the float bowl.
5. Worn or dirty inlet valve or seat.
6. Damaged or leaking float assembly.
7. Particle contamination in inlet fitting cavity.
For more information about your issue please visit the websites below. Good luck and have nice a day.
My carb leaks fuel out of the overflow hose at the bottom of my carb
Carburetor is leaking gas out of overflow tube need help
Carburetor Carb Leaking Gas How to Fix Repair it Motorcycle Honda DIY..
Carbs leaking Here is how to fix it
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Mar 28, 2016 | GAS Motorcycles
Gas leaking out overflow tube as soon as petcock turned on fuel running out of overflow tube,running or not
If you are saying the fuel is leaking out of the carb overflow tube it would likley be that the float and/or needle and seat are stuck or defective
Jun 10, 2014 | 2004 Harley Davidson FXDWG - FXDWGI Dyna...
I have a 98 honda fourtrax 300 4x4 and it is leaking oil out of the overflow tube
please check oil level sound like to much oil in crankcase.darin oil and check for gas from faulted carb leak while not running.This would fill crank case with gas and cause oil over flow
May 22, 2014 | Motorcycles
1980 750 honda carbs leak gas from bowls
Most likely, one or more of your carb floats has gotten stuck. The carbs have connected, so one sticky float will impact all the carbs equally. With the bike on the center stand, you can turn on the fuel petcock and see which bowl starts overflowing first, but that's not a perfect test.
The right way to correct this is to dismount the carbs and clean out the bowls and floats to ensure that everything is working properly. This would also fix the issue of having some dirt in the needle valve, preventing it from fully shutting off.
The sloppier fix that might or might not work for you is to leave the carbs in place and drop the bowls for the outer two carbs. When a bike is routinely parked on its side stand, I've found that the right hand carb, which has the lowest gas level and hence is a bit more likely to gum up. A dose of industrial strength carb cleaner (I like the stuff labeled "gum cutter") may free everything up--though you have to be careful that you don't damage or dissolve plastic/styrofoam floats.
Mar 27, 2012 | Motorcycles
Gas is in the air filter compartment. What could be the problem?
your floats are sticking and overflowing out the back of the carbs.
your overflow tube in your float bowl must be clogged, otherwise the gas would run on the ground throught the drain tube.
Clean your carb really good and you shouldn't have any problems.
I recommend taking them apart and soaking everything overnight.
Take the jets out and the float&needle and soak the carb bodies, jets and screws.
After soaking rinse with water really well.
After rinsing, blow through every opening in the carb bodies, blow through each jet, and make sure you can see through them and through the little holes in the side of the main jet.
Reassemble and should work like new.
If your floats are still leaking, you make have to buy a new float needle valve.
Try the cleaning first.
As for the carb soak, you can purchase it at any local auto parts store for approx $22.00
Happy Holidays
Dec 22, 2010 | 1997 Suzuki LS 650 Savage
My 1974 kawasaki ke 125 is leaking gas out the bottom of the engine. what is wrong with it?
Several things could be wrong. First, the fuel petcock (valve) at the bottom of the gas tank should be turned off when the bike is not being ridden. Also, it is possible the valve may not be fully shutting off the gas. This can allow the carb to overflow and leak gas. A stuck open or punctured float in the carb bowl can cause overflow. The float should be light as a feather and have nothing inside it but air. Is the carb securely mounted?
Check for cracked fuel hose or bad connections at the tank and carb. Is the fuel valve body leaking gas where it mounts to the tank? Heck, with the bike being 36 years old the tank may be leaking at a weld or due to rust through. I wish I could work on your bike. The older bikes are more fun to work on than the newer bikes. Post a reply and let me know what you find.
Aug 09, 2010 | 1976 kawasaki KE 125
Gas leaking from hose that is under tank that is not for gas flow
is it an overflow from the carb? gas will only be in one of 2 tubes and they are the fuel line from the tank and the carb over flow. unless you have an electronic fuel pump then tubes go from tank to pump to carb. if its coming from the overflow then you are getting too much fuel into the carb float chamber. you may have a sticky float. thy getting some Berrymans B12 fuel additive and putting double the doseage in the tank. run engine til hot then leave it to stand overnight. this should break down any gum/varnish that has built up in the system
has this been in storage thru winter?
Apr 02, 2009 | 2001 Honda XR 250 R
Gas leak
sounds like you have either a stuck float or a needle and seat leaking your carb is overflowing and coming out overflow tube. could try adding a carb cleaner additive to your fuel but chances are you will have remove and clean carbs or replace needle and seat jim
Mar 18, 2009 | 2007 Yamaha Royal Star Venture
Gas Leak via Overflow
The usual culprit is a blocked vent tube. Verify it's open. The usual indicator is either a pressure release when you open the gas cap, or a vacuum "sucking" noise when opening it first thing in the morning. On a carb equipped bike, the carb overflow lines will leak, but in a fuel injected bike like yours, it'll be out the overflow vent. The next time it begins leaking, open the gas cap. It should stop immediately as pressure inside is released. Good luck.
Nov 20, 2008 | 2005 Ducati Monster 1000S
Garden Logo
51 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
